Fcc declaration OM27160B1EVK
6,694件の閲覧回数
roberthuisken
Is there a FCC declaration for the OM27160B1EVK board.
6,563件の閲覧回数
KaiLi
Hello @roberthuisken
You're welcome. Yes, we don’t obtain FCC ID numbers for development boards as they are not required for development boards.
If your question is clear please mark it as solved, thanks.
kelly
10 返答(返信)
6,679件の閲覧回数
KaiLi
Thanks for your contacting us and interested in the NXP products.
Yes, we have the FCC declaration for the OM27160B1EVK board, please check the attached file.
To update this case, you may reply by email.
To provide confidential information or attachments, you may add that online.
Please login to our NXP technical support portal:
https://support.nxp.com/s/case/5002p00002s6CAeAAM
The portal allows access to the full details of the case, including the previous communication.
Thank you for your interest in NXP Semiconductor products and for the opportunity to serve you.
Kelly
Technical Support
NXP Semiconductor
6,649件の閲覧回数
roberthuisken
Thanks for helping me.
Now its clear that answer is lying on that document.
6,639件の閲覧回数
KaiLi
kelly
6,645件の閲覧回数
roberthuisken
Do you have a FCC-ID number for the OM27160B1EVK board ?
6,640件の閲覧回数
KaiLi
Please check the below information, I think that it should be what you want.
kelly
6,633件の閲覧回数
roberthuisken
What i need is the FCC-ID number issued by the FCC organization for the OM27160B1EVK board.
Kind regards, Robert
6,595件の閲覧回数
KaiLi
Yes, I've checked the relevant team, there is no FCC ID and the device is not in the database. But we have the FCC report and the FCC DECLARATION OF CONFORMITY document that we can show to prove it. And here is the link where it is described: https://www.fcc.gov/general/equipment-authorization-procedures
kelly
6,621件の閲覧回数
KaiLi
This may be a little difficult, anyway I will consult the relevant team and update you if any news.
kelly
6,588件の閲覧回数
roberthuisken
Hello Kelly,
Thanks for the information.
6,564件の閲覧回数
KaiLi
kelly
