Could not resolve host: source.codeaurora.cn
kangqin
In the Android build step, in imx-p9.0.0_ 2.1.0 Execute source envsetup.sh in the auto-ga file path, and an error occurred: Could not resolve host: source.codeaurora.cn   ,How can I make envsetup.sh successful?
Sanket_Parekh
I hope you are doing well.
Please mention the steps you are following to reproduce the issue at our end.
Kindly attach the whole error logs you are getting for further debugging the issue.
Thanks & Regards
Sanket Parekh
kangqin
Thank you for your reply~
As shown in the figure, this is the step I took
Follow the steps of “Android_User's_Guide.pdf”
kangqin
/imx$ source ./imx-p9.0.0_2.1.0-auto-ga/imx_android_setup.sh
Start fetching the source for android build
Setting REL_PACKAGE_DIR to /home/root123/imx/imx-p9.0.0_2.1.0-auto-ga
Downloading Repo source from https://mirrors.tuna.tsinghua.edu.cn/git/git-repo/
remote: Enumerating objects: 4483, done.
remote: Counting objects: 100% (4483/4483), done.
remote: Compressing objects: 100% (2133/2133), done.
remote: Total 8049 (delta 3993), reused 2350 (delta 2350), pack-reused 3566
Receiving objects: 100% (8049/8049), 3.79 MiB | 9.92 MiB/s, done.
Resolving deltas: 100% (5176/5176), done.
manifests:
fatal: unable to access 'http://source.codeaurora.cn/external/imx/imx-manifest.git/': Could not resolve host: source.codeaurora.cn
manifests: sleeping 4.0 seconds before retrying
manifests:
fatal: cannot obtain manifest https://source.codeaurora.org/external/imx/imx-manifest.git
-----Repo Init failure
Sanket_Parekh
Hi @kangqin
The steps seem correct. Kindly confirm that you are downloading the source code from the below official link.
Thanks & Regards,
Sanket Parekh
