Falcon Mode for IMX8MM V2 for linux
1,850 次查看
shivam_awasthi
Hi there NXP team, I was working in this board 1st time and I have to implement FALCON mode to reduce the boot time of my board IMX8MM V2, I have tried the example related to imx6 but not succeeded it was not able to exicute spl export command for generation of FDT. so do you have any document related to this process for IMX8MM V2.? please help me with this I have stuck on it from a long time.
and also is there any procee to launch the camera in 2-3 seconds, if is there please let me know.
标记 (2)
3 回复数
1,807 次查看
Dhruvit
I hope you are doing well.
Please find below the document for the IMX8M family
=>To launch the camera at an early stage of the boot process, one can try the below suggestions.
  • Put the required kernel module first in the makefile.
  • Put the init function at a higher level i.e early_init
Thanks & Regards
Dhruvit Vasavada
1,795 次查看
shivam_awasthi
Hi @Dhruvit
Do you have any document related to this process..? if yes please share with me.
1,767 次查看
Dhruvit
Hi @shivam_awasthi,
Unfortunately, we have no such documents related to this.
Thanks & Regards,
Dhruvit Vasavada
