FS86 PMIC OTP Programming
1,091件の閲覧回数
pratikkul26
We are working on PMIC FS8613.
We have made our own board of FS8613.
We are using S32K146 MCU to communicate with PMIC using I2C.
We are trying to write the MAIN and FS OTP registers but we are not able to verify if the registers are written correctly. We are trying to read these registers but they are showing NULL value. We could verify that OTP Mode status is shown to be 1 for MAIN and FS . However, we are able to successfully read and write the normal MAIN and FS registers.
We have few doubts regarding the otp programming as mentioned below:
1. While writing the OTP registers, how many data bytes ( 2 or 1) should be written as these registers are of 1 byte only? I2C frame structure as per datasheets shows 2 bytes of data(MSB & LSB)
2. For FS OTP registers what should be the device id 0x20 or 0x21?
is it compulsory to use KITFS86SKTFRDMEM for OTP programming?
1,059件の閲覧回数
guoweisun
Hi pratikkul26
Please order the socket board of FS86 to do OTP with GUI :
KITFS86SKTFRDMEM: FS86 Safety SBC Programming Socket Board | NXP Semiconductors
Please also download the user manual for this socket,inside of this files there is detail steps for dong OTP.
Hope this could help you!
