FS26 LDO Off Issue
FS26 LDO Off Issue
1,013件の閲覧回数
kjy106906
Hello
I am using the FS26 and S32K358.
I am using the FS26's VLDO2 as the power supply for the MCU and the FS26's VLDO1 as the power supply for the CAN transceiver.
When the MCU is left in a state of CAN communication, the FS26's VLDO turns OFF, cutting off the MCU's power.
(This occurs randomly, approximately every 1 to 8 hours.)
The VLDO is restored only after the FS26's power supply is cut off and then restored.
This issue occurs on all boards, not just a single one, and does not occur when CAN communication is not in progress.
The status when the issue occurs is as follows:
Vpre 6V O
VDIG 1.6V O
VBOS 5V O
VLDO2 X
VLDO1 X
VCORE X
DFS is disabled via OTP.
I would like to know the current state of the FS26 and what causes this to happen.
6 返答(返信)
992件の閲覧回数
RafaR
Hello kjy106906
Good day!
Is the watchdog enabled?
What are the values of:
  • FS_STATES
  • FS_GRL_FLAGS
  • FS_OVUV_REG_STATUS
  • M_REG_FLG
  • M_STATUS immediately after failure?
Have you checked if FS26 is not displaying any UV or OV flags?
Also could you share your M_STATUS?
I hope this information has helped you, please let me know if you need help with anything else.
Have a great day and best of luck.
972件の閲覧回数
kjy106906
@RafaR
Thank you for the reply.
Unfortunately, the MCU is receiving power from the SBC, but communication is not possible because the VLDO is OFF.
You must cut off and resupplied the board power for the MCU to function.
The watchdog window is infinite.
タグ(1)
881件の閲覧回数
RafaR
Hello kjy106906
Good day!
Looks as if the FS26 analog front end is still powered, but the internal power-tree supplying the system has been disabled.
One possible explanation is that a fault has been detected on one of the monitored regulators (VCORE, VLDO1, VLDO2), and the configured reaction disables the regulator outputs. FS26 documentation indicates that regulators can remain disabled after a fault depending on the configured fault-reaction settings.
859件の閲覧回数
kjy106906
+ waveform
Blue VLDO2 / Red Vpre/ Green VLDO1 / Yellow VCore
タグ(1)
870件の閲覧回数
kjy106906
Thank you
@RafaR
This is an important issue, so I would appreciate your response.
I would like to check exactly what state FS26 is in and why it failed.
When the issue occurred, I read the registers using an external tool.
FS26 [FS_STATES:0x17]R:0x0009; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_MIRRORCMD:0x1c]W:0x001d; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_MIRRORDATA:0x1d]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [ID_VOTP:0x1D]R:0x00
FS26 [FS_WDW_DURATION:0x0b]W:0xd08b; CRC[MOSI:0x00; MISO:0x00]
FS26 [FS_NOT_WDW_DURATION:0x0c]W:0x2f74; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_VSUP_FLG:0x07]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_VSUP_MSK:0x08]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_REG_FLG:0x05]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_REG_MSK:0x06]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_TSD_FLG:0x03]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_TSD_MSK:0x04]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_WIO_FLG:0x09]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_WIO_MSK:0x0a]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_STATUS:0x02]R:0x5020; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_COM_FLG:0x0b]R:0x0005; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_COM_MSK:0x0c]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [FS_OVUV_REG_STATUS:0x10]R:0x1544; CRC[MOSI:0x00; MISO:0x00]
FS26 [FS_INTB_MASK:0x16]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [FS_DIAG_SAFETY1:0x14]R:0x03c3; CRC[MOSI:0x00; MISO:0x00]
FS26 [FS_DIAG_SAFETY2:0x15]R:0x0010; CRC[MOSI:0x00; MISO:0x00]
FS26 [FS_SAFE_IOS_1:0x12]R:0xf000; CRC[MOSI:0x00; MISO:0x00]
FS26 [FS_GRL_FLAGS:0x00]R:0x5000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_DEVICEID:0x00]R:0x65d8; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_PROGID:0x01]R:0x0105; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_SYS_CFG:0x0d]R:0x0001; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_TSD_CFG:0x0e]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_REG_CFG:0x0f]R:0x0002; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_WIO_CFG:0x10]R:0x0202; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_REG_CTRL1:0x11]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_AMUX_CTRL:0x13]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_LDT_CFG1:0x14]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_LDT_CFG2:0x15]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_LDT_CFG3:0x16]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_LDT_CTRL:0x17]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_MEMORY0:0x18]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [M_MEMORY1:0x19]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [FS_WDW_DURATION:0x0b]R:0xd08b; CRC[MOSI:0x00; MISO:0x00]
FS26 [FS_NOT_WDW_DURATION:0x0c]R:0x2144; CRC[MOSI:0x00; MISO:0x00]
FS26 [FS_WD_TOKEN:0x0e]R:0x5ab2; CRC[MOSI:0x00; MISO:0x00]
FS26 [FS_ABIST_ON_DEMAND:0x0f]R:0x0040; CRC[MOSI:0x00; MISO:0x00]
FS26 [FS_SAFE_IOS_2:0x13]R:0x035f; CRC[MOSI:0x00; MISO:0x00]
FS26 [FS_LP_REQ:0x18]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
FS26 [FS_LDT_LPSEL:0x19]R:0x0000; CRC[MOSI:0x00; MISO:0x00]
I am attaching the waveform when an issue occurs.
Blue VSUP / Red VBOS / Green RSTB / Yellow VDIG
Blue VSUP / Red VPre / Green Vcore / Yellow RSTB
タグ(1)
854件の閲覧回数
db16122
Please refer to PMIC initiailization process for debug. AN13431
NXP PMIC solution for TI TMS570 series MCU should be helpful
%3CLINGO-SUB%20id%3D%22lingo-sub-2396817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFS26%20LDO%20%E7%99%BA%E8%A1%8C%E7%B5%82%E4%BA%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396817%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFFS26%E3%81%A8S32K358%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFFS26%E3%81%AEVLDO2%E3%82%92MCU%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81FS26%E3%81%AEVLDO1%E3%82%92CAN%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMCU%E3%81%8CCAN%E9%80%9A%E4%BF%A1%E7%8A%B6%E6%85%8B%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%A8%E3%80%81FS26%E3%81%AEVLDO%E3%81%AF%E3%82%AA%E3%83%95%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81MCU%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%8C%E9%81%AE%E6%96%AD%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%88%E3%81%93%E3%82%8C%E3%81%AF%E3%83%A9%E3%83%B3%E3%83%80%E3%83%A0%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E3%81%8A%E3%82%88%E3%81%9D1%EF%BD%9E8%E6%99%82%E9%96%93%E3%81%94%E3%81%A8%E3%81%AB%E8%B5%B7%E3%81%93%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%EF%BC%89%3C%2FP%3E%3CP%3EVLDO%E3%81%AF%E3%80%81FS26%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%8C%E9%81%AE%E6%96%AD%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E5%BE%A9%E6%97%A7%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%81%AB%E3%81%AE%E3%81%BF%E5%BE%A9%E6%97%A7%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E5%8D%98%E4%B8%80%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A0%E3%81%91%E3%81%A7%E3%81%AA%E3%81%8F%E3%80%81CAN%E9%80%9A%E4%BF%A1%E3%81%8C%E9%80%B2%E8%A1%8C%E4%B8%AD%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E7%99%BA%E7%94%9F%E6%99%82%E3%81%AE%E7%8A%B6%E6%B3%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EVpre%206V%20O%3C%2FP%3E%3CP%3EVDIG%201.6VO%3C%2FP%3E%3CP%3EVBOS%205V%20O%3C%2FP%3E%3CP%3EVLDO2%20X%3C%2FP%3E%3CP%3EVLDO1%20X%3C%2FP%3E%3CP%3EVCORE%20X%3C%2FP%3E%3CP%3EOTP%E3%81%AB%E3%82%88%E3%82%8BDFS%E3%81%AF%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EFS26%E3%81%AE%E7%8F%BE%E7%8A%B6%E3%81%A8%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS26%20LDO%20Off%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20data-unlink%3D%22true%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CSPAN%20class%3D%22UserName%20lia-user-name%20lia-user-rank-Contributor-IV%20lia-component-message-view-widget-author-username%22%3E%3CSPAN%20class%3D%22%22%3Ekjy106906%E3%81%95%E3%82%93%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%89%E3%83%83%E3%82%B0%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%80%A4%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EFS_STATES%3C%2FLI%3E%0A%3CLI%3EFS_GRL_FLAGS%3C%2FLI%3E%0A%3CLI%3EFS_OVUV_REG_STATUS%3C%2FLI%3E%0A%3CLI%3EM_REG_FLG%3C%2FLI%3E%0A%3CLI%3E%E9%9A%9C%E5%AE%B3%E7%99%BA%E7%94%9F%E7%9B%B4%E5%BE%8C%E3%81%ABM_STATUS%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EFS26%E3%81%ABUV%E3%83%95%E3%83%A9%E3%82%B0%E3%82%84OV%E3%83%95%E3%83%A9%E3%82%B0%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEM_STATUS%E3%82%82%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E4%BB%96%E3%81%AB%E4%BD%95%E3%81%8B%E3%81%94%E4%B8%8D%E6%98%8E%E3%81%AA%E7%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%8A%E6%B0%97%E8%BB%BD%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%B9%B8%E9%81%8B%E3%82%92%E7%A5%88%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2397302%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS26%20LDO%20Off%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2397302%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242156%22%20target%3D%22_blank%22%3E%40RafaR%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81MCU%E3%81%AFSBC%E3%81%8B%E3%82%89%E9%9B%BB%E5%8A%9B%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81VLDO%E3%81%8C%E3%82%AA%E3%83%95%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E9%80%9A%E4%BF%A1%E3%81%AF%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EMCU%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E5%9F%BA%E6%9D%BF%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%88%87%E3%81%A3%E3%81%A6%E5%86%8D%E4%BE%9B%E7%B5%A6%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%9B%A3%E8%A6%96%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AF%E7%84%A1%E9%99%90%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS26%20LDO%20Off%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81kjy106906%E3%81%95%E3%82%93%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%EF%BC%81%3C%2FP%3E%0A%3CP%3EFS26%E3%81%AE%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%82%A8%E3%83%B3%E3%83%89%E3%81%AF%E3%81%BE%E3%81%A0%E9%9B%BB%E6%BA%90%E3%81%8C%E4%BE%9B%E7%B5%A6%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E9%9B%BB%E5%8A%9B%E3%82%92%E4%BE%9B%E7%B5%A6%E3%81%99%E3%82%8B%E5%86%85%E9%83%A8%E9%9B%BB%E6%BA%90%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AF%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E8%AA%AC%E6%98%8E%E3%81%AE%E4%B8%80%E3%81%A4%E3%81%AF%E3%80%81%E7%9B%A3%E8%A6%96%E5%AF%BE%E8%B1%A1%E3%81%AE%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%EF%BC%88VCORE%E3%80%81VLDO1%E3%80%81VLDO2%EF%BC%89%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AB%E9%9A%9C%E5%AE%B3%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E5%8F%8D%E5%BF%9C%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AE%E5%87%BA%E5%8A%9B%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E3%81%A8%E3%81%84%E3%81%86%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82FS26%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E6%95%85%E9%9A%9C%E5%BE%8C%E3%82%82%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E6%95%85%E9%9A%9C%E5%8F%8D%E5%BF%9C%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AF%E7%84%A1%E5%8A%B9%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E4%BB%96%E3%81%AB%E4%BD%95%E3%81%8B%E3%81%94%E4%B8%8D%E6%98%8E%E3%81%AA%E7%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%8A%E6%B0%97%E8%BB%BD%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%89%AF%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%B9%B8%E9%81%8B%E3%82%92%E7%A5%88%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS26%20LDO%20Off%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242156%22%20target%3D%22_blank%22%3E%40RafaR%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E9%87%8D%E8%A6%81%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EFS26%E3%81%8C%E7%8F%BE%E5%9C%A8%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81%E3%81%AA%E3%81%9C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E3%81%AE%E3%81%8B%E3%82%92%E6%AD%A3%E7%A2%BA%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%9F%E9%9A%9B%E3%80%81%E5%A4%96%E9%83%A8%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EFS26%20%5BFS_STATES%3A0x17%5DR%3A0x0009%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_MIRRORCMD%3A0x1c%5DW%3A0x001d%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_MIRRORDATA%3A0x1d%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BID_VOTP%3A0x1D%5DR%3A0x00%3CBR%20%2F%3E%20FS26%20%5BFS_WDW_DURATION%3A0x0b%5DW%3A0xd08b%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_NOT_WDW_DURATION%3A0x0c%5DW%3A0x2f74%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_VSUP_FLG%3A0x07%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_VSUP_MSK%3A0x08%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_REG_FLG%3A0x05%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_REG_MSK%3A0x06%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_TSD_FLG%3A0x03%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_TSD_MSK%3A0x04%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_WIO_FLG%3A0x09%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_WIO_MSK%3A0x0a%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_STATUS%3A0x02%5DR%3A0x5020%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_COM_FLG%3A0x0b%5DR%3A0x0005%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_COM_MSK%3A0x0c%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_OVUV_REG_STATUS%3A0x10%5DR%3A0x1544%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_INTB_MASK%3A0x16%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_DIAG_SAFETY1%3A0x14%5DR%3A0x03c3%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_DIAG_SAFETY2%3A0x15%5DR%3A0x0010%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_SAFE_IOS_1%3A0x12%5DR%3A0xf000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_STATES%3A0x17%5DR%3A0x0009%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_GRL_FLAGS%3A0x00%5DR%3A0x5000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_DEVICEID%3A0x00%5DR%3A0x65d8%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_PROGID%3A0x01%5DR%3A0x0105%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_STATUS%3A0x02%5DR%3A0x5020%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_TSD_FLG%3A0x03%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_TSD_MSK%3A0x04%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_REG_FLG%3A0x05%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_REG_MSK%3A0x06%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_VSUP_FLG%3A0x07%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_VSUP_MSK%3A0x08%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_WIO_FLG%3A0x09%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_WIO_MSK%3A0x0a%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_COM_FLG%3A0x0b%5DR%3A0x0005%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_COM_MSK%3A0x0c%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_SYS_CFG%3A0x0d%5DR%3A0x0001%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_TSD_CFG%3A0x0e%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_REG_CFG%3A0x0f%5DR%3A0x0002%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_WIO_CFG%3A0x10%5DR%3A0x0202%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_REG_CTRL1%3A0x11%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_AMUX_CTRL%3A0x13%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_LDT_CFG1%3A0x14%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_LDT_CFG2%3A0x15%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_LDT_CFG3%3A0x16%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_LDT_CTRL%3A0x17%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_MEMORY0%3A0x18%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BM_MEMORY1%3A0x19%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_GRL_FLAGS%3A0x00%5DR%3A0x5000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_WDW_DURATION%3A0x0b%5DR%3A0xd08b%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_NOT_WDW_DURATION%3A0x0c%5DR%3A0x2144%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_WD_TOKEN%3A0x0e%5DR%3A0x5ab2%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_ABIST_ON_DEMAND%3A0x0f%5DR%3A0x0040%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_OVUV_REG_STATUS%3A0x10%5DR%3A0x1544%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_SAFE_IOS_1%3A0x12%5DR%3A0xf000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_SAFE_IOS_2%3A0x13%5DR%3A0x035f%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_DIAG_SAFETY1%3A0x14%5DR%3A0x03c3%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_DIAG_SAFETY2%3A0x15%5DR%3A0x0010%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_INTB_MASK%3A0x16%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_STATES%3A0x17%5DR%3A0x0009%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_LP_REQ%3A0x18%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3CBR%20%2F%3E%20FS26%20%5BFS_LDT_LPSEL%3A0x19%5DR%3A0x0000%3B%20CRC%5BMOSI%3A0x00%3B%20MISO%3A0x00%5D%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E7%99%BA%E7%94%9F%E6%99%82%E3%81%AE%E6%B3%A2%E5%BD%A2%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kjy106906_0-1785205262839.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kjy106906_0-1785205262839.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kjy106906_0-1785205262839.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393288i0BFA64634580AD11%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kjy106906_0-1785205262839.png%22%20alt%3D%22kjy106906_0-1785205262839.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%9D%92%EF%BC%9AVSUP%20%2F%20%E8%B5%A4%EF%BC%9AVBOS%20%2F%20%E7%B7%91%EF%BC%9ARSTB%20%2F%20%E9%BB%84%EF%BC%9AVDIG%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22kjy106906_1-1785205354126.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kjy106906_1-1785205354126.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kjy106906_1-1785205354126.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393289i860988FA7CE317B1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22kjy106906_1-1785205354126.png%22%20alt%3D%22kjy106906_1-1785205354126.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E9%9D%92%E8%89%B2%20VSUP%20%2F%20%E8%B5%A4%E8%89%B2%20VPre%20%2F%20%E7%B7%91%E8%89%B2%20Vcore%20%2F%20%E9%BB%84%E8%89%B2%20RSTB%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS26%20LDO%20Off%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22db16122_0-1785211448726.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22db16122_0-1785211448726.png%22%20style%3D%22width%3A%20260px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393302iE766274E84679D69%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22db16122_0-1785211448726.png%22%20alt%3D%22db16122_0-1785211448726.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81PMIC%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82AN13431%3CBR%20%2F%3ETI%20TMS570%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BAMCU%E5%90%91%E3%81%91%E3%81%AENXP%20PMIC%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E
