ads model
ads model
hadi3000
hi
i downloaded ads model forMRFE6VS25NR1 but it did not work due to this error
Model `FSL_MRFE6VS25N_FET2.FET2M1' (defined in file 'C:/Users/hadih/OneDrive/Desktop/NXP/MRFE6VS25N_Level1_Rev1_DK//circuit/models/fsl_MRFE6VS25N_pkg_netlists.net' around line 31): `FSLRFPK_FET2_v1' is an undefined primitive device.
is it broken?
this is the element page
https://www.nxp.com/products/radio-frequency-rf/legacy-rf/legacy-rf-power/1-8-2000-mhz-25-w-50-v-wid...
RafaR
Hello hadi3000
Good day!
This appears to be you not installing  RF High power Model Kit before using single product model.
https://www.nxp.com/products/rf/rf-high-power-models/models-for-ads-keysight-advanced-design-system:...
Our models are two part :
    Product Model Design Kit
Both parts are required to simulate device.
If you already installed the High power Model Kit, please check the TroubleShootingADSInstallation Problems and verify that the FSL_TECH_INCLUDE element exists in the top-level circuit.
You can also find the section on common installation errors here.
https://www.nxp.com/docs/en/companyinformation/OVERVIEW_MDL_ADS_DESIGN_KIT.pdf
I hope this information has helped you, please let me know if you need help with anything else.
Have a great day and best of luck.
%3CLINGO-SUB%20id%3D%22lingo-sub-2399619%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eads%20model%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399619%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehi%26nbsp%3B%3C%2FP%3E%3CP%3Ei%20downloaded%20ads%20model%20forMRFE6VS25NR1%20but%20it%20did%20not%20work%20due%20to%20this%20error%3C%2FP%3E%3CP%3EModel%20%60FSL_MRFE6VS25N_FET2.FET2M1'%20(defined%20in%20file%20'C%3A%2FUsers%2Fhadih%2FOneDrive%2FDesktop%2FNXP%2FMRFE6VS25N_Level1_Rev1_DK%2F%2Fcircuit%2Fmodels%2Ffsl_MRFE6VS25N_pkg_netlists.net'%20around%20line%2031)%3A%20%60FSLRFPK_FET2_v1'%20is%20an%20undefined%20primitive%20device.%3C%2FP%3E%3CP%3Eis%20it%20broken%3F%3C%2FP%3E%3CP%3Ethis%20is%20the%20element%20page%3C%2FP%3E%3CP%3E%3CA%20title%3D%22MRFE6VS25NR1%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fradio-frequency-rf%2Flegacy-rf%2Flegacy-rf-power%2F1-8-2000-mhz-25-w-50-v-wideband-rf-power-ldmos-transistors%3AMRFE6VS25N%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fradio-frequency-rf%2Flegacy-rf%2Flegacy-rf-power%2F1-8-2000-mhz-25-w-50-v-wideband-rf-power-ldmos-transistors%3AMRFE6VS25N%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20ads%20model%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20hadi3000%3C%2FP%3E%0A%3CP%3EGood%20day!%3C%2FP%3E%0A%3CP%3EThis%20appears%20to%20be%20you%20not%20installing%20%26nbsp%3BRF%20High%20power%20Model%20Kit%20before%20using%20single%20product%20model.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Frf%2Frf-high-power-models%2Fmodels-for-ads-keysight-advanced-design-system%3ARF_HIGH_POWER_MODELS_KEYSIGHT%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Frf%2Frf-high-power-models%2Fmodels-for-ads-keysight-advanced-design-system%3ARF_HIGH_POWER_MODELS_KEYSIGHT%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EOur%20models%20are%20two%20part%20%3A%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%20%26nbsp%3B%20RF%20High%20power%20Model%20Kit%3CBR%20%2F%3E%26nbsp%3B%20%26nbsp%3B%20Product%20Model%20Design%20Kit%3C%2FP%3E%0A%3CP%3EBoth%20parts%20are%20required%20to%20simulate%20device.%3C%2FP%3E%0A%3CP%3EIf%20you%20already%20installed%20the%20High%20power%20Model%20Kit%2C%20please%20check%20the%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fsupporting-information%2FTROUBLESHOOTING_ADS_INSTALL_1001.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETroubleShootingADSInstallation%20Problems%3C%2FA%3E%20and%20verify%20that%20the%20FSL_TECH_INCLUDE%20element%20exists%20in%20the%20top-level%20circuit.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EYou%20can%20also%20find%20the%20section%20on%20common%20installation%20errors%20here.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fcompanyinformation%2FOVERVIEW_MDL_ADS_DESIGN_KIT.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fcompanyinformation%2FOVERVIEW_MDL_ADS_DESIGN_KIT.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EI%20hope%20this%20information%20has%20helped%20you%2C%20please%20let%20me%20know%20if%20you%20need%20help%20with%20anything%20else.%3C%2FP%3E%0A%3CP%3EHave%20a%20great%20day%20and%20best%20of%20luck.%3C%2FP%3E%3C%2FLINGO-BODY%3E
