FRDM33771CSPIEVB
FRDM33771CSPIEVB
harish89
In the EVB MC33771C with SPI Interface, why 3k and 0.047uF, 2k and 0.1uF LPF has been used in the cell voltage measurement section of the AFE.
guoweisun
No app note for explain this, you can select the filter parameters by doing same test.
harish89
Can we change those values or is it fixed to be used with the AFE.
guoweisun
Yes I think you can do that!
harish89
So is there any application note just to see what values we can give to LPF at what frequency.
guoweisun
guoweisun
Just for filter out the high frequency noise inside of the battery line.
