FRDM IMX93 GoPoint Demo
hoanghan
I got an issue when run dms demo with usb camera. When i use this command
gst-launch-1.0 -v v4l2src device=/dev/video0 ! "video/x-raw,format=YUY2,width=640,height=480" ! queue ! waylandsink window-width=640 window-height=480
to check the camera it works fine. However when run the dms it shows the drivers not found ??
Any ideas for this issues ??
Thanks all
Chavira
HI @hoanghan!
Are you selecting the correct device?
The board should be connected to internet to download the proper model.
Best Regards!
Chavira
Chavira
HI @hoanghan!
Best Regards!
Chavira
hoanghan
Yes the model has been dowloaded correctly and i have already check the device. Some ideas told that the usb camera not fit ?? Is that true ??
R_S002
hi are you available here?
%3CLINGO-SUB%20id%3D%22lingo-sub-2078111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM%20IMX93%20GoPoint%20Demo%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20got%20an%20issue%20when%20run%20dms%20demo%20with%20usb%20camera.%20When%20i%20use%20this%20command%3C%2FP%3E%3CP%3Egst-launch-1.0%20-v%20v4l2src%20device%3D%2Fdev%2Fvideo0%20!%20%22video%2Fx-raw%2Cformat%3DYUY2%2Cwidth%3D640%2Cheight%3D480%22%20!%20queue%20!%20waylandsink%20window-width%3D640%20window-height%3D480%3C%2FP%3E%3CP%3Eto%20check%20the%20camera%20it%20works%20fine.%20However%20when%20run%20the%20dms%20it%20shows%20the%20drivers%20not%20found%20%3F%3F%3C%2FP%3E%3CP%3EAny%20ideas%20for%20this%20issues%20%3F%3F%26nbsp%3B%3C%2FP%3E%3CP%3EThanks%20all%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2078786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20FRDM%20IMX93%20GoPoint%20Demo%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EYes%20the%20model%20has%20been%20dowloaded%20correctly%20and%20i%20have%20already%20check%20the%20device.%20Some%20ideas%20told%20that%20the%20usb%20camera%20not%20fit%20%3F%3F%20Is%20that%20true%20%3F%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2078582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20FRDM%20IMX93%20GoPoint%20Demo%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F249180%22%20target%3D%22_blank%22%3E%40hoanghan%3C%2FA%3E!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EAre%20you%20selecting%20the%20correct%20device%3F%3C%2FP%3E%0A%3CP%3EThe%20board%20should%20be%20connected%20to%20internet%20to%20download%20the%20proper%20model.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards!%3C%2FP%3E%0A%3CP%3EChavira%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2256489%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM%20IMX93%20GoPoint%20Demo%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256489%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ehi%20are%20you%20available%20here%3F%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
