Does CBTL06GP213EE Support eDP singnal Switch?
2,013 次查看
Makabaka
Dears:
Does CBTL06GP213EE support EDP signal switching?
I have used as DP signal switching before, but now I need to switch EDP signal.
Looking forward to your reply
2,002 次查看
TomasVaverka
Dear Ziv,
eDP use the same electrical signaling as DP for main data lanes.
So, yes, the CBTL06GP213 can support eDP. If you need a higher bandwidth, the CBTL06DP213 is a better option.
Tomas
2,003 次查看
TomasVaverka
Dear Ziv,
Tomas
1,998 次查看
Makabaka
Hi Tomas:
Yes, I've read the CBTL06DP213's specifications. It support  DP V1.3 and 8.1GBIT/S.
Thanks for your reply.
