Display Controller Integration Manual
guojunqiang
Dears,
Could you kindly tell that whether display controller which vendor is VIVANTE has used on NXP imx7d platform ?
Looking forward to receiving a reply.
Thank you.
guojunqiang
Dears,
I have one issue now ,
 fb0 node open fail when I try to open this node by "fp = open ("/dev/graphics/fb0",O_RDWR);" in one seperate test code.
same time,I have modified the mxsfb.c to fit with my lcdc.
Could you please help find the possible fail case ?
Thank you.
Bio_TICFSL
Hello keil,
The MX7D does not have GPU, The i,MX7ULP has GPU for 3D and 2D composition but this is pre-liminar.
Regard
guojunqiang
Dears,
Thanks for your response.
Could you please show which display controllers are supported on i.mx7d platform ?
I am considering to bringup lcd panels with proper supported display controllers on this platform.
Thanks.
Bio_TICFSL
It has LCD interface for 24 bit parallel RGB or 2 lane of MIPI/ DSI.
