DP - HDMI Conversion w/o DP++
2,785 次查看
roshandsouza
Dear Team,
I am looking at PTN3366BSMP for DP-HDMI conversion. From the datasheet, I understand that it is focused on passive adapters. My source doesn't support DP++. In fact, I would be using a source that has eDP/DP output; wherein the DP O/P doesn't even support audio. Will this IC work for my application? Can you suggest a better one if not? How can I get reference schematics for the same? Does this IC provide protocol translation or only voltage translation?
Source supports DP 1.2a, eDP 1.4
#HDMI #DP-HDMI #DisplayBridge #PassiveAdapter #ActiveAdapter
3 回复数
2,676 次查看
roshandsouza
Hello Sun,
Yes, I would need a DP-HDMI conversion/bridge. As mentioned above, my DP source supports DP 1.2a
2,676 次查看
guoweisun
Unfortunately we have the DP-HDMI bridge chips only support DPV1.1 not DP1.2a.
2,676 次查看
guoweisun
Do you need DP-HDMI conversion? what's your DP version supported?
