DAB Decode on chip
DAB Decode on chip
1,414件の閲覧回数
khushboosharma
    I am looking for a solution for AM,FM and DAB receiver with DAB demodulation functionality to be present in hardware.
I found one possible solution SAF360x, so went through its data sheet  "http://www.nxp.com/documents/short_data_sheet/SAF360X_FAM_SDS.pdf " and schematics to understand the flow.
Logically on receiving DAB input from antenna it will be demodulated and decoded in SAF360XX chip and it should output both Digital audio and Digital data
For Digital audio data that was part of DAB data i can see Digital Audio IO interfaces,
but not able to locate the interface that will be used to output Digital Data (i.e. DAB data services like HTML pages, videos, images) received though DAB.
Any help will be appreciated.
0 返答(返信)
