Custom bootloader jump to Application
wasimarfath
I am using NXP iMXRT1020 , I tried programming the same LED code blinking for 1ms/2ms at 2 different address locations and branching from one code to another. This is working as it holds the same peripheral configuration. But it is not working if one address holds LED example code and another address is placed with UART example code. Please help me on this issue.
