Compile Pascal source code for MPC5554
22,485 次查看
schlosserolivie
Does someone know a compiler for Pascal source code that can be used on MPC5554 ?
Olivier
标记 (3)
2,462 次查看
TICS_Fiona
The CodeWarrior for Qorivva only supports C and assembly code, and does not support Pascal.
I am unaware of a tool that supports Pascal.
In the last page of the below document,  there is a list of our vendor, you may contact them for Pascal support:
Fiona Kuang
Technical Information & Commercial Support
2,463 次查看
TICS_Fiona
Fiona Kuang
