Code, Connections, NXP with WS2812
Kishore02
I am new to NXP microcontrollers and would like to interface a 16-pixel WS2812B RGB LED strip.
Which NXP development board would you recommend for this project?
I would also appreciate any example projects, SDK examples, or documentation for controlling WS2812B LEDs.
Thank you.
Alondra
Thank you for your interest in NXP products!
The FRDM-MCXA366 is an ideal board for your project.
NXP provides a dedicated, beginner-friendly application note that specifically demonstrates how to control WS2812B LEDs using the MCX A366. The document includes board recommendations, hardware connections, source code, and step-by-step setup instructions.
AN14980 – Emulating the WS2812 Bus with FlexIO on MCX A366
This application note explains in detail how to use the FlexIO module on the MCX A366 to emulate the WS2812 communication protocol and drive WS2812B LEDs.
This should provide everything you need to get started with your design.
Please let me know further questions
Alondra
Kishore02
Hello Alondra,
Thank you for the suggestion! Our design is still in the evaluation phase.
Before we decide on a board, I wanted to check if the LPC5514JBD64E can also support WS2812 LEDs?
Kishore
%3CLINGO-SUB%20id%3D%22lingo-sub-2400888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECode%2C%20Connections%2C%20NXP%20with%20WS2812%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2400888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3EI%20am%20new%20to%20NXP%20microcontrollers%20and%20would%20like%20to%20interface%20a%2016-pixel%20WS2812B%20RGB%20LED%20strip.%3CBR%20%2F%3EWhich%20NXP%20development%20board%20would%20you%20recommend%20for%20this%20project%3F%3CBR%20%2F%3EI%20would%20also%20appreciate%20any%20example%20projects%2C%20SDK%20examples%2C%20or%20documentation%20for%20controlling%20WS2812B%20LEDs.%3CBR%20%2F%3EThank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2400956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Code%2C%20Connections%2C%20NXP%20with%20WS2812%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2400956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%0A%3CP%3EThank%20you%20for%20your%20interest%20in%20NXP%20products!%3C%2FP%3E%0A%3CP%3EThe%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FFRDM-MCXA366%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSTRONG%3EFRDM-MCXA366%3C%2FSTRONG%3E%3C%2FA%3E%20is%20an%20ideal%20board%20for%20your%20project.%3C%2FP%3E%0A%3CP%3ENXP%20provides%20a%20dedicated%2C%20beginner-friendly%20application%20note%20that%20specifically%20demonstrates%20how%20to%20control%20%3CSTRONG%3EWS2812B%20LEDs%3C%2FSTRONG%3E%20using%20the%20MCX%20A366.%20The%20document%20includes%20board%20recommendations%2C%20hardware%20connections%2C%20source%20code%2C%20and%20step-by-step%20setup%20instructions.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14980.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSTRONG%3EAN14980%20%E2%80%93%20Emulating%20the%20WS2812%20Bus%20with%20FlexIO%20on%20MCX%20A366%3C%2FSTRONG%3E%3C%2FA%3E%3CBR%20%2F%3EThis%20application%20note%20explains%20in%20detail%20how%20to%20use%20the%20FlexIO%20module%20on%20the%20MCX%20A366%20to%20emulate%20the%20WS2812%20communication%20protocol%20and%20drive%20WS2812B%20LEDs.%3C%2FP%3E%0A%3CP%3EThis%20should%20provide%20everything%20you%20need%20to%20get%20started%20with%20your%20design.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EPlease%20let%20me%20know%20further%20questions%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EAlondra%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2401634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Code%2C%20Connections%2C%20NXP%20with%20WS2812%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2401634%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Alondra%2C%3C%2FP%3E%3CP%3EThank%20you%20for%20the%20suggestion!%20Our%20design%20is%20still%20in%20the%20evaluation%20phase.%3C%2FP%3E%3CP%3EBefore%20we%20decide%20on%20a%20board%2C%20I%20wanted%20to%20check%20if%20the%20LPC5514JBD64E%20can%20also%20support%20WS2812%20LEDs%3F%3C%2FP%3E%3CP%3EBest%20regards%2C%3CBR%20%2F%3EKishore%3C%2FP%3E%3C%2FLINGO-BODY%3E
