CRLC663 EEPROM initialize soultion
1,075 次查看
dwdwsd2124
Hello, I want to ask you a question. I want to initialize the data written incorrectly in the EEPROM to the default default default value. (clrc663 datasheet 19.2)
The Cockpit Tool is currently not available for CLC663.
I need help with the source code that I can refer to.
1,054 次查看
KaiLi
Hello @dwdwsd2124
Thanks for contacting us and interested in the NXP products.
Based on your description there is a software package (SW6693) that you can refer to.
You can download from CLRC663 plus family | Low-Power NFC Frontends | NXP Semiconductors
To update this case, you may reply by email.
To provide confidential information or attachments, you may add that online.
Please login to our NXP technical support portal:
https://support.nxp.com/s/case/5002p00002qYm8DAAS
The portal allows access to the full details of the case, including the previous communication.
Thank you for your interest in NXP Semiconductor products and for the opportunity to serve you.
