Bootloader code for the MPC5604
4,965 次查看
bryanwade
I'm just getting started Freescale products so please forgive me if I'm missing something obvious. Is there any example bootloader code available for the the MPC5604P or similar?
Ultimately I plan to update application code via Flexray, but a UART or CAN example would be a good starting point.
Thanks.
3,355 次查看
lukaszadrapa
attached you will find draft of my application note. Hope it will be useful.
Lukas
3,355 次查看
Stevanatto
I will use this code too. Thank you.
3,355 次查看
gangzhou
Tkank you for sharing the bootloader code.I want to write a bootloader for MPC5644A according to your code.But,the program can not run properly.And ,stop at function EXCEP_DefaultExceptionHandler().Whether I must write some command files in my project like
"t32" file  in your project or not? How should I do?
