BSP for MPC8313E-RDB
2,756 次查看
saso_kavcic
I have an MPC8313E-RDB, the version is REVA4. Does anyone know if I can use the latest BSP -
MPC8313E_RDB_K26_20081226-LTIB.iso. This BSP is supposed to support REVC version of the board. If I have an older one, will this still work or do I have to use the older BSP CD.
Best Regards, Saso
标记 (1)
2,119 次查看
TedMarshall
I don't believe that the current BSP will run on the older board, right off the disk.  Freescale has a pretty-new App Note, AP3947 with instructions for doing this but I've only briefly skimmed it and I don't know how hard it is to implement.
You best bet may be to email Freescale support and ask for a link to the older BSP.  Unfortunately, they've pulled down the links on the website.
2,120 次查看
TedMarshall
2,119 次查看
saso_kavcic
Thank you for the info.
