Is there a way to re-access the SDK Wizard after the initial time you configure a project? Basically, at that point it lets you select which drivers you want and includes them in a drivers folder. However, as time went on I found that I need to add more drivers than I originally planned for. How do I select additional drivers to incorporate from the SDK after initial project creation?
Solved! Go to Solution.
Hello ,
You can use Manage SDK components to add SDK drivers:
Alice
Hello ,
Alice
Yes thanks i got it.
