A1007 Secure Authenticator IC
2,785 次查看
Andrew8
I would like to know the details of OSC in the block diagram among the data sheet of A1007 Secure Authenticator IC.
EMC test (conformity assessment) is required when OSC checks more than 9KHz.
I want to provide details and avoid EMC testing.
Can you help?
2,750 次查看
Kan_Li
Hi @Andrew8 ,
I just replied you in the SFDC, and we may continue the discussion there.
Thanks for your patience!
Kan
