UWB
UWB
1,868 次查看
MohamedKadry
hello ALL,
can I flash my app or customer app into the NCJ29D5 board or I have to have another ECU communicating with the NCJ29D5, And if that is possible is there a SW package I can extract into MCUXpressoIDE  Which provides the sw stack provided from your side so i can integrate my app with,
this part is not clear in the files the quick guide start guide for NCJ29D5 mentions That I can have my own Ranging app in the ecu itself but the files do not mention how to do so, the available sw is only .bin or .elf .
is this product only intended to act as a sensor?
and if so can i use aurix board instead of  S32K144EVB To interface with NCJ29D5 and if that is possible is there a secure session i have to unlock to use it with an other Board than S32K144EVB
1,816 次查看
Ricardo_Zamora
Hope you are doing well. Sorry for the inconvenience this might cause you but as the information of this product it's under NDA (Non-Disclosure Agreement) the information it's not public, this is not a secure channel to share any information of this device and I do not have the data as well for the same reason.
For more information about the chip could you please contact one of our distributors available in the Distributor Network|NXP? Or if you have a direct contact who helped you with information about this product in a first place, please communicate with him/her.
Ricardo
