UWB Propriety Calibration
2,097 次查看
Mimii3
Hello !
i’m working with sr150 , i m trying to send a UCI to configure the calibration parameters manually
ext_uci_msg_set_calibration 0x11
ext_uci_msg_get_calibration 0x12
Uci_calib from 0x00 to 0x09
i didn t found how to acces to the 9 parameters !
the composition of the frame !
thanks for your help
2,071 次查看
Ricardo_Zamora
Hope you are doing well. Are you working with one of these Development Kits/Modules (UWB Developer Resources)?
If that is the case, please redirect your questions to the respective Module Maker. They will be able to help you supporting their kit/module.
Ricardo
