Reg: UWB Related Queries
2,774 次查看
Rishikesh1
1. At what frequency do we have to change the battery cells in UWB Tag?
2. What is the range of UWB tags indoors?
3. How many antennas will be required for a 5000 sq feet area? (In the NXP demo video we saw 4 antennas are required for 100 sq feet. Out of the 4 antennae, one is acting as a master whereas the other 3 is acting as a slave).
4. How many slaves communicate with one master?
5. Can we transmit data using UWB? If yes means, how?
6. What will be the Cost of the UWB tag and UWB antenna?
2,751 次查看
stephanie_m
As some of the information of UWB is still under NDA and can't be disclosed in a public way such as this community  and in order to keep all the information in a single support line, is there a way that you can help using the internal case number you already submitted?
2,741 次查看
Rishikesh1
I have already submitted the ticket.
Case Number: 00481460
FYKI,
Rishikesh G
标记 (1)
2,733 次查看
stephanie_m
Thank you for the information , the case will be updated as soon as possible .
regards
