Question regarding the DTM API
Takuya_Tanaka
I would like to use the Hci_LeEnhancedReceiverTest and Hci_LeEnhancedTransmitterTest functions declared in SDK_26_03_00_KW47-EVK\mcuxsdk\middleware\wireless\bluetooth\host\interface\hci_interface.h from MCUXpresso SDK v26.03.00 on a KW47 MCU. Are these commands supported?
Additional information:
  • The declarations for these two functions are guarded by: #if defined(gHciCompleteHciCmdSupport_d) && (gHciCompleteHciCmdSupport_d == TRUE) When I enabled that macro, the project failed to build with errors.
  • I searched the SDK for Hci_LeEnhancedReceiverTest and Hci_LeEnhancedTransmitterTest and only found the declarations in hci_interface.h; I could not find any implementation or other references.
Could someone please confirm whether these DTM commands are supported for KW47 in this SDK release, and advise how to enable or obtain the required implementation (or point me to any necessary firmware/library/configuration)? Any guidance would be greatly appreciated.
Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-2410276%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EQuestion%20regarding%20the%20DTM%20API%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410276%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3EHello%2C%3C%2FP%3E%3CP%20class%3D%22%22%3EI%20would%20like%20to%20use%20the%20Hci_LeEnhancedReceiverTest%20and%20Hci_LeEnhancedTransmitterTest%20functions%20declared%20in%20SDK_26_03_00_KW47-EVK%5Cmcuxsdk%5Cmiddleware%5Cwireless%5Cbluetooth%5Chost%5Cinterface%5Chci_interface.h%20from%20MCUXpresso%20SDK%20v26.03.00%20on%20a%20KW47%20MCU.%20Are%20these%20commands%20supported%3F%3C%2FP%3E%3CP%20class%3D%22%22%3EAdditional%20information%3A%3C%2FP%3E%3CUL%3E%3CLI%3EThe%20declarations%20for%20these%20two%20functions%20are%20guarded%20by%3A%20%23if%20defined(gHciCompleteHciCmdSupport_d)%20%26amp%3B%26amp%3B%20(gHciCompleteHciCmdSupport_d%20%3D%3D%20TRUE)%20When%20I%20enabled%20that%20macro%2C%20the%20project%20failed%20to%20build%20with%20errors.%3C%2FLI%3E%3CLI%3EI%20searched%20the%20SDK%20for%20Hci_LeEnhancedReceiverTest%20and%20Hci_LeEnhancedTransmitterTest%20and%20only%20found%20the%20declarations%20in%20hci_interface.h%3B%20I%20could%20not%20find%20any%20implementation%20or%20other%20references.%3C%2FLI%3E%3C%2FUL%3E%3CP%20class%3D%22%22%3ECould%20someone%20please%20confirm%20whether%20these%20DTM%20commands%20are%20supported%20for%20KW47%20in%20this%20SDK%20release%2C%20and%20advise%20how%20to%20enable%20or%20obtain%20the%20required%20implementation%20(or%20point%20me%20to%20any%20necessary%20firmware%2Flibrary%2Fconfiguration)%3F%20Any%20guidance%20would%20be%20greatly%20appreciated.%3C%2FP%3E%3CP%20class%3D%22%22%3EThank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E
