Precision finding with UWB cost
1,633 次查看
StevieB
in my pursuit to build some IoT devices with UWB technology I’m coming up to a bit of a hurdle for cost. If I understand correctly the UWB precision tracking requires the anchor and the tag. The Anchor seems to be the expensive part which certain iPhones and Samsung phones cover correct? That means if I build the device for tracking I could theoretically just build the tag? Is that correct? Does anyone know what the approximate cost would be to manufacture a very simple tag assuming that the device is as straight forward as an AirTag?
1,594 次查看
Ricardo_Zamora
Hope you are doing well. Sorry for the inconvenience this might cause you but as the information of these products it's under NDA (Non-Disclosure Agreement) the information it's not public.
In case you are looking for information about our UWB products or you are interested in this technology, I would recommend you check these Development Kits and Modules from our Partners (Trimension UWB Partners).
In case you are interested in one of these Kits/Modules, you would need to go directly with them to know the process and the support that they can provide them, as the support path for this technology is through them.
Ricardo
