NXH3675 LC3 codec
NXH3675 LC3 codec
hsuzuki
We would like to use NXH3675 as the just LC3 codec not uses any other BT function.
For decode case, LC3 data is comming from other dvice through the UART and it decoded by the NXH3675 then it output PCM audio through I2S.
For encode case, it opposit way, PCM data is comming from other dvice through the I2S and it encoded by the NXH3675 then it output LC3 data through UART.
Can we realize this scenario by using NXH3675?
If no, could you suggest other NXP device?
H.Suzuki
Ricardo_Zamora
Hope you are doing well. NXH3675 and enablement (documentation, software and boards) are available for select customers with an approved NDA. Could you please contact your local sales representative or a Distributor from the Distributor Network | NXP Semiconductors?
Ricardo
