Windows 7 64 Bit
Windows 7 64 Bit
JosephK
I am running CodeWarrior version 5.1 on a computer running Windows 7 Enterprise 64-Bit. I will be using it to program an SC12C128.
CodeWarrior does not currently support TBDML on the 64 bit edition of Windows 7 because there are no drivers available for the 64 bit edition.
Are there any 64 bit TDML drivers, or any in the works?
Thank you,
Joe
pgo
Senior Contributor V
Dear Joe,
If you have a standand TBDML you can try USBDM-JB16 which may work on them.  However I thought there were problems using the codewarrior software at all on Windows 7-64bit?
http://sourceforge.net/projects/usbdm/files/
Untested combination however CW V5 & Win7-64bit.
bye
