Windows 7 64 Bit
Windows 7 64 Bit
2,017 次查看
JosephK
I am running CodeWarrior version 5.1 on a computer running Windows 7 Enterprise 64-Bit. I will be using it to program an SC12C128.
CodeWarrior does not currently support TBDML on the 64 bit edition of Windows 7 because there are no drivers available for the 64 bit edition.
Are there any 64 bit TDML drivers, or any in the works?
Thank you,
Joe
1,088 次查看
pgo
Senior Contributor V
Dear Joe,
If you have a standand TBDML you can try USBDM-JB16 which may work on them.  However I thought there were problems using the codewarrior software at all on Windows 7-64bit?
http://sourceforge.net/projects/usbdm/files/
Untested combination however CW V5 & Win7-64bit.
bye
