USBDM_JS16
USBDM_JS16
1,448件の閲覧回数
ивандончев
Hi , i am want to build a USBDM JS16
but before i start i have to know a couple of things
can you tell me where should i connect the 6-pin connector from the BDM  on the MC9S08QG4 (HCS08) in order to program and work with the MC9S08QG4 (HCS08)
Thank you in advance !
2 返答(返信)
1,264件の閲覧回数
pgo
Senior Contributor V
If you download the QG8 reference manual you can check out the recommended system connections in section 2.2.
Available here http://cache.freescale.com/files/microcontrollers/doc/data_sheet/MC9S08QG8.pdf?fpsp=1&WT_TYPE=Data%2...
bye
1,264件の閲覧回数
ивандончев
thank you !
i have read the user manual but not in such detail
