I need your help
I need your help
891 次查看
puke7381
Hi, pgo
     I need your help.
     I want JM60 OSBDM - Qorivva MPC55xx/56xx of P&E to transplanting your USBDM 's hardware using the PCB " USBDM_CF_JMxxCLD_V3 ".
    The problem is I don't know when to shut down target VDD, when exiting debug mode.
     The BDM receives what when exit debug mode?
     Can you help me?
     P&E Microcomputer Systems
824 次查看
pgo
Senior Contributor V
I'm unsure what you are doing and what information you are asking. I hope the following is useful.
The target supply control can best be followed by looking at the usbdm API and the usbdm_dll source code.
bye
