How do I re-flash a USBDM
已解决
跳至解决方案
2,362 次查看
juliancox
Contributor V
I have a "dead" JS16CWJ based USBDM. When I plug it in there is no activity on the COM LED and I believe that there is either a hardware fault or the Flash is corrupt. EXACTLY how do I re-flash it? I have another USBDM (JM60). Obviously I cannot use the USBDM app because, according to my computer, the board does not exist. How do I connect the two USBDMs together? I enclose a picture of the faulty board.pastedImage_1.jpg
1 解答
2,180 次查看
juliancox
Contributor V
Since posting this I have been able to re-flash the board and it works with USBDM 4.12, but not with C/W as is the case with my other BDM How do I get tit to work with C/W?
在原帖中查看解决方案
1 回复
2,181 次查看
juliancox
Contributor V
