Model-Based Design Toolbox for S32K14x Automotive MCU 2018.R1
Product Release Announcement
Automotive Microcontrollers and Processors
NXP Model-Based Design Toolbox
for S32K1xx - 2018.R1
Austin, Texas, USA
July 23, 2018
The Automotive Microcontrollers and Processors’ Model-Based Design Tools Team at NXP Semiconductors, is pleased to announce the release of the Model-Based Design Toolbox for S32K1xx 2018.R1. This release supports automatic code generation for S32K1xx peripherals and applications prototyping from MATLAB/Simulink for NXP’s S32K1xx Automotive Microprocessors.
FlexNet Location:
https://nxp.flexnetoperations.com/control/frse/download?element=10221477
Activation link
Technical Support
NXP Model-Based Design Toolbox for S32K1xx issues are tracked through NXP Model-Based Design Tools Community space.
https://community.nxp.com/community/mbdt
Release Content
  • Automatic C code generation based on S32K SDK 2.0.0 RTM drivers from MATLAB® for NXP all S32K14x derivatives:
  • S32K142 MCU Packages with 16/32KB SRAM (*updated)
  • S32K144 MCU Packages with 48/64KB SRAM (*updated)
  • S32K146 MCU Packages with 128KB SRAM (*new)
  • S32K148 MCU Packages with 192/256KB SRAM (*new)
  • Multiple options for packages and clock frequencies are available via Model-Based Design Toolbox S32K Simulink main configuration block
  • New S32K peripheral support added for DMA, RTC, Registers were added to extend the existing toolbox capabilities. The 2018.R1 peripheral coverage for each of the S32K14x derivatives is shown below:
  • Redesigned the FlexTimer configuration block to support additional features for PWM generation and triggering events
  • Added support for System Basis Chip (SBC) UJA116x configuration
  • Redesigned the main Simulink Embedded Target library for supporting future additions of other S32K derivatives and External Devices for S32K products
  • Implement communication port auto discovery to allow easy configuration for downloading the generated code to NXP targets and new Diagnostic options to helps with model creation or migration.
  • 100% S32K supported peripheral coverage with examples. Currently there 115 examples available as part of the toolbox that exercise all the functionalities supported
  • Add support for External Mode that enables Simulink on the host computer to communicate with the deployed model on NXP hardware board during runtime
  • Enable MATLAB code profiler for NXP targets for measuring the function execution time using Processor-in-the-Loop mode
For more details, features and how to use the new functionalities, please refer to the Release Notes document attached.
MATLAB® Integration
The NXP Model-Based Design Toolbox extends the MATLAB® and Simulink® experience by allowing customers to evaluate and use NXP’s S32K1xx MCUs and evaluation boards solutions out-of-the-box with:
  • NXP Support Package for S32K1xx Online Installer Guide Add-on allows users to install NXP solution directly from the Mathwork’s website or directly from MATLAB IDE. The Support Package provide a step-by-step guide for installation and verification.
Target Audience
This release (2018.R1) is intended for technology demonstration, evaluation purposes and prototyping for S32K142, S32K144, S32K146 and S32K148 MCUs and Evaluation Boards
标记 (5)
附件
评论
After pushing "Add" button in addon explorer
I will not go on ahead.
Is there a method to install it other than Addon Explorer?
Hi hayaoki7‌,
Thank you for highlighting this. I'm going to recheck with Mathworks what's happening since that is not normal.
Anyway, please go to directly this link: https://nxp.flexnetoperations.com/control/frse/download?element=10221477 select the NXP Model-Based Design Toolbox for S32K1xx version 2018.R1, make sure you select the checkbox near it and use the "Download Selected Files" button in order to download the file with mltbx extension.
Then, you can follow up the steps shown in the Quick Start Guide manual attached to the main thread.
Hope this helps!
Hi Hayaoki7,  I just tested this and I don't see this issue. Add-on Explorer will contact mathworks.com to get a list of the add-ons, so if the website was temporarily down or  there was an interruption in the connection, this might be the outcome.  Please try this again - and it if fails, please contact MathWorks Technical Support as this is likely a Mathworks issue, not an NXP issue.
Cheers,
-Brian
Hi Hayaoki7,
I did more looking into this (uninstalled and reinstalled fresh) and I can replicate the issue. This looks to be an issue on the MathWorks side (Add-on Explorer isn't handling the MLTBX file properly). It has been internally logged and a developer is looking into fixes. Short term, please use the direct download method Daniel outlined.
Cheers,
-Brian
Hello all,
This has been fixed on the MathWorks side, and I just confirmed that once you click on "add" the installation progresses as expected via Add-on Explorer.
Cheers,
-Brian
I installed and tried everything that appeared directly in the download.
I will try it from now on even with add-ons.
Thank you very much.
Is it possible to use this toolbox without Embedded coder from mathworks ? Only with Matlab coder and Simulink coder ?
No, the Embedded Coder from MathWorks is a pre-requisite for all the other Coders (MATLAB/SIMULINK) that interact with the embedded targets: Embedded Coder - MATLAB & Simulink
%3CLINGO-SUB%20id%3D%22lingo-sub-1121879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%9D%A2%E5%90%91%20S32K14x%20%E6%B1%BD%E8%BD%A6%20MCU%202018.R1%20%E7%9A%84%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22background%3A%20%23003883%3B%20padding%3A%202.0pt%203.0pt%202.0pt%203.0pt%3B%22%20width%3D%22185%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23d1d1d1%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22background%3A%20%23003883%3B%20padding%3A%202.0pt%203.0pt%202.0pt%203.0pt%3B%22%20width%3D%22771%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23d1d1d1%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202.0pt%203.0pt%202.0pt%203.0pt%3B%22%20width%3D%22185%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20171px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66153iAF0FC382572F046B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22background%3A%20white%3B%20padding%3A%202.0pt%203.0pt%202.0pt%203.0pt%3B%22%20width%3D%22771%22%3E%3CP%20style%3D%22margin%3A%200in%200in%200.0001pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2024.0pt%3B%20color%3A%20%233b3838%3B%22%3E%E4%BA%A7%E5%93%81%E5%8F%91%E5%B8%83%E5%85%AC%E5%91%8A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%200.0001pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2018.0pt%3B%20color%3A%20%233b3838%3B%20background%3A%20white%3B%22%3E%E6%B1%BD%E8%BD%A6%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E5%92%8C%E5%A4%84%E7%90%86%E5%99%A8%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%200.0001pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22background%3A%20white%3B%20font-size%3A%2026pt%3B%20color%3A%20%23333333%3B%22%3E%3CSTRONG%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%200.0001pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22background%3A%20white%3B%20font-size%3A%2026pt%3B%20color%3A%20%23333333%3B%22%3E%3CSTRONG%3E%E9%80%82%E7%94%A8%E4%BA%8ES32K1xx-2018.R1%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22background%3A%20%23003883%3B%20padding%3A%202.0pt%203.0pt%202.0pt%203.0pt%3B%22%20width%3D%22185%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23d1d1d1%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22background%3A%20%23003883%3B%20padding%3A%202.0pt%203.0pt%202.0pt%203.0pt%3B%22%20width%3D%22771%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22background%3A%20white%3B%20padding%3A%202.0pt%203.0pt%202.0pt%203.0pt%3B%22%20width%3D%22185%22%3E%3CP%20style%3D%22margin%3A%200in%200in%200.0001pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%20font-size%3A%2010.0pt%3B%22%3E%3CEM%3EAustin%2C%20Texas%2C%20USA%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%200.0001pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CEM%3E%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%22%3E2018%E5%B9%B4%3C%2FSPAN%3E7%E6%9C%8823%E6%97%A5%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22background%3A%20white%3B%20padding%3A%202.0pt%203.0pt%202.0pt%203.0pt%3B%22%20width%3D%22771%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%E6%B1%BD%E8%BD%A6%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E5%92%8C%E5%A4%84%E7%90%86%E5%99%A8%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E5%9B%A2%E9%98%9F%E6%AC%A3%E7%84%B6%E5%AE%A3%E5%B8%83%E6%8E%A8%E5%87%BA%E9%80%82%E7%94%A8%E4%BA%8E%20S32K1xx%202018.R1%20%E7%9A%84%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%E3%80%82%E6%AD%A4%E7%89%88%E6%9C%AC%E6%94%AF%E6%8C%81%E4%BD%BF%E7%94%A8%20MATLAB%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%2FSimulink%3C%2FSPAN%3E%E8%87%AA%E5%8A%A8%E7%94%9F%E6%88%90%20S32K1xx%20%E5%A4%96%E8%AE%BE%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%B9%B6%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E6%94%AF%E6%8C%81%E6%81%A9%E6%99%BA%E6%B5%A6%20S32K1xx%20%E6%B1%BD%E8%BD%A6%E5%BE%AE%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%8E%9F%E5%9E%8B%E8%AE%BE%E8%AE%A1%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%233b3838%3B%20background%3A%20white%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2010.0pt%3B%22%3E%3CSTRONG%3EFlexNet%20%E4%BD%8D%E7%BD%AE%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Felement%3D10221477%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Felement%3D10221477%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%2300b050%3B%20background%3A%20white%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2010.0pt%3B%22%3E%3CSTRONG%20style%3D%22text-decoration%3A%20none%3B%22%3E%3CEM%3E%26nbsp%3B%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%233b3838%3B%20background%3A%20white%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2010.0pt%3B%22%3E%3CSTRONG%3E%E6%BF%80%E6%B4%BB%E9%93%BE%E6%8E%A5%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Felement%3D10221477%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Felement%3D10221477%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%233b3838%3B%20text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%8A%80%E6%9C%AF%E6%94%AF%E6%8C%81%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E9%92%88%E5%AF%B9%20S32K1xx%20%E9%97%AE%E9%A2%98%E7%9A%84%20NXP%20%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%22%3E%E9%80%9A%E8%BF%87%20NXP%20%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%A4%BE%E5%8C%BA%E7%A9%BA%E9%97%B4%E8%BF%9B%E8%A1%8C%E8%B7%9F%E8%B8%AA%3C%2FSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fmbdt%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fmbdt%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2300b050%3B%20font-size%3A%2015.0pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%20font-size%3A%2015.0pt%3B%22%3E%3CSTRONG%3E%E7%89%88%E6%9C%AC%E5%86%85%E5%AE%B9%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3E%E5%9F%BA%E4%BA%8E%20MATLAB%20%C2%AE%E7%9A%84%20S32K%20SDK%202.0.0%20RTM%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%B8%BA%20NXP%20%E6%89%80%E6%9C%89%20S32K14x%20%E8%A1%8D%E7%94%9F%E4%BA%A7%E5%93%81%E8%87%AA%E5%8A%A8%E7%94%9F%E6%88%90%20C%20%E4%BB%A3%E7%A0%81%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22margin-left%3A%20.5in%3B%22%3E%E5%B8%A6%E6%9C%89%2016%2F32KB%20SRAM%20%E7%9A%84%20S32K142%20MCU%20%E5%B0%81%E8%A3%85%EF%BC%88*%E5%B7%B2%E6%9B%B4%E6%96%B0%EF%BC%89%3C%2FLI%3E%3CLI%20style%3D%22margin-left%3A%20.5in%3B%22%3E%E9%85%8D%E5%A4%87%2048%2F64KB%20SRAM%20%E7%9A%84%20S32K144%20MCU%20%E5%B0%81%E8%A3%85%EF%BC%88*%E5%B7%B2%E6%9B%B4%E6%96%B0%EF%BC%89%3C%2FLI%3E%3CLI%20style%3D%22margin-left%3A%20.5in%3B%22%3E%E9%85%8D%E5%A4%87%20128KB%20SRAM%20%E7%9A%84%20S32K146%20MCU%20%E5%B0%81%E8%A3%85%EF%BC%88*%E6%96%B0%E5%93%81%EF%BC%89%3C%2FLI%3E%3CLI%20style%3D%22margin-left%3A%20.5in%3B%22%3E%E9%85%8D%E5%A4%87%20192%2F256KB%20SRAM%20%E7%9A%84%20S32K148%20MCU%20%E5%B0%81%E8%A3%85%EF%BC%88*%E6%96%B0%E5%93%81%EF%BC%89%3C%2FLI%3E%3CLI%20style%3D%22margin-left%3A%20.5in%3B%22%3E%E9%80%9A%E8%BF%87%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1S32K%20Simulink%E4%B8%BB%E9%85%8D%E7%BD%AE%E5%9D%97%EF%BC%8C%E5%8F%AF%E6%8F%90%E4%BE%9B%E5%A4%9A%E7%A7%8D%E5%B0%81%E8%A3%85%E9%80%89%E9%A1%B9%E5%92%8C%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20392px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66154i49BD873F20726468%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206.0pt%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3E%E6%96%B0%E5%A2%9E%E4%BA%86%E5%AF%B9%20DMA%E3%80%81RTC%20%E5%92%8C%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%20S32K%20%E5%A4%96%E8%AE%BE%E6%94%AF%E6%8C%81%EF%BC%8C%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E4%BB%A5%E6%89%A9%E5%B1%95%E7%8E%B0%E6%9C%89%E5%B7%A5%E5%85%B7%E7%AE%B1%E5%8A%9F%E8%83%BD%E3%80%822018.R1%20%E7%89%88%E6%9C%AC%E5%AF%B9%20S32K14x%20%E5%90%84%E8%A1%8D%E7%94%9F%E4%BA%A7%E5%93%81%E7%9A%84%E5%A4%96%E8%AE%BE%E8%A6%86%E7%9B%96%E8%8C%83%E5%9B%B4%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20946px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66155i18ECE4D740B372F6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_6.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206.0pt%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3E%E9%87%8D%E6%96%B0%E8%AE%BE%E8%AE%A1%E4%BA%86%20FlexTimer%20%E9%85%8D%E7%BD%AE%E5%9D%97%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%EF%BC%8C%E4%BB%A5%E6%94%AF%E6%8C%81%20PWM%20%E7%94%9F%E6%88%90%E5%92%8C%E8%A7%A6%E5%8F%91%E4%BA%8B%E4%BB%B6%E7%9A%84%E9%99%84%E5%8A%A0%E5%8A%9F%E8%83%BD%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66156iC7CFF37F3C929946%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206.0pt%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%A2%9E%E5%8A%A0%E4%BA%86%E5%AF%B9%E7%B3%BB%E7%BB%9F%E5%9F%BA%E7%A1%80%E8%8A%AF%E7%89%87(SBC)%20UJA116x%20%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3E%20%E7%9A%84%E6%94%AF%E6%8C%81%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20549px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66157i13FF9DECD4A49416%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_9.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206.0pt%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3E%E9%87%8D%E6%96%B0%E8%AE%BE%E8%AE%A1%E4%BA%86%E4%B8%BB%E8%A6%81%E7%9A%84%20Simulink%20%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%9B%AE%E6%A0%87%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%BA%93%EF%BC%8C%E4%BB%A5%E6%94%AF%E6%8C%81%E6%9C%AA%E6%9D%A5%E6%B7%BB%E5%8A%A0%E5%85%B6%E4%BB%96%20S32K%20%E8%A1%8D%E7%94%9F%E4%BA%A7%E5%93%81%E5%92%8C%20S32K%20%E4%BA%A7%E5%93%81%E7%9A%84%E5%A4%96%E9%83%A8%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%20style%3D%22width%3A%20520px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66158iD7E9EA1F493AB954%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_11.png%22%20alt%3D%22pastedImage_11.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_11.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206.0pt%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3E%E5%AE%9E%E7%8E%B0%E9%80%9A%E4%BF%A1%E7%AB%AF%E5%8F%A3%E8%87%AA%E5%8A%A8%E5%8F%91%E7%8E%B0%EF%BC%8C%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E4%BB%A5%E4%BE%BF%E8%BD%BB%E6%9D%BE%E9%85%8D%E7%BD%AE%E5%B0%86%E7%94%9F%E6%88%90%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%8B%E8%BD%BD%E5%88%B0%20NXP%20%E7%9B%AE%E6%A0%87%3CSTRONG%3E%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%E6%96%B0%E7%9A%84%E8%AF%8A%E6%96%AD%E9%80%89%E9%A1%B9%3C%2FSTRONG%3E%E5%B8%AE%E5%8A%A9%E6%A8%A1%E5%9E%8B%E5%88%9B%E5%BB%BA%E6%88%96%E8%BF%81%E7%A7%BB%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_13.png%22%20style%3D%22width%3A%20339px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66224i62E1D4F71ED0D9CD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_13.png%22%20alt%3D%22pastedImage_13.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_13.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%20style%3D%22width%3A%20429px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66380iE2F627EED3E80828%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_14.png%22%20alt%3D%22pastedImage_14.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_14.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3E100%25%20S32K%20%E6%94%AF%E6%8C%81%E7%9A%84%E5%A4%96%E8%AE%BE%EF%BC%8C%E5%B9%B6%E6%8F%90%E4%BE%9B%E7%A4%BA%E4%BE%8B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%80%82%E7%9B%AE%E5%89%8D%EF%BC%8C%E5%B7%A5%E5%85%B7%E7%AE%B1%E4%B8%AD%E6%9C%89%20115%20%E4%B8%AA%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%89%80%E6%9C%89%E6%94%AF%E6%8C%81%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%20style%3D%22width%3A%20620px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66382i6FFCA3775A1DF4D2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_16.png%22%20alt%3D%22pastedImage_16.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_16.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3E%E6%B7%BB%E5%8A%A0%E5%AF%B9%E5%A4%96%E9%83%A8%E6%A8%A1%E5%BC%8F%E7%9A%84%E6%94%AF%E6%8C%81%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%EF%BC%8C%E4%BD%BF%E4%B8%BB%E6%9C%BA%E4%B8%8A%E7%9A%84%20Simulink%20%E8%83%BD%E5%A4%9F%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%97%B6%E4%B8%8E%20NXP%20%E7%A1%AC%E4%BB%B6%E6%9D%BF%E4%B8%8A%E9%83%A8%E7%BD%B2%E7%9A%84%E6%A8%A1%E5%9E%8B%E8%BF%9B%E8%A1%8C%E9%80%9A%E4%BF%A1%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_18.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_18.png%22%20style%3D%22width%3A%20618px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66383iEFEE57C11FDDB75B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_18.png%22%20alt%3D%22pastedImage_18.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_18.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3E%E4%B8%BA%20NXP%20%E7%9B%AE%E6%A0%87%E5%90%AF%E7%94%A8%20MATLAB%20%E4%BB%A3%E7%A0%81%E5%88%86%E6%9E%90%E5%99%A8%EF%BC%8C%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E4%BD%BF%E7%94%A8%E5%A4%84%E7%90%86%E5%99%A8%E5%9C%A8%E7%8E%AF%E6%A8%A1%E5%BC%8F%E6%B5%8B%E9%87%8F%E5%87%BD%E6%95%B0%E6%89%A7%E8%A1%8C%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_20.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_20.png%22%20style%3D%22width%3A%20471px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66386iA1704E5BC4DFFE77%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_20.png%22%20alt%3D%22pastedImage_20.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_20.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E6%9C%89%E5%85%B3%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%E3%80%81%E5%8A%9F%E8%83%BD%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E6%96%B0%E5%8A%9F%E8%83%BD%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E9%9A%8F%E9%99%84%E7%9A%84%E3%80%8A%E5%8F%91%E5%B8%83%E8%AF%B4%E6%98%8E%E3%80%8B%E6%96%87%E6%A1%A3%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2300b050%3B%20font-size%3A%2015.0pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%20font-size%3A%2015.0pt%3B%22%3E%3CSTRONG%3EMATLAB%C2%AE%20%E9%9B%86%E6%88%90%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%206.0pt%200in%204.6pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3ENXP%20%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%E6%89%A9%E5%B1%95%E4%BA%86%20MATLAB%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%C2%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%92%8C%20Simulink%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%C2%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E4%BD%93%E9%AA%8C%EF%BC%8C%E5%85%81%E8%AE%B8%E5%AE%A2%E6%88%B7%E8%AF%84%E4%BC%B0%E5%92%8C%E4%BD%BF%E7%94%A8%20NXP%20%E7%9A%84%20S32K1xx%20MCU%20%E5%92%8C%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%22%3E%E5%BC%80%E7%AE%B1%E5%8D%B3%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23002c14%3B%22%3E%E7%94%A8%E7%9A%84%E8%AF%84%E4%BC%B0%E6%9D%BF%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9A%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206.0pt%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.mathworks.com%2Fmatlabcentral%2Ffileexchange%2F64740-nxp-support-package-s32k1xx%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3ENXP%20S32K1xx%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%9C%A8%E7%BA%BF%E5%AE%89%E8%A3%85%E6%8C%87%E5%8D%97%E6%8F%92%E4%BB%B6%3C%2FSPAN%3E%E6%94%AF%E6%8C%81%E5%8C%85%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%E5%85%81%E8%AE%B8%E7%94%A8%E6%88%B7%E7%9B%B4%E6%8E%A5%E4%BB%8E%20Mathwork%20%E7%BD%91%E7%AB%99%E6%88%96%20MATLAB%20IDE%20%E5%AE%89%E8%A3%85%20NXP%20%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%E8%AF%A5%E6%94%AF%E6%8C%81%E5%8C%85%E6%8F%90%E4%BE%9B%E4%BA%86%E5%AE%89%E8%A3%85%E5%92%8C%E9%AA%8C%E8%AF%81%E7%9A%84%E5%88%86%E6%AD%A5%E6%8C%87%E5%8D%97%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_22.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_22.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66159iC7985ED30184D89F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_22.png%22%20alt%3D%22pastedImage_22.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_22.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206.0pt%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D10221477%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3ENXP%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84S32K1xx%202018.R1%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%20%E5%9C%A8%E5%AE%89%E8%A3%85%E3%80%81%E6%96%87%E6%A1%A3%E3%80%81%E5%B8%AE%E5%8A%A9%E5%92%8C%E7%A4%BA%E4%BE%8B%C2%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%20%E4%B8%8EMATLAB%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%201%E7%8E%AF%E5%A2%83%20%E5%AE%8C%E5%85%A8%E9%9B%86%E6%88%90%20%EF%BC%9B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_24.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_24.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66160iAEF02A585823C7D2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_24.png%22%20alt%3D%22pastedImage_24.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_24.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%2300b050%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%20font-size%3A%2015.0pt%3B%22%3E%3CSTRONG%3E%E7%9B%AE%E6%A0%87%E5%8F%97%E4%BC%97%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E6%AD%A4%E7%89%88%E6%9C%AC%20(2018.R1)%20%E6%97%A8%E5%9C%A8%E7%94%A8%E4%BA%8E%20S32K142%E3%80%81S32K144%E3%80%81S32K146%20%E5%92%8C%20S32K148%20MCU%20%E5%92%8C%E8%AF%84%E4%BC%B0%E6%9D%BF%E7%9A%84%E6%8A%80%E6%9C%AF%E6%BC%94%E7%A4%BA%E3%80%81%E8%AF%84%E4%BC%B0%E7%9B%AE%E7%9A%84%E5%92%8C%E5%8E%9F%E5%9E%8B%E8%AE%BE%E8%AE%A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%20font-size%3A%2015.0pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84S32K14x%E6%B1%BD%E8%BD%A6MCU%202018.R1%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121887%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%8D%EF%BC%8CMathWorks%20%E7%9A%84%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%BC%96%E7%A0%81%E5%99%A8%E6%98%AF%E4%B8%8E%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%9B%AE%E6%A0%87%E4%BA%A4%E4%BA%92%E7%9A%84%E6%89%80%E6%9C%89%E5%85%B6%E4%BB%96%E7%BC%96%E7%A0%81%E5%99%A8%EF%BC%88MATLAB%2FSIMULINK%EF%BC%89%E7%9A%84%E5%85%88%E5%86%B3%E6%9D%A1%E4%BB%B6%EF%BC%9A%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.mathworks.com%2Fproducts%2Fembedded-coder.html%22%20title%3D%22https%3A%2F%2Fwww.mathworks.com%2Fproducts%2Fembedded-coder.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%BC%96%E7%A0%81%E5%99%A8%20-%20MATLAB%20%E5%92%8C%20Simulink%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84S32K14x%E6%B1%BD%E8%BD%A6MCU%202018.R1%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%B2%A1%E6%9C%89%20mathworks%20%E7%9A%84%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%BC%96%E7%A0%81%E5%99%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%E5%B7%A5%E5%85%B7%E7%AE%B1%E5%90%97%EF%BC%9F%E4%BB%85%E4%BD%BF%E7%94%A8%20Matlab%20%E7%BC%96%E7%A0%81%E5%99%A8%E5%92%8C%20Simulink%20%E7%BC%96%E7%A0%81%E5%99%A8%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84S32K14x%E6%B1%BD%E8%BD%A6MCU%202018.R1%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%AE%89%E8%A3%85%E5%B9%B6%E5%B0%9D%E8%AF%95%E4%BA%86%E4%B8%8B%E8%BD%BD%E4%B8%AD%E7%9B%B4%E6%8E%A5%E5%87%BA%E7%8E%B0%E7%9A%84%E6%89%80%E6%9C%89%E5%86%85%E5%AE%B9%E3%80%82%3CBR%20%2F%3E%E4%BB%8E%E7%8E%B0%E5%9C%A8%E5%BC%80%E5%A7%8B%E6%88%91%E4%BC%9A%E5%B0%9D%E8%AF%95%E5%AE%83%EF%BC%8C%E5%8D%B3%E4%BD%BF%E6%9C%89%E9%99%84%E5%8A%A0%E7%BB%84%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84S32K14x%E6%B1%BD%E8%BD%A6MCU%202018.R1%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%A5%E9%97%AE%E9%A2%98%E5%B7%B2%E5%9C%A8%20MathWorks%20%E7%AB%AF%E5%BE%97%E5%88%B0%E4%BF%AE%E5%A4%8D%EF%BC%8C%E6%88%91%E5%88%9A%E5%88%9A%E7%A1%AE%E8%AE%A4%EF%BC%8C%E4%B8%80%E6%97%A6%E6%82%A8%E5%8D%95%E5%87%BB%E2%80%9C%E6%B7%BB%E5%8A%A0%E2%80%9D%EF%BC%8C%E5%AE%89%E8%A3%85%E5%B0%B1%E4%BC%9A%E9%80%9A%E8%BF%87%20Add-on%20Explorer%20%E6%8C%89%E9%A2%84%E6%9C%9F%E8%BF%9B%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B9%B2%E6%9D%AF%EF%BC%8C%3C%2FP%3E%3CP%3E-%E5%B8%83%E8%8E%B1%E6%81%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84S32K14x%E6%B1%BD%E8%BD%A6MCU%202018.R1%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Hayaoki7%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%AF%B9%E6%AD%A4%E8%BF%9B%E8%A1%8C%E4%BA%86%E8%BF%9B%E4%B8%80%E6%AD%A5%E7%9A%84%E8%B0%83%E6%9F%A5%EF%BC%88%E5%8D%B8%E8%BD%BD%E5%B9%B6%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%EF%BC%89%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%A4%8D%E5%88%B6%E8%AF%A5%E9%97%AE%E9%A2%98%E3%80%82%E8%BF%99%E4%BC%BC%E4%B9%8E%E6%98%AF%20MathWorks%20%E6%96%B9%E9%9D%A2%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%88%E9%99%84%E5%8A%A0%E7%BB%84%E4%BB%B6%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E6%97%A0%E6%B3%95%E6%AD%A3%E7%A1%AE%E5%A4%84%E7%90%86%20MLTBX%20%E6%96%87%E4%BB%B6%EF%BC%89%E3%80%82%E8%AF%A5%E9%97%AE%E9%A2%98%E5%B7%B2%E5%9C%A8%E5%86%85%E9%83%A8%E8%AE%B0%E5%BD%95%EF%BC%8C%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E6%AD%A3%E5%9C%A8%E7%A0%94%E7%A9%B6%E4%BF%AE%E5%A4%8D%E6%96%B9%E6%B3%95%E3%80%82%E7%9F%AD%E6%9C%9F%E5%86%85%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20Daniel%20%E6%A6%82%E8%BF%B0%E7%9A%84%E7%9B%B4%E6%8E%A5%E4%B8%8B%E8%BD%BD%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B9%B2%E6%9D%AF%EF%BC%8C%3C%2FP%3E%3CP%3E-%E5%B8%83%E8%8E%B1%E6%81%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84S32K14x%E6%B1%BD%E8%BD%A6MCU%202018.R1%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121882%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CHayaoki7%EF%BC%8C%E6%88%91%E5%88%9A%E5%88%9A%E6%B5%8B%E8%AF%95%E8%BF%87%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%8F%91%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82Add-on%20Explorer%20%E5%B0%86%E8%81%94%E7%B3%BB%20mathworks.com%20%E4%BB%A5%E8%8E%B7%E5%8F%96%E9%99%84%E5%8A%A0%E7%BB%84%E4%BB%B6%E5%88%97%E8%A1%A8%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%A6%82%E6%9E%9C%E7%BD%91%E7%AB%99%E6%9A%82%E6%97%B6%E5%85%B3%E9%97%AD%E6%88%96%E8%BF%9E%E6%8E%A5%E4%B8%AD%E6%96%AD%EF%BC%8C%E5%88%99%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E3%80%82%E8%AF%B7%E5%86%8D%E8%AF%95%E4%B8%80%E6%AC%A1%20-%20%E5%A6%82%E6%9E%9C%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%AF%B7%3CA%20href%3D%22https%3A%2F%2Fwww.mathworks.com%2Fsupport%2Fcontact_us.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E8%81%94%E7%B3%BB%20MathWorks%20%E6%8A%80%E6%9C%AF%E6%94%AF%E6%8C%81%EF%BC%8C%3C%2FA%3E%E5%9B%A0%E4%B8%BA%E8%BF%99%E5%8F%AF%E8%83%BD%E6%98%AF%20Mathworks%20%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20NXP%20%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B9%B2%E6%9D%AF%EF%BC%8C%3C%2FP%3E%3CP%3E-%E5%B8%83%E8%8E%B1%E6%81%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84S32K14x%E6%B1%BD%E8%BD%A6MCU%202018.R1%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fhayaoki7%22%20target%3D%22_blank%22%3Ehayaoki7%3C%2FA%3E%E2%80%8C%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%BC%BA%E8%B0%83%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%E6%88%91%E5%B0%86%E4%B8%8E%20Mathworks%20%E9%87%8D%E6%96%B0%E6%A3%80%E6%9F%A5%E5%8F%91%E7%94%9F%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E5%B9%B6%E4%B8%8D%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CP%3E%E6%97%A0%E8%AE%BA%E5%A6%82%E4%BD%95%EF%BC%8C%E8%AF%B7%E7%9B%B4%E6%8E%A5%E8%AE%BF%E9%97%AE%E6%AD%A4%E9%93%BE%E6%8E%A5%EF%BC%9A%20%3CA%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fnxp.flexnetoperations.com%252Fcontrol%252Ffrse%252Fdownload%253Felement%253D10221477%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20text-decoration%3A%20underline%3B%20padding%3A%200px%20calc(12px%20%2B%200.35ex)%200px%200px%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3C%2FA%3E%20%EF%BC%9Felement%3D10221477%20%E9%80%89%E6%8B%A9%E9%80%82%E7%94%A8%E4%BA%8E%20S32K1xx%20%E7%89%88%E6%9C%AC%202018.R1%20%E7%9A%84%20NXP%20%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%EF%BC%8C%E7%A1%AE%E4%BF%9D%E9%80%89%E4%B8%AD%E5%AE%83%E9%99%84%E8%BF%91%E7%9A%84%E5%A4%8D%E9%80%89%E6%A1%86%E5%B9%B6%E4%BD%BF%E7%94%A8%E2%80%9C%E4%B8%8B%E8%BD%BD%E9%80%89%E5%AE%9A%E6%96%87%E4%BB%B6%E2%80%9D%E6%8C%89%E9%92%AE%E4%B8%8B%E8%BD%BD%E5%B8%A6%E6%9C%89%20mltbx%20%E6%89%A9%E5%B1%95%E5%90%8D%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F66379iABBA0934D2940B92%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%8C%89%E7%85%A7%E4%B8%BB%E7%BA%BF%E7%A8%8B%E9%99%84%E5%B8%A6%E7%9A%84%E5%BF%AB%E9%80%9F%E5%85%A5%E9%97%A8%E6%8C%87%E5%8D%97%E6%89%8B%E5%86%8C%E4%B8%AD%E6%89%80%E7%A4%BA%E7%9A%84%E6%AD%A5%E9%AA%A4%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E6%9C%89%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9F%BA%E4%BA%8E%E6%A8%A1%E5%9E%8B%E7%9A%84S32K14x%E6%B1%BD%E8%BD%A6MCU%202018.R1%E8%AE%BE%E8%AE%A1%E5%B7%A5%E5%85%B7%E7%AE%B1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A8%E6%8F%92%E4%BB%B6%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E4%B8%AD%E6%8C%89%E4%B8%8B%E2%80%9C%E6%B7%BB%E5%8A%A0%E2%80%9D%E6%8C%89%E9%92%AE%E5%90%8E%3CBR%20%2F%3E%E6%88%91%E4%B8%8D%E4%BC%9A%E7%BB%A7%E7%BB%AD%E5%BE%80%E5%89%8D%E8%B5%B0%E3%80%82%3C%2FP%3E%3CP%3E%E9%99%A4%E4%BA%86%20Addon%20Explorer%20%E4%B9%8B%E5%A4%96%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E5%AE%89%E8%A3%85%E5%AE%83%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎07-23-2018 10:46 AM
更新人:
