Model-Based Design Toolbox for MPC57xx Automotive Version 3.0.0
Product Release Announcement
Automotive Microcontrollers and Processors
NXP Model-Based Design Toolbox
for MPC57xx – version 3.0.0
Austin, Texas, USA
February 18, 2019
The Automotive Microcontrollers and Processors’ Model-Based Design Tools Team at NXP Semiconductors, is pleased to announce the release of the Model-Based Design Toolbox for MPC57xx version 3.0.0. This release supports automatic code generation for peripherals and applications prototyping from MATLAB/Simulink for NXP’s MPC574xB/C/G/P series.
FlexNet Location
https://nxp.flexnetoperations.com/control/frse/download?element=10769197
Activation link
Technical Support
NXP Model-Based Design Toolbox for MPC57xx issues are tracked through NXP Model-Based Design Tools Community space.
https://community.nxp.com/community/mbdt
Release Content
  • Automatic C code generation based on PA SDK 2.0.0 RTM drivers from MATLAB®/Simulink® for NXP MPC574xB/C/G/P derivatives:
  • MPC5744B, MPC5745B, MPC5746B                                                (*new)
  • MPC5744C, MPC5745C, MPC5746C, MPC5747C, MPC5748C      (*new)
  • MPC5746G, MPC5747G, MPC5748G                                               (*new)
  • MPC5741P, MPC5742P, MPC5743P, MPC5744P                             (*upd)
  • Multiple options for MCU packages, Build Toolchains and embedded Target Connections are available via Model-Based Design Toolbox MPC574x Simulink main configuration block
  • Enhanced user experience with a complete redesign of all Simulink Library blocks compared with v.2.0.0 to support:
  • Similar look & feel with Model-Based Design Toolbox for S32K14x Series
  • Basic and Advanced configurations modes based on PA SDK 2.0.0 RTM standard API
  • Integration with MathWorks SW environment: Installer, Help and online Add-on Manager for distribution and installation
  • MPC574xP Ultra-Reliable MCU for Automotive & Industrial Safety Applications and MPC574xB/C/G Ultra-Reliable MCUs for Automotive & Industrial Control and summary of the peripherals coverage by Model-Based Design version 3.0.0 is highlighted in red:
  • Redesigned the main Simulink Embedded Target library for supporting future additions for other MPC57xx derivatives, Automotive Math and Motor Control Libraries and MPC57xx Examples:
  • Implement communication port auto discovery to allow easy configuration for downloading the generated code to NXP targets and new Diagnostic options to helps with model creation or migration.
  • 100% MPC574x supported peripheral coverage with examples. Currently there are 102 examples available as part of the toolbox that exercise all the functionalities supported. The examples are grouped into two categories:
  • MPC574x Generic examples that can be run on any of the MPC574x Evaluation Boards
  • MPC574x Targeted examples that are configured for a single target (e.g.: might contains peripherals that are available only on a specific target)
  • Motor Control examples for PMSM and BLDC based on FOC and 6-step commutation with Closed and Open loop control
  • Enable MATLAB code profiler for NXP targets for measuring the function execution time using Software -in-the-Loop or Processor-in-the-Loop modes
For more details, features and how to use the new functionalities, please refer to the Release Notes and Quick Start Guide documents attached.
MATLAB® Integration
The NXP Model-Based Design Toolbox extends the MATLAB® and Simulink® experience by allowing customers to evaluate and use NXP’s MPC57xx MCUs and evaluation boards solutions out-of-the-box with:
  • NXP Support Package for MPC57xx Online Installer Guide Add-on allows users to install NXP solution directly from the Mathwork’s website or directly from MATLAB IDE. The Support Package provide a step-by-step guide for installation and verification.
Target Audience
This release (v.3.0.0) is intended for technology demonstration, evaluation purposes and prototyping for MPC574xB/C/G/P MCUs and their corresponding Evaluation Boards:
  • DEVKIT-MPC5744P PCB RevX1 SCH RevB
  • DEVKIT-MPC5748G PCB RevA SCH RevB
  • Daughter Card MPC574XG-256DS RevB
  • Daughter Card X-MPC574XG-324DS RevA
  • Daughter Card MPC5744P-257DS RevB1
  • Daughter Card SPC5746CSK1MKU6
  • Motherboard X-MPC574XG-MB RevD
  • Motherboard MPC57XX RevC
添付
コメント
Model-Based Design Toolbox for MPC57xx Automotive Version 3.0.0 Installing S32K blocks will be uninstalled.
Is there a solution?
Hello hayaoki7‌,
Thank you for your message and for your interest in our toolbox!
The mentioned behaviour is now tracked internally as AST-1325.
If you want to have installed the both toolboxes (MPC and S32K) they must not be installed in the same location. Please follow the next instructions:
1. Open Matlab, go to Preferences -> Add-Ons and under Installation Folder please add the desired location followes by \S32K (I typed C:AddOns\S32K)
2. Install the mltbx for S32K.
3. In Matlab, Set Path, Pres Default and Save or go to [C:\AddOns]\S32K\Toolboxes\NXP_MBDToolbox_S32K1xx, right click on folder code, go to Remove from Path -> Selected folder and subfolders.
4. In Matlab, go to Preferences -> Add-Ons and under Installation Folder please changed the desired location followes by \MPC (I typed C:AddOns\MPC)
5. Install the mltbx for MPC.
6. Now you have the both toolboxes installed but only the MPC is in path.
7. In order to use the S32K toolbox please go to C:\AddOns\S32K\Toolboxes\NXP_MBDToolbox_S32K1xx\code and run the mbd_s32k_path.m script. This will add also the S32K script in path.
Now you have the both toolboxes installed.
But what would I also recommend will be to remove from Matlab's path the toolbox that you are not using: only from path! For example if you don't use the S32K toolbox keep in path only the MPC Toolbox and reverse. You can remove from path using the script from the point number 3, and to add any of the toolbox the instruction 7 because the MPC and S32K have the same mechanism.
Hope this helps,
Marius!
Hi hayaoki7
What's the MATLAB revision you are using? I'm testing with MATLAB 2018b and there's no problem.
Thank you!
am using R2018A.
Is R2018B better?
Thank you
Will there be an other release in the future which supports the MPC5777C?
Luca
Hi lucabarbiero‌,
Currently we have added support for the MPC574x derivatives B/C/G/P supported by NPX SDK 2.0.0 RTM release.
Once the support for MPC577x will be enabled in a SDK RTM release, we are going to add them into Simulink too. Most likely the next release of this toolbox (denoted 3.1.0) will include such support.
Hey there,a general suggestion to u and this community.As someone asked above users are eagerly waiting for future versions,which may support MPC5777C,as many users need it and eagerly waiting for it.And pls make sure,it is done as soon as possible.Regards kfc survey
Help!!!
Where should I put the “license.dat” about MBDToolbox_MPC57xx_3.0.0,I can not find the “lic” file.And my error as follow picture.
You need to place it in {Toolbox installation directory}\lic folder
Please refer to the step by step available in your {Toolbox installation directory}\help folder Model_Based_Design_Toolbox_MPC57xx_Series_Licensing_Guide.pdf or to https://www.nxp.com/docs/en/quick-reference-guide/MBDT-MPC57xx_QSG.pdf page 1-7
Hope this helps!
But how to install the Add-ons,I don't know how to open this view as follow.What "*.mltbx" file should I open?
And My Matlab version is 2017b,can I use this MBD_574xx_3.0.0 in this version?
tjs
Hello dumitru-daniel.popa!
Is there an update on an expected release date for the 3.1.0 release to support the MPC5777x variant?
Best-
Tom
Hi Thomas,
According with our internal roadmap the MBDT MPC57xx 3.1.0 will be available in Q1 20192020. I can't give you an exact date because i've not yet closed the PRD but is going to be towards the end of the quarter.
Anything in particular that are you looking for ?
tjs
Hi Daniel-
Thanks for the response. I assume you meant Q1-2020 right?
We are developing a new ECU and would like to utilize the toolbox for further development.
Thx-
Tom
Hi Tom,
Yes, 2020 - sorry for mistake.
What kind of processor you want to use and which are the main functionalities you are looking for. If you want to be sure, some particular features will be present, please contact your account manager in NXP and tell him your requirements.
Bottom line, we want to upgrade the MPC57xx toolbox to similar level of features as S32K1xx version 4.1.0
%3CLINGO-SUB%20id%3D%22lingo-sub-1109352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CTABLE%20style%3D%22width%3A%20974px%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22background%3A%20%23003883%3B%20padding%3A%202pt%203pt%3B%20width%3A%20184px%3B%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23d1d1d1%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22background%3A%20%23003883%3B%20padding%3A%202pt%203pt%3B%20width%3A%20772px%3B%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23d1d1d1%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22padding%3A%202pt%203pt%3B%20width%3A%20184px%3B%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20146px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72362i68391F8C9CCFD218%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22background%3A%20white%3B%20padding%3A%202pt%203pt%3B%20width%3A%20772px%3B%22%3E%3CP%20style%3D%22margin%3A%200in%200in%200.0001pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2024pt%3B%20color%3A%20%23333333%3B%22%3E%E8%A3%BD%E5%93%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%200.0001pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%22%3E%E8%BB%8A%E8%BC%89%E7%94%A8%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%EF%BC%8F%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%200.0001pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%20font-size%3A%2026pt%3B%22%3E%3CSTRONG%3ENXP%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E8%A8%AD%E8%A8%88%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%200in%200.0001pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%23333333%3B%20background%3A%20white%3B%20font-size%3A%2026pt%3B%22%3E%3CSTRONG%3EMPC57xx%20%E2%80%93%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22background%3A%20%23003883%3B%20padding%3A%202pt%203pt%3B%20width%3A%20184px%3B%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20%23d1d1d1%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22background%3A%20%23003883%3B%20padding%3A%202pt%203pt%3B%20width%3A%20772px%3B%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22background%3A%20white%3B%20padding%3A%202pt%203pt%3B%20width%3A%20184px%3B%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%20font-size%3A%2010.0pt%3B%22%3E%3CEM%3EAustin%2C%20Texas%2C%20USA%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%20font-size%3A%2010.0pt%3B%22%3E%3CEM%3E2019%E5%B9%B42%E6%9C%8818%E6%97%A5%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22background%3A%20white%3B%20padding%3A%202pt%203pt%3B%20width%3A%20772px%3B%22%3E%3CP%20style%3D%22margin%3A%200in%200in%200.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ENXP%20Semiconductors%E3%81%AE%E8%BB%8A%E8%BC%89%E7%94%A8%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%8A%E3%82%88%E3%81%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Felement%3D10769197%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20MPC57xx%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.0.0%E7%94%A8%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FA%3E%20%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E7%99%BA%E8%A1%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%AC%89%E3%81%97%E3%81%8F%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%20NXP%E3%81%AEMPC574xB%2FC%2FG%2FP%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E7%94%A8%E3%81%AE%20MATLAB%20%2FSimulink%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%20%E3%81%8B%E3%82%89%E3%81%AE%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%8A%E3%82%88%E3%81%B3%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%97%E3%83%AD%E3%83%88%E3%82%BF%E3%82%A4%E3%83%94%E3%83%B3%E3%82%B0%E7%94%A8%E3%81%AE%E8%87%AA%E5%8B%95%E3%82%B3%E3%83%BC%E3%83%89%E7%94%9F%E6%88%90%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%233b3838%3B%20text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3EFlexNet%20%E3%81%AE%E5%A0%B4%E6%89%80%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Felement%3D10769197%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Felement%3D10769197%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%2300b050%3B%20background%3A%20white%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2010.0pt%3B%22%3E%3CSTRONG%20style%3D%22text-decoration%3A%20none%3B%20%22%3E%3CEM%3E%26nbsp%3B%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%233b3838%3B%20text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%99%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%AA%E3%83%B3%E3%82%AF%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Felement%3D10769197%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Felement%3D10769197%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22%3B%20color%3A%20%233b3838%3B%20text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E3%83%86%E3%82%AF%E3%83%8B%E3%82%AB%E3%83%AB%E3%83%BB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ENXP%20Model-Based%20Design%20Toolbox%20for%20MPC57xx%E3%81%AE%E5%95%8F%E9%A1%8C%20%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%22%3E%E3%81%AF%E3%80%81NXP%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E8%BF%BD%E8%B7%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fmbdt%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fmbdt%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2300b050%3B%20font-size%3A%2015.0pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%20font-size%3A%2015.0pt%3B%22%3E%3CSTRONG%3E%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E5%86%85%E5%AE%B9%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3ENXP%20MPC574xB%2FC%2FG%2FP%20%E6%B4%BE%E7%94%9F%E7%89%A9%E7%94%A8%E3%81%AE%20MATLAB%2F%C2%AE%20Simulink%C2%AE%20%E3%81%AE%20PA%20SDK%202.0.0%20RTM%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E8%87%AA%E5%8B%95%20C%20%E3%82%B3%E3%83%BC%E3%83%89%E7%94%9F%E6%88%90%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3A%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-left%3A%20.5in%3B%22%3EMPC5744B%2C%20MPC5745B%2C%20MPC5746B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B(*new)%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-left%3A%20.5in%3B%22%3EMPC5744C%2C%20MPC5745C%2C%20MPC5746C%2C%20MPC5747C%2C%20MPC5748C%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20(*new)%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-left%3A%20.5in%3B%22%3EMPC5746G%2C%20MPC5747G%2C%20MPC5748G%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B(*new)%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-left%3A%20.5in%3B%22%3EMPC5741P%2C%20MPC5742P%2C%20MPC5743P%2C%20MPC5744P%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B(*upd)%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-left%3A%20.5in%3B%22%3E%3CSTRONG%3EMCU%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%3C%2FSTRONG%3E%E3%80%81%3CSTRONG%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%3C%2FSTRONG%3E%E3%80%81%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%3CSTRONG%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%3C%2FSTRONG%3E%E3%81%AE%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81Model-Based%20Design%20Toolbox%20MPC574x%20Simulink%20main%20configuration%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_4.png%22%20style%3D%22width%3A%20315px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72396i69D9629FA2C515A2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_4.png%22%20alt%3D%22pastedImage_4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206.0pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3Ev.2.0.0%20%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20Simulink%20Library%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E5%86%8D%E8%A8%AD%E8%A8%88%E3%81%97%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%AA%E3%82%A8%E3%83%B3%E3%82%B9%E3%82%92%E5%90%91%E4%B8%8A%E3%81%95%E3%81%9B%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22margin-left%3A%20.5in%3B%22%3ES32K14x%20Series%20%E3%81%AE%20Model-Based%20Design%20Toolbox%20%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AE%E3%83%AB%E3%83%83%E3%82%AF%20%E3%82%A2%E3%83%B3%E3%83%89%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%3C%2FLI%3E%3CLI%20style%3D%22margin-left%3A%20.5in%3B%22%3EPA%20SDK%202.0.0%20RTM%20%E6%A8%99%E6%BA%96%20API%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E5%9F%BA%E6%9C%AC%E6%A7%8B%E6%88%90%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%E8%A9%B3%E7%B4%B0%E6%A7%8B%E6%88%90%E3%83%A2%E3%83%BC%E3%83%89%3C%2FLI%3E%3CLI%20style%3D%22margin-left%3A%20.5in%3B%22%3EMathWorks%20SW%20%E7%92%B0%E5%A2%83%E3%81%A8%E3%81%AE%E7%B5%B1%E5%90%88%3A%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%A9%E3%83%BC%E3%80%81%E3%83%98%E3%83%AB%E3%83%97%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E9%85%8D%E5%B8%83%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E7%94%A8%E3%81%AE%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%82%A2%E3%83%89%E3%82%AA%E3%83%B3%20%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206.0pt%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3EMPC574xP%20%E8%B6%85%E9%AB%98%E4%BF%A1%E9%A0%BC%E6%80%A7%20MCU%20for%20Automotive%20%26amp%3B%20Industrial%20Safety%20Applications%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%20%E3%81%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3E%20MPC574xB%2FC%2FG%20Ultra-Reliable%20MCUs%20for%20Automotive%20%26amp%3B%20Industrial%20Control%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%20%E3%80%81%20%E3%81%8A%E3%82%88%E3%81%B3%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AB%E3%82%88%E3%82%8B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%20%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20black%3B%22%3E%20%E3%82%AB%E3%83%90%E3%83%AC%E3%83%83%E3%82%B8%E3%81%AE%E6%A6%82%E8%A6%81%E3%81%AF%20%E8%B5%A4%E3%81%A7%E5%BC%B7%E8%AA%BF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20368px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72450iB43C558322650698%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_6.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20314px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72470i6FA9258FF54A8C71%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206.0pt%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E4%BB%96%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%20MPC57xx%20%E6%B4%BE%E7%94%9F%E8%A3%BD%E5%93%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%20%E3%80%81Automotive%20Math%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%20%E3%81%8A%E3%82%88%E3%81%B3%20Motor%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%20Control%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%80%81MPC57xx%20Examples%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%20%E3%81%AE%E5%B0%86%E6%9D%A5%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3E%20%E3%80%81%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%81%AE%20Simulink%20Embedded%20Target%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E5%86%8D%E8%A8%AD%E8%A8%88%20%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin%3A%206pt%200in%204.35pt%200.5in%3B%20text-align%3A%20center%3B%22%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20465px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72532i56028AA484F5E187%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_8.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%206pt%200in%204.35pt%200.5in%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%20style%3D%22width%3A%20332px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72571iC2042FF85303BD44%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_10.png%22%20alt%3D%22pastedImage_10.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_10.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%20style%3D%22width%3A%20337px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72533i21272D6DA8DDC0FA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_11.png%22%20alt%3D%22pastedImage_11.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_11.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%206pt%200in%204.35pt%200.5in%3B%20text-align%3A%20center%3B%22%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206.0pt%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3E%E9%80%9A%E4%BF%A1%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E8%87%AA%E5%8B%95%E6%A4%9C%E5%87%BA%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%81%A6%E3%80%81%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92NXP%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E7%B0%A1%E5%8D%98%E3%81%AA%E6%A7%8B%E6%88%90%E3%81%A8%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%BE%E3%81%9F%E3%81%AF%E7%A7%BB%E8%A1%8C%E3%82%92%E6%94%AF%E6%8F%B4%E3%81%99%E3%82%8B%E6%96%B0%E3%81%97%E3%81%84%3CSTRONG%3E%E8%A8%BA%E6%96%AD%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSTRONG%3E%E3%82%92%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.png%22%20style%3D%22width%3A%20288px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72534i6B685AD95B469745%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_12.png%22%20alt%3D%22pastedImage_12.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_12.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.png%22%20style%3D%22width%3A%20320px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72618iEBE9F22B9D20096E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_14.png%22%20alt%3D%22pastedImage_14.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_14.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3E100%25%20MPC574x%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%AB%E3%83%90%E3%83%AC%E3%83%83%E3%82%B8(%E4%BE%8B%E4%BB%98%E3%81%8D%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E)%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%3C%2FSPAN%3E%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A8%E3%81%97%E3%81%A6%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%201%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E02%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%81%AE%E4%BE%8B%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%E3%80%82%E4%BE%8B%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%202%20%E3%81%A4%E3%81%AE%E3%82%AB%E3%83%86%E3%82%B4%E3%83%AA%E3%81%AB%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22margin-left%3A%20.5in%3B%22%3EMPC574x%20MPC574x%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%A7%E3%82%82%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%20%3CSTRONG%3E%E6%B1%8E%E7%94%A8%3C%2FSTRONG%3E%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%3C%2FLI%3E%3CLI%20style%3D%22margin-left%3A%20.5in%3B%22%3EMPC574x%20%E5%8D%98%E4%B8%80%E3%81%AE%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E7%94%A8%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20%3CSTRONG%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%3C%2FSTRONG%3E%20%E3%81%AE%E4%BE%8B%20(%E4%BE%8B%3A%20%E7%89%B9%E5%AE%9A%E3%81%AE%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%A7%E3%81%AE%E3%81%BF%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_15.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_15.png%22%20style%3D%22width%3A%20306px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72572i77D0D9780C0D6022%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_15.png%22%20alt%3D%22pastedImage_15.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_15.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%20style%3D%22width%3A%20308px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72660iFEE88CBF013E0B62%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_16.png%22%20alt%3D%22pastedImage_16.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_16.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3EFOC%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%3CSTRONG%3E%20PMSM%3C%2FSTRONG%3E%20%E3%81%8A%E3%82%88%E3%81%B3%3CSTRONG%3E%20BLDC%20%E3%81%AE%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E4%BE%8B%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E9%96%89%E3%83%AB%E3%83%BC%E3%83%97%E3%81%8A%E3%82%88%E3%81%B3%E9%96%8B%E3%83%AB%E3%83%BC%E3%83%97%E5%88%B6%E5%BE%A1%E3%81%AB%E3%82%88%E3%82%8B6%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E6%95%B4%E6%B5%81%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_18.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_18.png%22%20style%3D%22width%3A%20609px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72451iE4BB7F2492C13FB4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_18.png%22%20alt%3D%22pastedImage_18.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_18.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSTRONG%3ENXP%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%20MATLAB%20%E3%82%B3%E3%83%BC%E3%83%89%20%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%A9%E3%83%BC%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%20%E3%80%81%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%82%A4%E3%83%B3%E3%82%B6%E3%83%AB%E3%83%BC%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%A4%E3%83%B3%E3%82%B6%E3%83%AB%E3%83%BC%E3%83%97%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%20%E3%83%A2%E3%83%BC%E3%83%89%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E9%96%A2%E6%95%B0%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%99%82%E9%96%93%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_20.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_20.png%22%20style%3D%22width%3A%20366px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72780iF88E4B7D76D65822%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_20.png%22%20alt%3D%22pastedImage_20.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_20.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_21.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_21.png%22%20style%3D%22width%3A%20327px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72831i3B7DC4B8AA69BC3A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_21.png%22%20alt%3D%22pastedImage_21.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_21.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E6%96%B0%E3%81%97%E3%81%84%E6%A9%9F%E8%83%BD%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%80%81%E7%89%B9%E5%BE%B4%E3%80%81%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%B7%BB%E4%BB%98%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%BB%E3%83%8E%E3%83%BC%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%83%BB%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%83%BB%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2300b050%3B%20font-size%3A%2015.0pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%20font-size%3A%2015.0pt%3B%22%3E%3CSTRONG%3EMATLAB%C2%AE%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%206.0pt%200in%204.6pt%200in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3ENXP%20Model-Based%20Design%20Toolbox%20%E3%81%AF%E3%80%81MATLAB%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%C2%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%20%E3%81%8A%E3%82%88%E3%81%B3%20Simulink%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%C2%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%20%E3%81%AE%E4%BD%93%E9%A8%93%E3%82%92%E6%8B%A1%E5%BC%B5%E3%81%97%E3%80%81NXP%20%E3%81%AE%20MPC57xx%20MCU%20%E3%81%8A%E3%82%88%E3%81%B3%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%81%99%E3%81%90%E3%81%AB%E8%A9%95%E4%BE%A1%E3%81%8A%E3%82%88%E3%81%B3%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%22%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23002c14%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206.0pt%3B%20margin-bottom%3A%204.35pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.mathworks.com%2Fmatlabcentral%2Ffileexchange%2F70327-nxp-support-package-mpc57xx%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3ENXP%20Support%20Package%20for%20MPC57xx%3C%2FSPAN%3E%3C%2FA%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3EOnline%20Installer%20Guide%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3EAdd-on%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AFMathwork%E3%81%AEWeb%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E7%9B%B4%E6%8E%A5%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFMATLAB%20IDE%E3%81%8B%E3%82%89%E7%9B%B4%E6%8E%A5NXP%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AF%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%A8%E6%A4%9C%E8%A8%BC%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%90%E3%82%A4%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_23.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_23.png%22%20style%3D%22width%3A%20397px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72367iB77ED536EAB7A20C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_23.png%22%20alt%3D%22pastedImage_23.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_23.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_24.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_24.png%22%20style%3D%22width%3A%20302px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72876iAA5A05B729227A39%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_24.png%22%20alt%3D%22pastedImage_24.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_24.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-top%3A%206pt%3B%20margin-bottom%3A%204.35pt%3B%20text-align%3A%20left%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fnxp.flexnetoperations.com%2Fcontrol%2Ffrse%2Fdownload%3Fagree%3DAccept%26amp%3Belement%3D10769197%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3ENXP%E3%81%AEMPC57xx%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B33.0.0%E7%94%A8%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%20%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%20%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%80%81%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%81%E3%83%98%E3%83%AB%E3%83%97%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AE%E7%82%B9%E3%81%A7MATLAB%C2%AE%E7%92%B0%E5%A2%83%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%20%E3%81%A8%E5%AE%8C%E5%85%A8%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_35.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_35.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72535i6FAB12284324F08C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_35.png%22%20alt%3D%22pastedImage_35.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_35.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_34.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_34.png%22%20style%3D%22width%3A%20348px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F73012iFEE092E07FD578C6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_34.png%22%20alt%3D%22pastedImage_34.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_34.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20%2300b050%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%20font-size%3A%2015.0pt%3B%22%3E%3CSTRONG%3E%E5%AF%BE%E8%B1%A1%E8%80%85%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E3%81%93%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(v.3.0.0)%20%E3%81%AF%E3%80%81MPC574xB%2FC%2FG%2FP%20MCU%20%E3%81%8A%E3%82%88%E3%81%B3%E3%81%9D%E3%82%8C%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E6%8A%80%E8%A1%93%E3%83%87%E3%83%A2%E3%80%81%E8%A9%95%E4%BE%A1%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%97%E3%83%AD%E3%83%88%E3%82%BF%E3%82%A4%E3%83%94%E3%83%B3%E3%82%B0%E3%82%92%E7%9B%AE%E7%9A%84%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22margin-top%3A%200in%3B%22%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-left%3A%20.5in%3B%22%3EDEVKIT-MPC5744P%20PCB%20RevX1%20SCH%20RevB%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-left%3A%20.5in%3B%22%3EDEVKIT-MPC5748G%20PCB%20RevA%20SCH%20RevB%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-left%3A%20.5in%3B%22%3E%E3%83%89%E3%83%BC%E3%82%BF%E3%83%BB%E3%82%AB%E3%83%BC%E3%83%89%20MPC574XG-256DS%20RevB%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-left%3A%20.5in%3B%22%3E%E3%83%89%E3%83%BC%E3%82%BF%E3%82%AB%E3%83%BC%E3%83%89%20X-MPC574XG-324DS%20RevA%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-left%3A%20.5in%3B%22%3E%E3%83%89%E3%83%BC%E3%82%BF%E3%82%AB%E3%83%BC%E3%83%89%20MPC5744P-257DS%20RevB1%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-left%3A%20.5in%3B%22%3E%E3%83%89%E3%83%BC%E3%82%BF%E3%82%AB%E3%83%BC%E3%83%89SPC5746CSK1MKU6%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-left%3A%20.5in%3B%22%3E%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%20X-MPC574XG-MB%20RevD%3C%2FLI%3E%3CLI%20style%3D%22color%3A%20%233b3838%3B%20margin-left%3A%20.5in%3B%22%3E%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%20MPC57XX%20RevC%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%20font-size%3A%2015.0pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%204.6pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%20.25in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22background%3A%20white%3B%20padding%3A%202pt%203pt%3B%20width%3A%20184px%3B%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233b3838%3B%20font-size%3A%2010.0pt%3B%22%3E%3CEM%3E%26nbsp%3B%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22background%3A%20white%3B%20padding%3A%202pt%203pt%3B%20width%3A%20772px%3B%22%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tom%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%812020%E5%B9%B4-%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%A6%E3%81%99%E3%81%BF%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E7%A8%AE%E9%A1%9E%E3%81%A8%E3%80%81%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E4%B8%BB%E3%81%AA%E6%A9%9F%E8%83%BD%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81NXP%E3%81%AE%E3%82%A2%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%E3%81%AB%E9%80%A3%E7%B5%A1%E3%81%97%E3%81%A6%E3%80%81%E5%BD%BC%E3%81%AB%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%A6%81%E4%BB%B6%E3%82%92%E4%BC%9D%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A6%81%E3%81%99%E3%82%8B%E3%81%AB%E3%80%81MPC57xx%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92S32K1xx%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.1.0%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AE%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%E6%9B%B8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Daniel-%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%822020%E5%B9%B4%E7%AC%AC1%E5%9B%9B%E5%8D%8A%E6%9C%9F%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%A8%80%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E6%96%B0%E3%81%97%E3%81%84ECU%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%95%E3%82%89%E3%81%AA%E3%82%8B%E9%96%8B%E7%99%BA%E3%81%AB%E6%B4%BB%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThx-%3C%2FP%3E%3CP%3ETom%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Thomas%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E7%A4%BE%E3%81%AE%E5%86%85%E9%83%A8%E3%83%AD%E3%83%BC%E3%83%89%E3%83%9E%E3%83%83%E3%83%97%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81MBDT%20MPC57xx%203.1.0%3CSPAN%20style%3D%22text-decoration%3A%20line-through%3B%22%3E2019%3C%2FSPAN%3E%E5%B9%B4%E7%AC%AC1%E5%9B%9B%E5%8D%8A%E6%9C%9F%E3%80%812020%E5%B9%B4%E3%81%AB%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%BE%E3%81%A0PRD%E3%82%92%E9%96%89%E3%81%98%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E5%9B%9B%E5%8D%8A%E6%9C%9F%E3%81%AE%E7%B5%82%E3%82%8F%E3%82%8A%E3%81%AB%E5%90%91%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E6%AD%A3%E7%A2%BA%E3%81%AA%E6%97%A5%E4%BB%98%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%89%B9%E3%81%AB%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%E6%9B%B8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fdumitru-daniel.popa%22%20target%3D%22_blank%22%3Edumitru-daniel.popa%3C%2FA%3E!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.1.0%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E4%BA%88%E5%AE%9A%E6%97%A5%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E6%9B%B4%E6%96%B0%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8BMPC5777x%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E8%89%AF-%3C%2FP%3E%3CP%3ETom%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109363%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E7%A7%81%E3%81%AEMatlab%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF2017b%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%93%E3%81%AEMBD_574xx_3.0.0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109362%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109362%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%A2%E3%83%89%E3%82%AA%E3%83%B3%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%93%E3%81%AE%E3%83%93%E3%83%A5%E3%83%BC%E3%82%92%E9%96%8B%E3%81%8F%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%80%8C*.mltbx%E3%80%8D%E3%81%A8%E3%81%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8F%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20678px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64380iB3720C9A6B7A1927%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%7BToolbox%20installation%20directory%7D%5Clic%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%3E%7BToolbox%20installation%20%3C%2FSPAN%3E%3CSPAN%3Edirectory%7D%5Chelp%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80Model_Based_Design_Toolbox_MPC57xx_Series_Licensing_Guide.pdf%E3%81%BE%E3%81%9F%E3%81%AF%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fquick-reference-guide%2FMBDT-MPC57xx_QSG.pdf%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fquick-reference-guide%2FMBDT-MPC57xx_QSG.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fquick-reference-guide%2FMBDT-MPC57xx_QSG.pdf%3C%2FA%3E%20%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE1-7%3C%2FSPAN%3E%E3%81%AB%E3%81%82%E3%82%8B%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%90%E3%82%A4%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EDaniel%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%98%E3%83%AB%E3%83%97%EF%BC%81%EF%BC%81%EF%BC%81%3C%2FP%3E%3CP%3E%E3%80%8Clicense.dat%E3%80%8D%E3%81%AF%E3%81%A9%E3%81%93%E3%81%AB%E7%BD%AE%E3%81%91%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3FMBDToolbox_MPC57xx_3.0.0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%80%8Clic%E3%80%8D%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E5%86%99%E7%9C%9F%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%A7%81%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64345i91A1EFDD76974E16%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%A8%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%B8%E3%81%AE%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E6%8F%90%E6%A1%88%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E8%AA%B0%E3%81%8B%E3%81%8C%E5%B0%8B%E3%81%AD%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AF%E5%B0%86%E6%9D%A5%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E7%86%B1%E5%BF%83%E3%81%AB%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E5%A4%9A%E3%81%8F%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%97%E3%80%81%E7%86%B1%E5%BF%83%E3%81%AB%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81MPC5777C%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6pls%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A0%E3%81%91%E6%97%A9%E3%81%8F%E8%A1%8C%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%20%3CA%20href%3D%22https%3A%2F%2Fmykfcexperience.website%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3Ekfc%E8%AA%BF%E6%9F%BB%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Flucabarbiero%22%20target%3D%22_blank%22%3Elucabarbiero%3C%2FA%3E%E2%80%8C%2C%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81NPX%20SDK%202.0.0%20RTM%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20MPC574x%20%E6%B4%BE%E7%94%9F%E7%89%A9%20B%2FC%2FG%2FP%20%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESDK%20RTM%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%20MPC577x%20%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E3%82%89%E3%80%81Simulink%20%E3%81%AB%E3%82%82%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E3%81%93%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AE%E6%AC%A1%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(3.1.0%20%E3%81%A8%E8%A1%A8%E7%A4%BA)%20%E3%81%A7%E3%81%99%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%E4%BB%8A%E5%BE%8C%E3%80%81%E3%81%93%E3%81%AEMPC5777C%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E4%BB%96%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ELuca%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ER2018A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ER2018B%E3%81%AE%E6%96%B9%E3%81%8C%E5%84%AA%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fhayaoki7%22%20target%3D%22_blank%22%3Ehayaoki7%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8BMATLAB%E3%81%AE%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3FMATLAB%202018b%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fhayaoki7%22%20target%3D%22_blank%22%3Ehayaoki7%3C%2FA%3E%E2%80%8C%2C%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%A8%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AB%E8%88%88%E5%91%B3%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E%E5%89%8D%E8%BF%B0%E3%81%AE%E5%8B%95%E4%BD%9C%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fjira.sw.nxp.com%2Fbrowse%2FAST-1325%22%20title%3D%22https%3A%2F%2Fjira.sw.nxp.com%2Fbrowse%2FAST-1325%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%80%81AST-1325%3C%2FA%3E%E3%81%A8%E3%81%97%E3%81%A6%E5%86%85%E9%83%A8%E7%9A%84%E3%81%AB%E8%BF%BD%E8%B7%A1%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%20(MPC%20%E3%81%A8%20S32K)%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E5%90%8C%E3%81%98%E5%A0%B4%E6%89%80%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E1.%20Matlab%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%5B%E8%A8%AD%E5%AE%9A%5D%20-%20%5B%26gt%3B%20Add-Ons%5D%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%5B%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%5D%E3%81%AE%E4%B8%8B%E3%81%AB%5C%20S32K%E3%81%AE%E5%BE%8C%E3%81%AB%E7%9B%AE%E7%9A%84%E3%81%AE%E5%A0%B4%E6%89%80%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84(C%20%3CEM%3E%3AAddOn%20%5C%20S32K%3C%2FEM%3E%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F)%3C%2FP%3E%3CP%3E2.%20S32K%20%E3%81%AE%20mltbx%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E3.%20Matlab%E3%81%A7%E3%80%81%E3%83%91%E3%82%B9%E3%80%81Pres%20Default%E3%80%81%E4%BF%9D%E5%AD%98%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%5B%20%3CEM%3EC%3A%5C%20AddOns%20%5D%20%5C%20S32K%20%5C%20Toolboxes%20%5C%20NXP_MBDToolbox_S32K1xx%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%3C%2FEM%3E%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%8F%B3%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%80%81%5B%3CEM%3E%20%E3%83%91%E3%82%B9%E3%81%8B%E3%82%89%E5%89%8A%E9%99%A4%5D%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99-%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%A8%E3%82%B5%E3%83%96%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%26gt%3B%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E4.%20%3CSPAN%3EMatlab%E3%81%A7%E3%80%81%5B%E8%A8%AD%E5%AE%9A%5D%20-%20%5B%26gt%3B%20Add-Ons%5D%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%3C%2FSPAN%3E%3C%2FEM%3E%E3%80%81%5B%3CEM%3E%3CSPAN%3E%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FSPAN%3E%3C%2FEM%3E%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%5D%E3%81%A7%E7%9B%AE%E7%9A%84%E3%81%AE%E5%A0%B4%E6%89%80%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CEM%3E%3CSPAN%3E%5C%20MPC%3C%2FSPAN%3E%3C%2FEM%3E%E3%81%8C%E7%B6%9A%E3%81%8D%E3%81%BE%E3%81%99(%E7%A7%81%E3%81%AF%3CEM%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CEM%3EC%3AAddOn%20%5C%20MPC%3C%2FEM%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FEM%3E%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F)%3C%2FP%3E%3CP%3E%3CSPAN%3E5.%20MPC%20%E7%94%A8%E3%81%AE%20mltbx%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E6.%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81MPC%E3%81%AE%E3%81%BF%E3%81%8C%E3%83%91%E3%82%B9%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E7.%20S32K%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81C%3A%5C%20AddOn%20%5C%20S32K%20%5C%20Toolboxes%20%5C%20NXP_MBDToolbox_S32K1xx%20%5C%20code%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81mbd_s32k_path.m%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%91%E3%82%B9%E3%81%AB%20S32K%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%82%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%8C%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81Matlab%E3%81%AE%E3%83%91%E3%82%B9%E3%81%8B%E3%82%89%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81S32K%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%91%E3%82%B9%E3%81%AB%20MPC%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AE%E3%81%BF%E3%82%92%E4%BF%9D%E6%8C%81%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E9%80%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E7%95%AA%E5%8F%B73%E3%81%8B%E3%82%89%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%91%E3%82%B9%E3%81%8B%E3%82%89%E5%89%8A%E9%99%A4%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81MPC%E3%81%A8S32K%E3%81%AF%E5%90%8C%E3%81%98%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%91%BD%E4%BB%A47%E3%82%92%E4%BB%BB%E6%84%8F%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%82%8A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EMarius!%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1109353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EMPC57xx%20Automotive%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%203.0.0%20%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%83%99%E3%83%BC%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%20%E3%83%84%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9S32K%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%AF%E3%82%A2%E3%83%B3%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎02-18-2019 07:23 AM
更新者:
