Hi, deniel. I have a problem about the nxpt_codegen() here.
I configured my envirement step by step following this attached instrument, and I did complete the there vision applications of 3.2.
But when I went to Chapter3 -- Face Detection on S32V234 Vision Processor, after I invoked run_face_detection_camera_main.m in MATLAB console, errors were reported as follows. I couldn't find the cause nor solution of this probelm, is there something wrong of my GNU/APU? I hope you can give some advice. Thank you very much.
Hi [email protected],
Can you try to apply HotFix_1 and and try again?
Also I want to know which Matlab version are you using?
Hi, Paul,
I'm using Matlab 2018a.
And I've tried the new nxpvt_build.p you provided, but it doesn't work either. But the errors seems a little bit different from before.
Can you copy the entire output from Matlab console window and paste it here?
