SuperTinyKernel (STK) - lightweight embedded multi/single-core multithreading for NXP Cortex-M MCUs
neutroncode
Hi NXP Devs!
Not really a question here. I would like to introduce a thread scheduling library - SuperTinyKernel (STK).
Its GitHub repo: https://github.com/dmitrykos/stk
You can check capabilities in detail on GitHub but briefly STK can:
  • Soft and hard real-time support: STK supports cooperative scheduling for “soft real-time” tasks, you can also enable hard real-time mode (KERNEL_HRT) for periodic tasks with guaranteed deadlines.
  • Static and dynamic tasks: Define all tasks at startup (KERNEL_STATIC) or allow tasks to be created and destroyed at runtime (KERNEL_DYNAMIC).
  • Low-power friendliness: STK puts MCU into a low-power mode when there are no runnable tasks (task calls Sleep).
  • Tiny footprint: Minimal C++ abstractions (no STL, no heavy namespaces) keep the kernel small and simple.
  • Portability: Supports any ARM Cortex-M MCU.
  • Multi-core support: Fully implemented for Cortex-M and RISC-V.
  • x86 development mode: Compile & debug your code on a PC before flashing to the MCU, which helps with early testing and unit tests.
  • Open-source License: MIT: Open for commercial, closed-source, open-source - your choice.
There are ready to use MCUXpresso examples for NXP K26/K66 MCU (FRDM-K66F dev board) and i.MX RT105 (IMXRT1050-EVKB dev board): https://github.com/dmitrykos/stk/tree/main/build/example/project/nxp-mcuxpresso
Any questions? Please ask, also you are welcome to participate in STK's GitHub repository.
neutroncode
Since the initial post there was an active development happening on STK and it has grown to a more convenient tool for embedded development, so wanted to highlight the progress:
  • Scheduling strategies: Besides existing Round-Robin (RR) new scheduling strategies were added: Fixed-Priority (FP, similar to FreeRTOS), Smooth Weighted Round-Robin (SWRR), Rate-Monotonic (RM), Deadline-Monotonic (DM), including Worst Case Reaction Time (WCRT) analysis, Earliest Deadline First (EDF), custom (via ITaskSwitchStrategy). It is probably the only open-source scheduler that has such a rich set of scheduling strategies.
  • Synchronization API: Besides CriticalSection there is a set of synchronization primitives now: SpinLock, Mutex, Event, ConditionVariable, Semaphore, Pipe primitives for inter-task, inter-core synchronization. Synchronization is optional via KERNEL_SYNC kernel mode, so it does not bloat FLASH/RAM.
  • Traceability: STK now supports tracing of tasks scheduling with a SEGGER SystemView.
  • C interface: For C-only projects STK got a fully-featured C interface.
If there are any questions, please ask!
%3CLINGO-SUB%20id%3D%22lingo-sub-2253453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESuperTinyKernel%20(STK)%20-%20lightweight%20embedded%20multi%2Fsingle-core%20multithreading%20for%20NXP%20Cortex-M%20MCUs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2253453%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%20Devs!%3C%2FP%3E%3CP%3ENot%20really%20a%20question%20here.%26nbsp%3B%3CSPAN%3EI%20would%20like%20to%20introduce%20a%20thread%20scheduling%20library%20-%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ESuperTinyKernel%20(STK)%3C%2FSTRONG%3E%3CSPAN%3E.%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EIts%20GitHub%20repo%3A%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fdmitrykos%2Fstk%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fdmitrykos%2Fstk%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EYou%20can%20check%20capabilities%20in%20detail%20on%20GitHub%20but%20briefly%20STK%20can%3A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3ESoft%20and%20hard%20real-time%20support%3C%2FSTRONG%3E%3A%20STK%20supports%20cooperative%20scheduling%20for%20%E2%80%9Csoft%20real-time%E2%80%9D%20tasks%2C%20you%20can%20also%20enable%20hard%20real-time%20mode%20(KERNEL_HRT)%20for%20periodic%20tasks%20with%20guaranteed%20deadlines.%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EStatic%20and%20dynamic%20tasks%3C%2FSTRONG%3E%3A%20Define%20all%20tasks%20at%20startup%20(KERNEL_STATIC)%20or%20allow%20tasks%20to%20be%20created%20and%20destroyed%20at%20runtime%20(KERNEL_DYNAMIC).%3C%2FLI%3E%3CLI%3E%3CSTRONG%3ELow-power%20friendliness%3C%2FSTRONG%3E%3A%20STK%20puts%20MCU%20into%20a%20low-power%20mode%20when%20there%20are%20no%20runnable%20tasks%20(task%20calls%20Sleep).%3C%2FLI%3E%3CLI%3E%3CSTRONG%3ETiny%20footprint%3C%2FSTRONG%3E%3A%20Minimal%20C%2B%2B%20abstractions%20(no%20STL%2C%20no%20heavy%20namespaces)%20keep%20the%20kernel%20small%20and%20simple.%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EPortability%3C%2FSTRONG%3E%3A%20Supports%20any%20ARM%20Cortex-M%20MCU.%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EMulti-core%20support%3C%2FSTRONG%3E%3A%20Fully%20implemented%20for%20Cortex-M%20and%20RISC-V.%3C%2FLI%3E%3CLI%3E%3CSTRONG%3Ex86%20development%20mode%3C%2FSTRONG%3E%3A%20Compile%20%26amp%3B%20debug%20your%20code%20on%20a%20PC%20before%20flashing%20to%20the%20MCU%2C%20which%20helps%20with%20early%20testing%20and%20unit%20tests.%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EOpen-source%20License%3A%20MIT%3C%2FSTRONG%3E%3A%20Open%20for%20commercial%2C%20closed-source%2C%20open-source%20-%20your%20choice.%3C%2FLI%3E%3C%2FUL%3E%3CP%3EThere%20are%20ready%20to%20use%20MCUXpresso%20examples%20for%20%3CSTRONG%3ENXP%20K26%2FK66%20MCU%3C%2FSTRONG%3E%20(FRDM-K66F%20dev%20board)%20and%20%3CSTRONG%3Ei.MX%20RT105%3C%2FSTRONG%3E%20(IMXRT1050-EVKB%20dev%20board)%3A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fdmitrykos%2Fstk%2Ftree%2Fmain%2Fbuild%2Fexample%2Fproject%2Fnxp-mcuxpresso%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fdmitrykos%2Fstk%2Ftree%2Fmain%2Fbuild%2Fexample%2Fproject%2Fnxp-mcuxpresso%3C%2FA%3E%3C%2FP%3E%3CP%3EAny%20questions%3F%20Please%20ask%2C%20also%20you%20are%20welcome%20to%20participate%20in%20STK's%20GitHub%20repository.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2303157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SuperTinyKernel%20(STK)%20-%20lightweight%20embedded%20multi%2Fsingle-core%20multithreading%20for%20NXP%20Cortex-M%20M%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2303157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESince%20the%20initial%20post%20there%20was%20an%20active%20development%20happening%20on%20STK%20and%20it%20has%20grown%20to%20a%20more%20convenient%20tool%20for%20embedded%20development%2C%20so%20wanted%20to%20highlight%20the%20progress%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EScheduling%20strategies%3C%2FSTRONG%3E%3A%20Besides%20existing%20%3CEM%3ERound-Robin%20(RR)%3C%2FEM%3E%20new%20scheduling%20strategies%20were%20added%3A%26nbsp%3B%3CEM%3EFixed-Priority%3C%2FEM%3E%20(FP%2C%20similar%20to%20FreeRTOS)%2C%20%3CEM%3ESmooth%20Weighted%20Round-Robin%3C%2FEM%3E%20(SWRR)%2C%20%3CEM%3ERate-Monotonic%3C%2FEM%3E%20(RM)%2C%20%3CEM%3EDeadline-Monotonic%3C%2FEM%3E%20(DM)%2C%20including%20Worst%20Case%20Reaction%20Time%20(WCRT)%20analysis%2C%20%3CEM%3EEarliest%20Deadline%20First%3C%2FEM%3E%20(EDF)%2C%20custom%20(via%20ITaskSwitchStrategy).%20It%20is%20probably%20the%20only%20open-source%20scheduler%20that%20has%20such%20a%20rich%20set%20of%20scheduling%20strategies.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3ESynchronization%20API%3C%2FSTRONG%3E%3A%20Besides%20%3CEM%3ECriticalSection%3C%2FEM%3E%20there%20is%20a%20set%20of%20synchronization%20primitives%20now%3A%20%3CEM%3ESpinLock%3C%2FEM%3E%2C%20%3CEM%3EMutex%3C%2FEM%3E%2C%20%3CEM%3EEvent%3C%2FEM%3E%2C%20%3CEM%3EConditionVariable%3C%2FEM%3E%2C%20%3CEM%3ESemaphore%3C%2FEM%3E%2C%20%3CEM%3EPipe%3C%2FEM%3E%20primitives%20for%20inter-task%2C%20inter-core%20synchronization.%20Synchronization%20is%20optional%20via%20KERNEL_SYNC%20kernel%20mode%2C%20so%20it%20does%20not%20bloat%20FLASH%2FRAM.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3ETraceability%3C%2FSTRONG%3E%3A%20STK%20now%20supports%20tracing%20of%20tasks%20scheduling%20with%20a%20%3CEM%3ESEGGER%20SystemView%3C%2FEM%3E.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EC%20interface%3C%2FSTRONG%3E%3A%20For%20C-only%20projects%20STK%20got%20a%20fully-featured%20C%20interface.%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EIf%20there%20are%20any%20questions%2C%20please%20ask!%3C%2FP%3E%3C%2FLINGO-BODY%3E
