Question on UCODE 8 behavior under auxiliary CW interference during reader communication
Zhy889
Dear NXP Technical Support Team,
I am currently conducting academic research on passive UHF RFID systems and would like to consult you regarding an observed behavior of the NXP UCODE 8 tag under a specific RF excitation condition.
In our experiments, during normal EPC Gen2 reader–tag communication, we introduce an additional continuous-wave (CW) signal at a different carrier frequency (no data information) from a USRP device. When the auxiliary CW has relatively high power, we observe that:
UCODE 8 tags fail to correctly decode reader commands and the communication breaks down.
In contrast, under the same experimental setup, Impinj Monza 4 tags can still maintain communication and, in some cases, show extended readable distance.
We understand that EPC Gen2 tags are designed for single-carrier operation and that auxiliary CW signals are outside standard operating assumptions. However, we are interested in understanding whether this difference may be related to implementation-level differences, such as:
a. RF front-end selectivity or matching bandwidth
b. Rectifier or envelope detector nonlinearity
c. Downlink demodulation architecture (e.g., envelope detection, filtering, timing recovery robustness)
d. On-chip filtering or interference suppression mechanisms
Our question is not about protocol compliance, but rather about whether UCODE 8 has known sensitivities to strong out-of-band CW signals, or if there are architectural characteristics that could explain the observed decoding failure compared to other Gen2 tags.
Any insight you could share at a high level (even without revealing proprietary details) would be greatly appreciated and very helpful for correctly interpreting our experimental results.
Thank you very much for your time and support.
%3CLINGO-SUB%20id%3D%22lingo-sub-2265054%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EQuestion%20on%20UCODE%208%20behavior%20under%20auxiliary%20CW%20interference%20during%20reader%20communication%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265054%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20NXP%20Technical%20Support%20Team%2C%3C%2FP%3E%3CP%3EI%20am%20currently%20conducting%20academic%20research%20on%20passive%20UHF%20RFID%20systems%20and%20would%20like%20to%20consult%20you%20regarding%20an%20observed%20behavior%20of%20the%20%3CSTRONG%3ENXP%20UCODE%208%20%3C%2FSTRONG%3Etag%20under%20a%20specific%20RF%20excitation%20condition.%3C%2FP%3E%3CP%3EIn%20our%20experiments%2C%20during%20normal%20EPC%20Gen2%20reader%E2%80%93tag%20communication%2C%20we%20introduce%20an%20%3CSTRONG%3Eadditional%20continuous-wave%20(CW)%20signal%20at%20a%20different%20carrier%20frequency%3C%2FSTRONG%3E%26nbsp%3B(no%20data%20information)%20from%20a%20USRP%20device.%20When%20the%20auxiliary%20CW%20has%20relatively%20high%20power%2C%20we%20observe%20that%3A%3C%2FP%3E%3CP%3EUCODE%208%20tags%20fail%20to%20correctly%20decode%20reader%20commands%20and%20the%20communication%20breaks%20down.%3C%2FP%3E%3CP%3EIn%20contrast%2C%20under%20the%20same%20experimental%20setup%2C%20%3CSTRONG%3EImpinj%20Monza%204%3C%2FSTRONG%3E%20tags%20can%20still%20maintain%20communication%20and%2C%20in%20some%20cases%2C%20show%20extended%20readable%20distance.%3C%2FP%3E%3CP%3EWe%20understand%20that%20EPC%20Gen2%20tags%20are%20designed%20for%20single-carrier%20operation%20and%20that%20auxiliary%20CW%20signals%20are%20outside%20standard%20operating%20assumptions.%20However%2C%20we%20are%20interested%20in%20understanding%20whether%20this%20difference%20may%20be%20related%20to%20%3CSTRONG%3Eimplementation-level%20differences%3C%2FSTRONG%3E%2C%20such%20as%3A%3C%2FP%3E%3CP%3Ea.%20RF%20front-end%20selectivity%20or%20matching%20bandwidth%3C%2FP%3E%3CP%3Eb.%20Rectifier%20or%20envelope%20detector%20nonlinearity%3C%2FP%3E%3CP%3Ec.%20Downlink%20demodulation%20architecture%20(e.g.%2C%20envelope%20detection%2C%20filtering%2C%20timing%20recovery%20robustness)%3C%2FP%3E%3CP%3Ed.%20On-chip%20filtering%20or%20interference%20suppression%20mechanisms%3C%2FP%3E%3CP%3EOur%20question%20is%20%3CSTRONG%3Enot%20about%20protocol%20compliance%3C%2FSTRONG%3E%2C%20but%20rather%20about%20whether%20UCODE%208%20has%20known%20sensitivities%20to%20strong%20out-of-band%20CW%20signals%2C%20or%20if%20there%20are%20architectural%20characteristics%20that%20could%20explain%20the%20observed%20decoding%20failure%20compared%20to%20other%20Gen2%20tags.%3C%2FP%3E%3CP%3EAny%20insight%20you%20could%20share%20at%20a%20high%20level%20(even%20without%20revealing%20proprietary%20details)%20would%20be%20greatly%20appreciated%20and%20very%20helpful%20for%20correctly%20interpreting%20our%20experimental%20results.%3C%2FP%3E%3CP%3EThank%20you%20very%20much%20for%20your%20time%20and%20support.%3C%2FP%3E%3C%2FLINGO-BODY%3E
