Question on UCODE 8 behavior under auxiliary CW interference during reader communication
Zhy889
Dear NXP Technical Support Team,
I am currently conducting academic research on passive UHF RFID systems and would like to consult you regarding an observed behavior of the NXP UCODE 8 tag under a specific RF excitation condition.
In our experiments, during normal EPC Gen2 reader–tag communication, we introduce an additional continuous-wave (CW) signal at a different carrier frequency (no data information) from a USRP device. When the auxiliary CW has relatively high power, we observe that:
UCODE 8 tags fail to correctly decode reader commands and the communication breaks down.
In contrast, under the same experimental setup, Impinj Monza 4 tags can still maintain communication and, in some cases, show extended readable distance.
We understand that EPC Gen2 tags are designed for single-carrier operation and that auxiliary CW signals are outside standard operating assumptions. However, we are interested in understanding whether this difference may be related to implementation-level differences, such as:
a. RF front-end selectivity or matching bandwidth
b. Rectifier or envelope detector nonlinearity
c. Downlink demodulation architecture (e.g., envelope detection, filtering, timing recovery robustness)
d. On-chip filtering or interference suppression mechanisms
Our question is not about protocol compliance, but rather about whether UCODE 8 has known sensitivities to strong out-of-band CW signals, or if there are architectural characteristics that could explain the observed decoding failure compared to other Gen2 tags.
Any insight you could share at a high level (even without revealing proprietary details) would be greatly appreciated and very helpful for correctly interpreting our experimental results.
Thank you very much for your time and support.
