PPS Latency in P3041
1,426 次查看
LordStark3232
I am using pps on P3041 to generate periodic pulses. I updated period as 10 ms from kernel codes. But on oscilloscope I am seeing pulses 10 ms + ~200 ns. Is it known issues or logical? Should I expect 10 ms correct precision? (Side note I am using system clk as a source clk.)
Also there are some sources reletad to slave pps signal not correctly phase alligned with master source. Is it related to my problem?
Thank you
0 回复数
