NFC PN7150 will produce beep sound while reading ?
3,998 次查看
karthikeyanraju
I have used PN7150 module integrated with android Nougat 7.1.2.
I have followed below mentioned procedure provided by NXP.
GitHub - NXPNFCLinux/nxpnfc_android_pie: Android patches for support of PN7150 NCI based NXP NFC Con...
This works fine for our platform to read the NFC cards, Here I want to know how to enable a sound while a card read.
Will it has the support with these patches ? or What is the procedure to enable the sound ?
Please provide the solution as soon as possible.
标签 (1)
标记 (1)
5 回复数
3,871 次查看
jimmychan
I think the Android is running on a MCU/MPU. The beep sound should be controlled by the MCU/MPU. e.g. the beep sound from a buzzer. The beep sound from the buzzer can be controlled by GPIO output 1/0.
3,871 次查看
karthikeyanraju
Hi jimmychan,
We have external speaker connected to our board & it has the capability to play the audio files.
Can you please mention with audio file will be played when the NFC read & where it is located ?
This will help us for the further debugging.
Thanks for the reply.
3,871 次查看
karthikeyanraju
Can you please share the information related to the GPIO (number) which is connected to the buzzer & the connection procedure ?
3,871 次查看
jimmychan
Which MCU or MPU you used for running Android? You should check your Android SDK and porting guide . e.g. add the GPIO support in device tree file for your MPU/MCU. This is not related to PN7150.
3,871 次查看
karthikeyanraju
Hi jimmychan,
We are using Qualcomm APQ8909 for our project. Can you please share PN7150 DTS with buzzer configuration ?
