MIFARE DESFire EV1 vs EV2
4,255 次查看
wilmer_suarez
I'm currently working on a project where I need to detect EV1 & EV2 cards. I'm using an STM32F207 (Cortex-m3) MCU and a TI TRF7970A as the RFID reader. I just wanted to know what the differences between the EV1 & EV2 cards are in terms of the detection requirements. The system I've set up is able to detect the EV2 cards seamlessly; but not the EV1 cards. Any Idea why this is happening?
Thank you!
标记 (3)
3,802 次查看
stephanie_m
Please consider that the MIFARE DESFire EV2 is backwards with EV1 so it can be used as a MIFARE DESFire EV1 in its default delivery configuration, still here are some commands and processes that might vary between both of them .
Still, as you might know,  there are some of the documents and libraries which are under NDA (Non-Disclosure Agreement) and placed in docstore, could you please follow this guides?
Docstore tutorial part 1: User Registration|NXP
https://www.nxp.com/video/docstore-tutorial-part-1-user-registration:DOCSTORE-USER-REGISTRATION
Docstore tutorial part 2: portal usage|NXP
https://www.nxp.com/video/docstore-tutorial-part-2-portal-usage:DOCSTORE-TUTORIAL-PORTAL-USAGE
Also, you will need to contact one of our distributors available in the  Distributor Network|NXP to help you through the NDA process.
https://www.nxp.com/support/sample-buy/distributor-network:DISTRIBUTORS
Estephania
