Bluetooth gateway
Bluetooth gateway
3,710件の閲覧回数
shahajas
Can i connect rapid iot to bluetooth gateway by setting rapid iot kit in beacon mode
3,458件の閲覧回数
atulprajapati
Modular IoT Gateway (SLN-IOT-GPI) https://www.mouser.com/pdfdocs/Modular_Gateway_UG.pdf has BLE, so it should work fine right?
3,598件の閲覧回数
Fabian_R
Hello Shahajas UT,
You can receive data from the Rapid IoT in your gateway; but, this won't be a proper connection. The gateway must be in listening mode all the time and It won't be an ACK between your devices. Your gateway needs to be able to understand the string the Rapid IoT is sending in beacon mode.
Have in mind the Rapid IoT is BLE so your gateway must be BLE too.
Regards, Fabian.
Fabian
