S32G3_Standby_QSPIPowerDown
Comments
你好,john:
能否分享一下你基于S32DS配置的的工程呢.
只有EB的工程
你好,john:
我用你的附件的bin文件烧录到S32G3中,通过串口调试,发现输入字符"y"之后,电流确实从正常模式的0.4A下降到了0.02A,但是我测量了Pmic的STBY和STBY_PGOOD,均为3.3V,FCCU2的电压从3.3V下降到了0.38V,所以这个现象和您在文档中说的不是很一致,麻烦还请给我解答一下疑惑,谢谢
以下是我是用的bin文件
%3CLINGO-SUB%20id%3D%22lingo-sub-1824728%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ES32G3_Standby_QSPIPowerDown%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1824728%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%0A%3CP%3EThis%20article%20describes%20the%20S32G3%20M7%20core%20Standby%20MCAL%3CBR%20%2F%3E%20Demo%20details%20and%20customization%2C%20and%3CBR%20%2F%3E%20call%20the%20QSPI%20interface%20to%20configure%20the%20QSPI%20NOR%20flash%20before%20entering%20Standby%3CBR%20%2F%3E%20Deep%20power%20down%20mode%20to%20save%20power.%3C%2FP%3E%0A%3CP%3ETable%20of%20contents%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046788%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E1%20References...%202%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046789%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E2%20The%20difference%20between%20G2%20and%20G3%20Demo...%202%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046790%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E3%20Implementation%20of%20G3%20MCAL%20Demo...%204%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046791%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E3.1%20Modify%20UART%20driver...%204%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046792%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E3.2%20Implementing%20the%20clock%20shutdown%20code...%204%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046793%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E3.3%20Configuring%20the%20Power%20Mode%20Switching%20Driver...%205%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046794%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E3.4%20Configuring%20wake-up%20sources...%205%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046795%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E3.5%20Add%20PMIC%20driver...%206%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046796%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E3.6%20Main%20function%20logic%20implementation...%207%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046797%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E3.7%20Running%20Tests...%207%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046798%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E3.8%20Future%20Development%20Plans...%208%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046799%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E4%20Set%20QSPI%20NOR%20to%20Deep%20Power%20Down%20mode...%208%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046800%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E4.1%20Modification%20of%20Fls%20layer...%2010%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046801%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E4.2%20Modification%20of%20the%20middle%20layer...%2010%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046802%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E4.3%26nbsp%3B%20QSPI_IP%E5%B1%82%E7%9A%84%E4%BF%AE%E6%94%B9...%2013%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046803%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E4.4%20Main%20test%20function%20call...%2016%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046804%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E4.5%20Fls%20driver%20test...%2017%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046805%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E5%20Integrate%20the%20Deep%20Power%20Down%20function%20into%20the%20STANDBY%20project%20and%20test%20it%2018%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046806%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E5.1%26nbsp%3B%20EB%E9%85%8D%E7%BD%AE...%2018%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046807%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E5.2%20Main%20test%20function%20and%20compilation%20modification...%2020%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22%23_Toc161046808%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E5.3%20Running%20Tests...%2021%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1824728%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAutomotive%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1980946%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3_Standby_QSPIPowerDown%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1980946%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20John%3A%3C%2FP%3E%3CP%3EI%20burned%20the%20bin%20file%20in%20your%20attachment%20into%20S32G3.%20Through%20serial%20port%20debugging%2C%20I%20found%20that%20after%20inputting%20the%20character%20%22y%22%2C%20the%20current%20did%20drop%20from%200.4A%20in%20normal%20mode%20to%200.02A.%20However%2C%20I%20measured%20the%20STBY%20and%20STBY_PGOOD%20of%20Pmic%2C%20both%20of%20which%20were%203.3V.%20The%20voltage%20of%20FCCU2%20dropped%20from%203.3V%20to%200.38V.%20So%20this%20phenomenon%20is%20not%20consistent%20with%20what%20you%20said%20in%20the%20document.%20Please%20answer%20my%20doubts.%20Thank%20you.%3C%2FP%3E%3CP%3EThe%20following%20is%20the%20bin%20file%20I%20used%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jiajun_cheng_0-1729754195865.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jiajun_cheng_0-1729754195865.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F306686i3E7282E94E3F4FDB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jiajun_cheng_0-1729754195865.png%22%20alt%3D%22jiajun_cheng_0-1729754195865.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ejiajun_cheng_0-1729754195865.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979122%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3_Standby_QSPIPowerDown%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979122%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EOnly%20EB's%20engineering%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979069%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32G3_Standby_QSPIPowerDown%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979069%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20John%3A%3C%2FP%3E%3CP%3ECan%20you%20share%20your%20project%20based%20on%20S32DS%20configuration%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
100% helpful (1/1)
Version history
Last update:
‎03-10-2024 08:46 PM
Updated by:
