This doc expain how to use eMMC from user space, contents as follows:
目录
1 eMMC的分区情况 ...................................................... 2
2 S32G+BSP29上默认的eMMC启动 ............................ 3
2.1 eMMC硬件设计 .................................................. 3
2.2 eMMC的镜像烧写办法与启动 ............................. 6
2.3 增加MMC内核测试工具 .................................... 10
3 eMMC GP功能的测试 .............................................. 10
3.1 eMMC GP功能的说明 ....................................... 10
3.2 eMMC GP功能的测试 ....................................... 11
4 eMMC RPMB功能的测试 ......................................... 13
4.1 eMMC RPMB功能的说明 ................................. 13
4.2 eMMC RPMB功能的测试 ................................. 15
Hi, @Johnli :
您好,我参考了你的文章,有个问题想要请教下您
在下面这张图片中的"/media/vmuser/temp/"这个是你的SD卡的路径吗,因为我看我的SD卡路径都是/dev/sdb1,/dev/sdb2, /dev/sdb3这种的,还请指导一下怎么选择这个路径,谢谢
which is running on ubuntu PC, to copy image into sdcard related folder.
