RDDSCPMSMVC: PMSM Vector Control with Single-Shunt Current-Sensing Reference Design Using MC56F8013/23
Overview
This application creates a vector control PMSM drive with optional speed closed-loop using a quadrature encoder, and serves as an example of a PMSM vector control system design based on the cost-effective 32-MIPS NXP® digital signal controller MC56F80XX.
  • Dedicated algorithms such as transformations, PI controllers and space vector modulation, are implemented using NXP’s Motor Control Library
  • This cost-effective and highly reliable solution minimizes system cost, as the algorithm implements a single shunt current sensing, reducing 3 current sensors to one
  • The reference manual provides a detailed description of the application, including the design of the hardware and the software
Features
  • Designed to fit into consumer and industrial applications
  • Uses 56F8013 or 56F8023 32 MIPS Digital Signal Controller
  • Running on a 3-phase High Voltage Power Stage
  • Vector control of PMSM using theQuadrature Encoder as a position sensor
  • Control technique incorporates:
    • Vector control with speed closed-loop with position encoder
    • Rotation in both direction
    • Start from any motor position with rotor alignment
    • 4-quadrant operation
    • Reconstruction of three-phase motor currents from DC-Bus shunt resistor
    • Wide speed range
  • FreeMASTER Control Interface
  • Fault protection - overcurrent, overvoltage, undervoltage
Block Diagram
Board
Design Resources
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1102182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERDDSCPMSMVC%3A%20MC56F8013%2F23%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E9%9B%BB%E6%B5%81%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%B0%E6%A9%9F%E8%83%BD%E4%BB%98%E3%81%8D%20PMSM%20%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%88%B6%E5%BE%A1%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1102182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCPMSMVC-PMSM-Vector-Control-with-Single-Shunt-Current%2Fta-p%2F1102182%23toc-hId-380545768%22%20target%3D%22_blank%22%3EOverview%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCPMSMVC-PMSM-Vector-Control-with-Single-Shunt-Current%2Fta-p%2F1102182%23toc-hId--1426908695%22%20target%3D%22_blank%22%3E%E7%89%B9%E9%95%B7%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCPMSMVC-PMSM-Vector-Control-with-Single-Shunt-Current%2Fta-p%2F1102182%23toc-hId-1060604138%22%20target%3D%22_blank%22%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%9B%B3%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCPMSMVC-PMSM-Vector-Control-with-Single-Shunt-Current%2Fta-p%2F1102182%23toc-hId--746850325%22%20target%3D%22_blank%22%3E%E3%83%9C%E3%83%BC%E3%83%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCPMSMVC-PMSM-Vector-Control-with-Single-Shunt-Current%2Fta-p%2F1102182%23toc-hId-1740662508%22%20target%3D%22_blank%22%3E%E8%A8%AD%E8%A8%88%E3%83%BB%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-380545768%22%20id%3D%22toc-hId-1304184761%22%3EOverview%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E7%9B%B4%E4%BA%A4%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E9%80%9F%E5%BA%A6%E9%96%89%E3%83%AB%E3%83%BC%E3%83%97%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%88%B6%E5%BE%A1PMSM%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%82%B3%E3%82%B9%E3%83%88%E5%8A%B9%E7%8E%87%E3%81%AE%E9%AB%98%E3%81%8432MIPS%E3%81%AENXP%C2%AE%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E4%BF%A1%E5%8F%B7%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9MC56F80XX%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FPMSM%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%88%B6%E5%BE%A1%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E8%A8%AD%E8%A8%88%E3%81%AE%E4%B8%80%E4%BE%8B%E3%81%A8%E3%81%97%E3%81%A6%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%A4%89%E6%8F%9B%E3%80%81PI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%80%81%E7%A9%BA%E9%96%93%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%A4%89%E8%AA%BF%E3%81%AA%E3%81%A9%E3%81%AE%E5%B0%82%E7%94%A8%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AF%E3%80%81NXP%E3%81%AE%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3E%E3%81%93%E3%81%AE%E8%B2%BB%E7%94%A8%E5%AF%BE%E5%8A%B9%E6%9E%9C%E3%81%8C%E9%AB%98%E3%81%8F%E4%BF%A1%E9%A0%BC%E6%80%A7%E3%81%AE%E9%AB%98%E3%81%84%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%8C%E5%8D%98%E4%B8%80%E3%81%AE%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E9%9B%BB%E6%B5%81%E6%A4%9C%E5%87%BA%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%80%813%E3%81%A4%E3%81%AE%E9%9B%BB%E6%B5%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%921%E3%81%A4%E3%81%AB%E6%B8%9B%E3%82%89%E3%81%99%E3%81%9F%E3%82%81%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B3%E3%82%B9%E3%83%88%E3%82%92%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AB%E6%8A%91%E3%81%88%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3E%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%A8%AD%E8%A8%88%E3%81%AA%E3%81%A9%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%AC%E6%98%8E%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1426908695%22%20id%3D%22toc-hId--503269702%22%3E%E7%89%B9%E9%95%B7%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E6%B0%91%E7%94%9F%E7%94%A8%E3%81%8A%E3%82%88%E3%81%B3%E7%94%A3%E6%A5%AD%E7%94%A8%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E9%81%A9%E5%90%88%E3%81%99%E3%82%8B%E8%A8%AD%E8%A8%88%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E56F8013%E3%81%BE%E3%81%9F%E3%81%AF56F8023%2032%20MIPS%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E4%BF%A1%E5%8F%B7%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E3%E7%9B%B8%E9%AB%98%E9%9B%BB%E5%9C%A7%E9%9B%BB%E5%8A%9B%E6%AE%B5%E3%81%A7%E5%8B%95%E4%BD%9C%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E4%BD%8D%E7%9B%B8%E5%B7%AE%E5%87%BA%E5%8A%9B%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%82%92%E4%BD%8D%E7%BD%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%A8%E3%81%97%E3%81%A6%E7%94%A8%E3%81%84%E3%81%9FPMSM%E3%81%AE%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%88%B6%E5%BE%A1%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E5%88%B6%E5%BE%A1%E6%8A%80%E8%A1%93%E3%81%AB%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%8C%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style%3A%20none%3B%22%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E9%80%9F%E5%BA%A6%E4%BB%98%E3%81%8D%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%88%B6%E5%BE%A1%2C%20%E3%82%AF%E3%83%AD%E3%83%BC%E3%82%BA%E3%83%89%E3%83%AB%E3%83%BC%E3%83%97%2C%20%E4%BD%8D%E7%BD%AE%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC%E4%BB%98%E3%81%8D%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E4%B8%A1%E6%96%B9%E5%90%91%E3%81%AE%E5%9B%9E%E8%BB%A2%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E3%83%AD%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E4%BB%BB%E6%84%8F%E3%81%AE%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E4%BD%8D%E7%BD%AE%E3%81%8B%E3%82%89%E5%A7%8B%E5%8B%95%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E4%E8%B1%A1%E9%99%90%E5%8B%95%E4%BD%9C%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3EDC%E3%83%90%E3%82%B9%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E6%8A%B5%E6%8A%97%E3%81%8B%E3%82%89%E3%81%AE%E4%B8%89%E7%9B%B8%E3%83%A2%E3%83%BC%E3%82%BF%E9%9B%BB%E6%B5%81%E3%81%AE%E5%86%8D%E6%A7%8B%E6%88%90%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E5%BA%83%E3%81%84%E9%80%9F%E5%BA%A6%E7%AF%84%E5%9B%B2%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3EFreeMASTER%E3%82%92%E5%88%A9%E7%94%A8%E3%81%97%E3%81%9F%E5%88%B6%E5%BE%A1%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%20%20%20%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E9%9A%9C%E5%AE%B3%E4%BF%9D%E8%AD%B7%20-%20%E9%81%8E%E9%9B%BB%E6%B5%81%E3%80%81%E9%81%8E%E9%9B%BB%E5%9C%A7%E3%80%81%E4%BD%8E%E9%9B%BB%E5%9C%A7%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1060604138%22%20id%3D%22toc-hId-1984243131%22%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%9B%B3%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223606_RDDSCPMSMVC_BD.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223606_RDDSCPMSMVC_BD.jpg%22%20style%3D%22width%3A%20563px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110369i3D752A507000718D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%223606_RDDSCPMSMVC_BD.jpg%22%20alt%3D%223606_RDDSCPMSMVC_BD.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--746850325%22%20id%3D%22toc-hId-176788668%22%3E%E3%83%9C%E3%83%BC%E3%83%89%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PMSMVCDEMO.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PMSMVCDEMO.jpg%22%20style%3D%22width%3A%20500px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110356i021A4EADB5398D38%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22PMSMVCDEMO.jpg%22%20alt%3D%22PMSMVCDEMO.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1740662508%22%20id%3D%22toc-hId--1630665795%22%3E%E8%A8%AD%E8%A8%88%E3%83%BB%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1102182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎08-09-2020 07:24 PM
更新者:
