RDDSCACIMVC: 3-Phase AC Induction Vector Control Drive Current Sensing Reference Design
Overview
This reference design enables development of a vector control algorithm for a three-phase AC induction motor implemented on NXP® digital signal controllers MC56F8013/MC56F8023.
  • Targeted mainly at consumer and industrial applications
  • Cost-effective and highly reliable, the algorithm implements a single shunt current sensing, eliminating the need for more than one sensor
  • High range of motor operating speeds up to 18000RPM
  • An adaptive closed loop rotor flux estimator enhances control performance and increases the overall robustness of the system
  • A reference manual provides a detailed description of the application, including a design of hardware and software
Features
  • 3-phase AC induction motor drive
  • Designed to fit into consumer and industrial applications
  • Uses 56F8013 or 56F8023 32 MIPS Digital Signal Controller
  • Running on a 3-phase High Voltage Power Stage
  • Control technique incorporating:
    • Vector control of three-phase AC induction motor with position encoder
    • Closed-loop speed control
    • Both directions of rotation
    • Both motor and generator modes
    • Reconstruction of three-phase motor currents from DC-Bus shunt resistor
    • Closed loop current control
    • Flux and torque independent control
    • Adaptive rotor flux space-vector estimator
    • Field-weakening for high speeds
    • High-speed range, max speed – 18000 RPM (2-pole motor)
  • FreeMASTER software control interface (motor start/stop, speed setup)
  • FreeMASTER software monitor
  • FreeMASTER software graphical control page (required speed, actual motor speed, start/stop status, DC-Bus voltage level, motor current, system status)
  • FreeMASTER software speed scope (observes actual and desired speeds, DC-Bus voltage and motor current)
  • FreeMASTER software high-speed recorder (reconstructed motor currents, vector control algorithm quantities)
  • DC-Bus overvoltage and undervoltage, overcurrent protection
Block Diagram
Board
Design Resources
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1126331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERDDSCACIMVC%3A3%20%E7%9B%B8%20AC%20%E8%AA%98%E5%B0%8E%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%88%B6%E5%BE%A1%E9%A7%86%E5%8B%95%E9%9B%BB%E6%B5%81%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCACIMVC-3-Phase-AC-Induction-Vector-Control-Drive-Current%2Fta-p%2F1126331%23toc-hId-382513740%22%20target%3D%22_blank%22%3EOverview%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCACIMVC-3-Phase-AC-Induction-Vector-Control-Drive-Current%2Fta-p%2F1126331%23toc-hId--1424940723%22%20target%3D%22_blank%22%3E%E7%89%B9%E9%95%B7%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCACIMVC-3-Phase-AC-Induction-Vector-Control-Drive-Current%2Fta-p%2F1126331%23toc-hId-1062572110%22%20target%3D%22_blank%22%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%9B%B3%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCACIMVC-3-Phase-AC-Induction-Vector-Control-Drive-Current%2Fta-p%2F1126331%23toc-hId--744882353%22%20target%3D%22_blank%22%3E%E3%83%9C%E3%83%BC%E3%83%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRDDSCACIMVC-3-Phase-AC-Induction-Vector-Control-Drive-Current%2Fta-p%2F1126331%23toc-hId-1742630480%22%20target%3D%22_blank%22%3E%E8%A8%AD%E8%A8%88%E3%83%BB%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-382513740%22%20id%3D%22toc-hId-1304074215%22%3EOverview%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81NXP%C2%AE%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E4%BF%A1%E5%8F%B7%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9MC56F8013%2FMC56F8023%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%9F%E4%B8%89%E7%9B%B8AC%E8%AA%98%E5%B0%8E%E3%83%A2%E3%83%BC%E3%82%BF%E3%81%AE%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%88%B6%E5%BE%A1%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E9%96%8B%E7%99%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%B8%BB%E3%81%AB%E6%B0%91%E7%94%9F%E7%94%A8%E3%81%8A%E3%82%88%E3%81%B3%E7%94%A3%E6%A5%AD%E7%94%A8%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AF%BE%E8%B1%A1%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3E%E8%B2%BB%E7%94%A8%E5%AF%BE%E5%8A%B9%E6%9E%9C%E3%81%8C%E9%AB%98%E3%81%8F%E3%80%81%E4%BF%A1%E9%A0%BC%E6%80%A7%E3%81%8C%E9%AB%98%E3%81%84%E3%81%93%E3%81%AE%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AF%E3%80%81%E5%8D%98%E4%B8%80%E3%81%AE%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E9%9B%BB%E6%B5%81%E6%A4%9C%E5%87%BA%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%81%8C%E4%B8%8D%E8%A6%81%E3%81%A7%E3%81%99%3C%2FLI%3E%3CLI%3E%E6%9C%80%E5%A4%A718000RPM%E3%81%AE%E9%AB%98%E9%80%9F%E5%BA%A6%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E5%8B%95%E4%BD%9C%E9%80%9F%E5%BA%A6%3C%2FLI%3E%3CLI%3E%E9%81%A9%E5%BF%9C%E5%9E%8B%E9%96%89%E3%83%AB%E3%83%BC%E3%83%97%E5%9B%9E%E8%BB%A2%E5%AD%90%E7%A3%81%E6%9D%9F%E6%8E%A8%E5%AE%9A%E5%99%A8%E3%81%AF%E3%80%81%E5%88%B6%E5%BE%A1%E6%80%A7%E8%83%BD%E3%82%92%E5%90%91%E4%B8%8A%E3%81%95%E3%81%9B%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E5%85%A8%E4%BD%93%E7%9A%84%E3%81%AA%E5%A0%85%E7%89%A2%E6%80%A7%E3%82%92%E5%90%91%E4%B8%8A%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%3E%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%A8%AD%E8%A8%88%E3%81%AA%E3%81%A9%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%AC%E6%98%8E%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1424940723%22%20id%3D%22toc-hId--503380248%22%3E%E7%89%B9%E9%95%B7%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E3%E7%9B%B8AC%E8%AA%98%E5%B0%8E%E9%9B%BB%E5%8B%95%E6%A9%9F%E9%A7%86%E5%8B%95%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E6%B0%91%E7%94%9F%E7%94%A8%E3%81%8A%E3%82%88%E3%81%B3%E7%94%A3%E6%A5%AD%E7%94%A8%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E9%81%A9%E5%90%88%E3%81%99%E3%82%8B%E8%A8%AD%E8%A8%88%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E56F8013%E3%81%BE%E3%81%9F%E3%81%AF56F8023%2032%20MIPS%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E4%BF%A1%E5%8F%B7%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E3%E7%9B%B8%E9%AB%98%E9%9B%BB%E5%9C%A7%E9%9B%BB%E5%8A%9B%E6%AE%B5%E3%81%A7%E5%8B%95%E4%BD%9C%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E4%BB%A5%E4%B8%8B%E3%82%92%E7%B5%84%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A0%E5%88%B6%E5%BE%A1%E6%96%B9%E5%BC%8F%EF%BC%9A%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style%3A%20none%3B%22%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E3%83%9D%E3%82%B8%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%A8%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%80%E4%BB%98%E3%81%8D%E4%B8%89%E7%9B%B8%E4%BA%A4%E6%B5%81%E8%AA%98%E5%B0%8E%E9%9B%BB%E5%8B%95%E6%A9%9F%E3%81%AE%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%88%B6%E5%BE%A1%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E3%82%AF%E3%83%AD%E3%83%BC%E3%82%BA%E3%83%89%E3%83%BB%E3%83%AB%E3%83%BC%E3%83%97%E9%80%9F%E5%BA%A6%E5%88%B6%E5%BE%A1%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E4%B8%A1%E5%9B%9E%E8%BB%A2%E6%96%B9%E5%90%91%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%E7%99%BA%E9%9B%BB%E6%A9%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E4%B8%A1%E6%96%B9%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3EDC%E3%83%90%E3%82%B9%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E6%8A%B5%E6%8A%97%E3%81%8B%E3%82%89%E3%81%AE%E4%B8%89%E7%9B%B8%E3%83%A2%E3%83%BC%E3%82%BF%E9%9B%BB%E6%B5%81%E3%81%AE%E5%86%8D%E6%A7%8B%E6%88%90%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E3%82%AF%E3%83%AD%E3%83%BC%E3%82%BA%E3%83%89%E3%83%AB%E3%83%BC%E3%83%97%E9%9B%BB%E6%B5%81%E5%88%B6%E5%BE%A1%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E7%A3%81%E6%9D%9F%E3%81%A8%E3%83%88%E3%83%AB%E3%82%AF%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%AA%E3%81%84%E5%88%B6%E5%BE%A1%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E9%81%A9%E5%BF%9C%E5%9E%8B%E5%9B%9E%E8%BB%A2%E5%AD%90%E7%A3%81%E6%9D%9F%E7%A9%BA%E9%96%93%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E6%8E%A8%E5%AE%9A%E5%99%A8%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E9%AB%98%E9%80%9F%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E5%BC%B1%E3%82%81%E7%95%8C%E7%A3%81%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%20style%3D%22margin-top%3A%200.5em%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3E%E9%AB%98%E9%80%9F%E7%AF%84%E5%9B%B2%E3%80%81%E6%9C%80%E9%AB%98%E9%80%9F%E5%BA%A6%E2%80%93%2018000%20RPM(2%E6%A5%B5%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC)%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3EFreeMASTER%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E5%88%B6%E5%BE%A1%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%EF%BC%88%E3%83%A2%E3%83%BC%E3%82%BF%E5%A7%8B%E5%8B%95%2F%E5%81%9C%E6%AD%A2%E3%80%81%E9%80%9F%E5%BA%A6%E8%A8%AD%E5%AE%9A%EF%BC%89%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3EFreeMASTER%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%83%A2%E3%83%8B%E3%82%BF%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3EFreeMASTER%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%B0%E3%83%A9%E3%83%95%E3%82%A3%E3%82%AB%E3%83%AB%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%83%9A%E3%83%BC%E3%82%B8(%E5%BF%85%E8%A6%81%E3%81%AA%E9%80%9F%E5%BA%A6%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E9%80%9F%E5%BA%A6%E3%80%81%E5%A7%8B%E5%8B%95%2F%E5%81%9C%E6%AD%A2%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%80%81DC%E3%83%90%E3%82%B9%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%83%99%E3%83%AB%E3%80%81%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E9%9B%BB%E6%B5%81%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9)%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3EFreeMASTER%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E9%80%9F%E5%BA%A6%E7%AF%84%E5%9B%B2(%E5%AE%9F%E9%9A%9B%E3%81%AE%E9%80%9F%E5%BA%A6%E3%81%A8%E7%9B%AE%E7%9A%84%E3%81%AE%E9%80%9F%E5%BA%A6%E3%80%81DC%E3%83%90%E3%82%B9%E9%9B%BB%E5%9C%A7%E3%80%81%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E9%9B%BB%E6%B5%81%E3%82%92%E8%A6%B3%E5%AF%9F)%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3EFreeMASTER%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E9%AB%98%E9%80%9F%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%80%E3%83%BC(%E5%86%8D%E6%A7%8B%E6%88%90%E3%83%A2%E3%83%BC%E3%82%BF%E9%9B%BB%E6%B5%81%E3%80%81%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%88%B6%E5%BE%A1%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E9%87%8F)%3C%2FDIV%3E%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%3CDIV%3EDC%E3%83%90%E3%82%B9%E3%81%AE%E9%81%8E%E9%9B%BB%E5%9C%A7%E3%81%8A%E3%82%88%E3%81%B3%E4%BD%8E%E9%9B%BB%E5%9C%A7%E3%80%81%E9%81%8E%E9%9B%BB%E6%B5%81%E4%BF%9D%E8%AD%B7%3C%2FDIV%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1062572110%22%20id%3D%22toc-hId-1984132585%22%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%9B%B3%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221103_3_PHASE_AC1.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221103_3_PHASE_AC1.gif%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111401i656E7D08B84759BC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221103_3_PHASE_AC1.gif%22%20alt%3D%221103_3_PHASE_AC1.gif%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1103_3_PHASE_AC1.gif%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--744882353%22%20id%3D%22toc-hId-176678122%22%3E%E3%83%9C%E3%83%BC%E3%83%89%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ACIMVCDEMO.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ACIMVCDEMO.jpg%22%20style%3D%22width%3A%20500px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111415i2213FEC11AEFF576%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22ACIMVCDEMO.jpg%22%20alt%3D%22ACIMVCDEMO.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EACIMVCDEMO.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1742630480%22%20id%3D%22toc-hId--1630776341%22%3E%E8%A8%AD%E8%A8%88%E3%83%BB%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1126331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎08-11-2020 11:48 AM
更新者:
