RD56F801XACIM: Design of an ACIM Vector Control Drive Reference Design using the 56F801X
Overview
This drive application allows vector control of an AC Induction Motor (ACIM) running in a closed-speed loop without a speed/position sensor at a low cost and serves as an example of AC induction vector control drive design using an NXP® 56F8013 with Processor Expert® software support.
  • ACIM is ideal for appliance and industrial applications
  • This design uses sensorless FOC to control an ACIM using the 56F8013 device, which can accommodate the sensorless FOC algorithm
  • The motor control system is flexible enough to implement complex motion protocols while it drives a variable load.
  • The system illustrates the features of the 56F8013 in motor control
Features
General:
  • The motor control algorithm employs Stator-Flux-Oriented Control (SFOC)
  • Power stage switches are controlled by Space Vector Pulse Width Modulation (SVPWM)
  • No position information devices or stator flux measurement are used, a sensorless speed method is employed
  • The motor is capable of forward and reverse rotation and has a speed range from 50rpm to 3000rpm
  • The user controls motion profiles, rotation direction, and speed. The RS-232 communication supports further R&D by enabling the easy tuning of control parameters
  • The motor drive system is designed to create minimal acoustic noise
  • Active power factor correction which reduces the negative effects of the load on the power grid in conducted noise and imaginary power
  • Design is low cost
General Benefits:
  • Improved End System Performance
  • Energy savings
  • Quieter operation
  • Improved EMI performance
  • System Cost savings
  • Enhanced Reliability
Performance:
  • Input voltage: 85 ~265VAC
  • Input frequency: 45 ~65HZ
  • Rating bus voltage: 350V
  • Rating output power: 500W
  • Switch frequency of PFC switch: 100KHZ
  • Switch frequency of inverter: 10KHZ
  • Power factor: >95%
  • Efficiency: >90%
Communications:
  • RS232 port for communication with optoisolation
Visual Interface:
  • Multi-segment LED indicators
Block Diagram
Board
Design Resources
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1105923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERD56F801XACIM%3A56F801X%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FACIM%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%88%B6%E5%BE%A1%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%BB%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AE%E8%A8%AD%E8%A8%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XACIM-Design-of-an-ACIM-Vector-Control-Drive-Reference%2Fta-p%2F1105923%23toc-hId-380642644%22%20target%3D%22_blank%22%3EOverview%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XACIM-Design-of-an-ACIM-Vector-Control-Drive-Reference%2Fta-p%2F1105923%23toc-hId--1426811819%22%20target%3D%22_blank%22%3E%E7%89%B9%E9%95%B7%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XACIM-Design-of-an-ACIM-Vector-Control-Drive-Reference%2Fta-p%2F1105923%23toc-hId-1761765592%22%20target%3D%22_blank%22%3E%E4%B8%80%E8%88%AC%EF%BC%9A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XACIM-Design-of-an-ACIM-Vector-Control-Drive-Reference%2Fta-p%2F1105923%23toc-hId--45688871%22%20target%3D%22_blank%22%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E5%88%A9%E7%82%B9%3A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XACIM-Design-of-an-ACIM-Vector-Control-Drive-Reference%2Fta-p%2F1105923%23toc-hId--1853143334%22%20target%3D%22_blank%22%3E%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%EF%BC%9A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XACIM-Design-of-an-ACIM-Vector-Control-Drive-Reference%2Fta-p%2F1105923%23toc-hId-634369499%22%20target%3D%22_blank%22%3E%E9%80%9A%E4%BF%A1%EF%BC%9A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A50px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XACIM-Design-of-an-ACIM-Vector-Control-Drive-Reference%2Fta-p%2F1105923%23toc-hId--1173084964%22%20target%3D%22_blank%22%3E%E3%83%93%E3%82%B8%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3A%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XACIM-Design-of-an-ACIM-Vector-Control-Drive-Reference%2Fta-p%2F1105923%23toc-hId-613363291%22%20target%3D%22_blank%22%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%9B%B3%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XACIM-Design-of-an-ACIM-Vector-Control-Drive-Reference%2Fta-p%2F1105923%23toc-hId--1194091172%22%20target%3D%22_blank%22%3E%E3%83%9C%E3%83%BC%E3%83%89%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FRD56F801XACIM-Design-of-an-ACIM-Vector-Control-Drive-Reference%2Fta-p%2F1105923%23toc-hId-1293421661%22%20target%3D%22_blank%22%3E%E8%A8%AD%E8%A8%88%E3%83%BB%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-380642644%22%20id%3D%22toc-hId-1304189776%22%3EOverview%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin%3A%200px%200px%2011px%3B%22%3E%E3%81%93%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%BB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%E9%80%9F%E5%BA%A6%2F%E4%BD%8D%E7%BD%AE%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AA%E3%81%97%E3%81%A7%E3%82%AF%E3%83%AD%E3%83%BC%E3%82%BA%E3%83%89%E3%82%B9%E3%83%94%E3%83%BC%E3%83%89%E3%83%BB%E3%83%AB%E3%83%BC%E3%83%97%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8BAC%E8%AA%98%E5%B0%8E%E3%83%A2%E3%83%BC%E3%82%BF(ACIM)%E3%81%AE%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%88%B6%E5%BE%A1%E3%82%92%E4%BD%8E%E3%82%B3%E3%82%B9%E3%83%88%E3%81%A7%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%97%E3%80%81NXP%3CSPAN%20style%3D%22font-size%3A%2010.88px%3B%22%3E%3CSUP%3E%C2%AE%3C%2FSUP%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E56F8013%E3%81%A8%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%83%BB%E3%82%A8%E3%82%AD%E3%82%B9%E3%83%91%E3%83%BC%E3%83%88%3CSPAN%20style%3D%22font-size%3A%2010.88px%3B%22%3E%3CSUP%3E%C2%AE%3C%2FSUP%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FAC%E8%AA%98%E5%B0%8E%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E5%88%B6%E5%BE%A1%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E8%A8%AD%E8%A8%88%E3%81%AE%E4%B8%80%E4%BE%8B%E3%81%A8%E3%81%97%E3%81%A6%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%20class%3D%22%22%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EACIM%E3%81%AF%E3%80%81%E5%AE%B6%E9%9B%BB%E8%A3%BD%E5%93%81%E3%82%84%E7%94%A3%E6%A5%AD%E7%94%A8%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E6%9C%80%E9%81%A9%E3%81%A7%E3%81%99%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%81%93%E3%81%AE%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AF%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9%20FOC%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20ACIM%20%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%97%E3%80%8156F8013%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9%20FOC%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%80%81%E5%8F%AF%E5%A4%89%E8%B2%A0%E8%8D%B7%E3%82%92%E9%A7%86%E5%8B%95%E3%81%97%E3%81%AA%E3%81%8C%E3%82%89%E8%A4%87%E9%9B%91%E3%81%AA%E3%83%A2%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%8D%81%E5%88%86%E3%81%AA%E6%9F%94%E8%BB%9F%E6%80%A7%E3%82%92%E5%82%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%81%93%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%80%81%E3%83%A2%E3%83%BC%E3%82%BF%E5%88%B6%E5%BE%A1%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B56F8013%E3%81%AE%E7%89%B9%E9%95%B7%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1426811819%22%20id%3D%22toc-hId--503264687%22%3E%E7%89%B9%E9%95%B7%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CH3%20style%3D%22color%3A%20%2320272d%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20bold%3B%20font-size%3A%2020px%3B%20margin-top%3A%2022px%3B%20margin-bottom%3A%2011px%3B%22%20id%3D%22toc-hId-1761765592%22%20id%3D%22toc-hId--1609654572%22%3E%E4%B8%80%E8%88%AC%EF%BC%9A%3C%2FH3%3E%3CUL%20class%3D%22%22%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E5%88%B6%E5%BE%A1%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AF%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%83%BC%E7%A3%81%E6%9D%9F%E6%8C%87%E5%90%91%E5%88%B6%E5%BE%A1%20(SFOC)%20%E3%82%92%E6%8E%A1%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%83%91%E3%83%AF%E3%83%BC%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AF%E3%80%81%E7%A9%BA%E9%96%93%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E3%83%91%E3%83%AB%E3%82%B9%E5%B9%85%E5%A4%89%E8%AA%BF(SVPWM)%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%88%B6%E5%BE%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E4%BD%8D%E7%BD%AE%E6%83%85%E5%A0%B1%E8%A3%85%E7%BD%AE%E3%82%84%E5%9B%BA%E5%AE%9A%E5%AD%90%E7%A3%81%E6%9D%9F%E6%B8%AC%E5%AE%9A%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%9B%E3%81%9A%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%AC%E3%82%B9%E9%80%9F%E5%BA%A6%E6%96%B9%E5%BC%8F%E3%82%92%E6%8E%A1%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AF%E6%AD%A3%E8%BB%A2%E3%81%A8%E9%80%86%E5%9B%9E%E8%BB%A2%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%80%81%E9%80%9F%E5%BA%A6%E7%AF%84%E5%9B%B2%E3%81%AF50rpm%E3%81%8B%E3%82%893000rpm%E3%81%A7%E3%81%99%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AF%E3%80%81%E3%83%A2%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%97%E3%83%AD%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%9B%9E%E8%BB%A2%E6%96%B9%E5%90%91%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E9%80%9F%E5%BA%A6%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82RS-232%E9%80%9A%E4%BF%A1%E3%81%AF%E3%80%81%E5%88%B6%E5%BE%A1%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AE%E3%83%81%E3%83%A5%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%92%E5%AE%B9%E6%98%93%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%81%95%E3%82%89%E3%81%AA%E3%82%8B%E7%A0%94%E7%A9%B6%E9%96%8B%E7%99%BA%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E9%A7%86%E5%8B%95%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%80%81%E9%9F%B3%E9%9F%BF%E3%83%8E%E3%82%A4%E3%82%BA%E3%82%92%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AB%E6%8A%91%E3%81%88%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8A%9B%E7%8E%87%E8%A3%9C%E6%AD%A3%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E4%BC%9D%E5%B0%8E%E3%83%8E%E3%82%A4%E3%82%BA%E3%81%A8%E8%99%9A%E6%95%B0%E9%9B%BB%E5%8A%9B%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E9%9B%BB%E5%8A%9B%E7%B6%B2%E3%81%B8%E3%81%AE%E8%B2%A0%E8%8D%B7%E3%81%AE%E6%82%AA%E5%BD%B1%E9%9F%BF%E3%82%92%E4%BD%8E%E6%B8%9B%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AF%E4%BD%8E%E3%82%B3%E3%82%B9%E3%83%88%E3%81%A7%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CH3%20style%3D%22color%3A%20%2320272d%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20bold%3B%20font-size%3A%2020px%3B%20margin-top%3A%2022px%3B%20margin-bottom%3A%2011px%3B%22%20id%3D%22toc-hId--45688871%22%20id%3D%22toc-hId-877858261%22%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E5%88%A9%E7%82%B9%3A%3C%2FH3%3E%3CUL%20class%3D%22%22%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%82%A8%E3%83%B3%E3%83%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%81%AE%E5%90%91%E4%B8%8A%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%82%A8%E3%83%8D%E3%83%AB%E3%82%AE%E3%83%BC%E7%AF%80%E7%B4%84%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%82%88%E3%82%8A%E9%9D%99%E3%81%8B%E3%81%AA%E6%93%8D%E4%BD%9C%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EEMI%E6%80%A7%E8%83%BD%E3%81%AE%E5%90%91%E4%B8%8A%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%B3%E3%82%B9%E3%83%88%E5%89%8A%E6%B8%9B%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E4%BF%A1%E9%A0%BC%E6%80%A7%E3%81%AE%E5%90%91%E4%B8%8A%3C%2FLI%3E%3C%2FUL%3E%3CH3%20style%3D%22color%3A%20%2320272d%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20bold%3B%20font-size%3A%2020px%3B%20margin-top%3A%2022px%3B%20margin-bottom%3A%2011px%3B%22%20id%3D%22toc-hId--1853143334%22%20id%3D%22toc-hId--929596202%22%3E%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%EF%BC%9A%3C%2FH3%3E%3CUL%20class%3D%22%22%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E5%85%A5%E5%8A%9B%E9%9B%BB%E5%9C%A7%3A85~265VAC%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E5%85%A5%E5%8A%9B%E5%91%A8%E6%B3%A2%E6%95%B0%3A%2045%20~65HZ%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E5%AE%9A%E6%A0%BC%E3%83%90%E3%82%B9%E9%9B%BB%E5%9C%A7%3A350V%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E5%AE%9A%E6%A0%BC%E5%87%BA%E5%8A%9B%E9%9B%BB%E5%8A%9B%3A500W%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3EPFC%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E5%91%A8%E6%B3%A2%E6%95%B0%3A100KHZ%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%82%A4%E3%83%B3%E3%83%90%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E5%91%A8%E6%B3%A2%E6%95%B0%3A10KHZ%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E5%8A%9B%E7%8E%87%3A%26gt%3B95%25%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E5%8A%B9%E7%8E%87%3A%26gt%3B90%25%3C%2FLI%3E%3C%2FUL%3E%3CH3%20style%3D%22color%3A%20%2320272d%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20bold%3B%20font-size%3A%2020px%3B%20margin-top%3A%2022px%3B%20margin-bottom%3A%2011px%3B%22%20id%3D%22toc-hId-634369499%22%20id%3D%22toc-hId-1557916631%22%3E%E9%80%9A%E4%BF%A1%EF%BC%9A%3C%2FH3%3E%3CUL%20class%3D%22%22%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E5%85%89%E7%B5%B6%E7%B8%81%E3%81%A8%E3%81%AE%E9%80%9A%E4%BF%A1%E7%94%A8%E3%81%AERS232%E3%83%9D%E3%83%BC%E3%83%88%3C%2FLI%3E%3C%2FUL%3E%3CH3%20style%3D%22color%3A%20%2320272d%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20bold%3B%20font-size%3A%2020px%3B%20margin-top%3A%2022px%3B%20margin-bottom%3A%2011px%3B%22%20id%3D%22toc-hId--1173084964%22%20id%3D%22toc-hId--249537832%22%3E%E3%83%93%E3%82%B8%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3A%3C%2FH3%3E%3CUL%20class%3D%22%22%20style%3D%22color%3A%20%23333f48%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2016px%3B%20margin-bottom%3A%2011px%3B%20padding-left%3A%201em%3B%22%3E%3CLI%20style%3D%22margin-bottom%3A%200.5em%3B%22%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88LED%E3%82%A4%E3%83%B3%E3%82%B8%E3%82%B1%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-613363291%22%20id%3D%22toc-hId-1536910423%22%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%9B%B3%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RD56F801XACIMBD.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RD56F801XACIMBD.jpg%22%20style%3D%22width%3A%20711px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110536i937E02D400CC58CE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22RD56F801XACIMBD.jpg%22%20alt%3D%22RD56F801XACIMBD.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1194091172%22%20id%3D%22toc-hId--270544040%22%3E%E3%83%9C%E3%83%BC%E3%83%89%3C%2FH1%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RD56F801XACIMIMG.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RD56F801XACIMIMG.jpg%22%20style%3D%22width%3A%20415px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F110563iE427D4BC9A9D3D32%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22RD56F801XACIMIMG.jpg%22%20alt%3D%22RD56F801XACIMIMG.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1293421661%22%20id%3D%22toc-hId--2077998503%22%3E%E8%A8%AD%E8%A8%88%E3%83%BB%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1105923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎08-12-2020 08:40 AM
更新者:
