OpenWRT Thread Border Router using i.MX6UL
Demo
This demo showcases an OpenWRT based Thread Border router running on i.MX6UL and the various options to configure and use routing, firewall and out of band commissioning for Thread networks in combination with WiFi, Ethernet and NFC. OpenWRT is an open source Linux distribution for embedded devices specifically designed for residential gateways and routers. When enhanced with the Kinetis Thread protocol it offers the perfect solutions for creating a Linux based Thread Border Router
Large and dense mesh network consisting in 64+ Thread nodes
Each node is router capable, network decides dynamically which nodes become active routers
Multiple application functionality run in parallel:
  • Device addressing and identification
  • Lighting demonstration with multicast
  • Occupancy sensing demonstration
  • Border Router with Network management web GUI
Features:
  • Application layer communication based on generic CoAP framework
  • CoAP messaging aligned with current ZigBee or OIC frameworks
  • Kinetis KW2xD and Kinetis KW41 ARM Cortex-M4/M0+ MCUs with large on-board memory (up to 512KB flash/128 KB RAM) enable multiple applications to run on a common Thread IP network fabric.
  • 1 i.MX6UL ARM Cortex-A7 with Kinetis KW2xD Linux Border Router used for interfacing with network management GUI
  • Network management and interoperable Thread diagnostics framework used to monitor node state
  • Nodes are enabled for OTA Updates
_____________________________________________________________________________________________
Featured NXP Products:
ProductLink
i.MX6UltraLite Evaluation Kiti.MX6UltraLite Evaluation Kit | NXP
Freedom Development Platform for Kinetis® KW2x MCUsFRDM-KW24D512|Freedom Development Platform|Kinetis | NXP
タグ(3)
コメント
Hi Cristian,
Is the source code and image available for developers ?
Dhvanil
I'm very interested in the OpenWRT image. Is it possible to get the source code of the openWRT tree for i.MX6UL? (thread is not necessary for us).
or at least, target directory, dts, drivers and  patches.
I've already got the i.mx6ul evaluation kit.
thanks in advance
Miguel
edk
Yes, but you will need to submit a request to access our Pre-Certified Thread Network Stack. Please go to the following link: www.nxp.com/thread for more information.
edk
Yes, but the code is within the Thread package at this point and you will need to request access to our Pre-Certified Thread Network Stack to access it. Please go to the following link: www.nxp.com/thread for more information.
Hi edk,
I already sign up for the pre certified thread stack. but there isn't any source code available for Openwrt.
edk
Hi Dhavani Patel,
Since you already signed up, could you please provide me with your email address so I can send you pertinent information?
Edk
Hi edk,
My Registered email id: dhvanil.patel@volansystech.com
Dhvanil
Same than Dhvanil. I already sign up for the pre certified thread stack, and I would like to get the source code for OpenWrt.
My registered e-mal is mlopez (at) egiaudio.com
Miguel
Hello Edk,
This is NXP i.MX FAE/CAS and I'm also interested in OpenWRT on i.MX6UL, is there any NXP internal repository to download it?
PS: I've just send the request for the access of the Thread stack, in case that's required.
Jim.
edk
Hi jim.lin
Did you get a response to your request to get the stack? if you have any issues, please let me know.
Ed
Hi Edk,
I'm develop IOT gateway with zigbee/zigwave and interested in OpenWRT on i.MX6UL.
 I already sign up for the pre certified thread stack and my registered e-mal is jimmy.hsu@zyxyel.com.tw.
Could you help to provide OpenWRT thread source code ?
Don't waste your time. I talked to them and NXP is not willing to give anything unless you pay several thousand of dollars for support. This is interesting because they are taking advantage of open source software, like OpenWRT, not returning anything to the community. I don't know how this could be, with OpenWRT based on GPLv2 license.
If anyone gets a working source code of OpenWRT please let me know. My e-mail is mlopez (at) egiaudio.com.
Hello edk,
I'm develop IoT gateway with LPWAN(Thread/SigFox/LoRa).
I already sign up for the pre-certified thread stack and my registered e-mail is k2s@chience.co.kr.
Could you provide a OpenWRT source?
Hi Edk,
I would appreciate it very much if you can provide me the OpenWRT source. My registered e-mail is arvin.amos@gmail.com.
Thanks.
Arvin Lim
Hi Edk,
I would also appreciate it very much if you can provide me the OpenWRT source code. My registered e-mail is piers.basto@lightfox.com
Kind Regards,
Piers
%3CLINGO-SUB%20id%3D%22lingo-sub-1106028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%20medium%3B%20font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3EDemo%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%22%3E%E3%81%93%E3%81%AE%E3%83%87%E3%83%A2%E3%81%A7%E3%81%AF%E3%80%81i.MX6UL%E4%B8%8A%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8BOpenWRT%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AEThread%20Border%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%A8%E3%80%81WiFi%E3%80%81%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%80%81NFC%E3%81%A8%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6Thread%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%82%A2%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%AB%E3%80%81%E3%82%A2%E3%82%A6%E3%83%88%E3%82%AA%E3%83%96%E3%83%90%E3%83%B3%E3%83%89%E3%82%B3%E3%83%9F%E3%83%83%E3%82%B7%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%92%E6%A7%8B%E6%88%90%E3%81%8A%E3%82%88%E3%81%B3%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E7%B4%B9%E4%BB%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82OpenWRT%E3%81%AF%E3%80%81%E4%BD%8F%E5%AE%85%E7%94%A8%E3%82%B2%E3%83%BC%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A4%E3%81%8A%E3%82%88%E3%81%B3%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%E7%94%A8%E3%81%AB%E7%89%B9%E5%88%A5%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%9F%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%94%A8%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9Linux%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82Kinetis%E3%81%AEThread%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E3%81%A7%E6%8B%A1%E5%BC%B5%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Linux%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AEThread%E5%A2%83%E7%95%8C%E3%83%AB%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%AE%8C%E7%92%A7%E3%81%AA%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%AE%9F%E7%8F%BE%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%22%3E%3CIFRAME%20class%3D%22embedly-embed%22%20src%3D%22https%3A%2F%2Fcdn.embedly.com%2Fwidgets%2Fmedia.html%3Fsrc%3Dhttps%253A%252F%252Fplayers.brightcove.net%252Fpages%252Fv1%252Findex.html%253FaccountId%253D4089003392001%2526playerId%253Ddefault%2526videoId%253D4945306336001%2526mode%253Diframe%26amp%3Burl%3Dhttp%253A%252F%252Fplayers.brightcove.net%252F4089003392001%252Fdefault_default%252Findex.html%253FvideoId%253D4945306336001%26amp%3Bimage%3Dhttp%253A%252F%252Fbrightcove01.brightcove.com%252F24%252F4089003392001%252F201606%252F2046%252F4089003392001_4945305973001_4945306336001-th.jpg%253FpubId%253D4089003392001%2526videoId%253D4945306336001%26amp%3Bkey%3Ddbd8e071ec924c24aed29db4738a7e1c%26amp%3Btype%3Dtext%252Fhtml%26amp%3Bschema%3Dbrightcove%22%20width%3D%22800%22%20height%3D%22450%22%20scrolling%3D%22no%22%20frameborder%3D%220%22%20allowfullscreen%3D%22%22%3E%3C%2FIFRAME%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%20medium%3B%22%3E64%2B%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%8E%E3%83%BC%E3%83%89%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%82%8B%E5%A4%A7%E8%A6%8F%E6%A8%A1%E3%81%A7%E9%AB%98%E5%AF%86%E5%BA%A6%E3%81%AE%E3%83%A1%E3%83%83%E3%82%B7%E3%83%A5%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%20medium%3B%22%3E%E5%90%84%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AF%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AF%E3%81%A9%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%8B%E3%82%92%E5%8B%95%E7%9A%84%E3%81%AB%E6%B1%BA%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%20medium%3B%22%3E%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E6%A9%9F%E8%83%BD%E3%81%8C%E4%B8%A6%E8%A1%8C%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%20margin%3A%200.5ex%200px%3B%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%8C%87%E5%AE%9A%E3%81%A8%E8%AD%98%E5%88%A5%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%20margin%3A%200.5ex%200px%3B%22%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%82%AD%E3%83%A3%E3%82%B9%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E7%85%A7%E6%98%8E%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%20margin%3A%200.5ex%200px%3B%22%3E%E5%8D%A0%E6%9C%89%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%AE%E3%83%87%E3%83%A2%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%20margin%3A%200.5ex%200px%3B%22%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E7%AE%A1%E7%90%86Web%20GUI%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E5%A2%83%E7%95%8C%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%20medium%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3E%3CSTRONG%3E%E7%89%B9%E9%95%B7%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%20margin%3A%200.5ex%200px%3B%22%3E%E6%B1%8E%E7%94%A8%20CoAP%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%B1%A4%E9%80%9A%E4%BF%A1%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%20margin%3A%200.5ex%200px%3B%22%3E%E7%8F%BE%E5%9C%A8%E3%81%AEZigBee%E3%81%BE%E3%81%9F%E3%81%AFOIC%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AB%E5%90%88%E3%82%8F%E3%81%9B%E3%81%9FCoAP%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%B3%E3%82%B0%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%20margin%3A%200.5ex%200px%3B%22%3EKinetis%20KW2xD%E3%81%8A%E3%82%88%E3%81%B3Kinetis%20KW41%20ARM%20Cortex-M4%2FM0%2B%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AF%E3%80%81%E5%A4%A7%E5%AE%B9%E9%87%8F%E3%81%AE%E3%82%AA%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%83%BB%E3%83%A1%E3%83%A2%E3%83%AA(%E6%9C%80%E5%A4%A7512KB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%2F128KB%E3%81%AERAM)%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%80%81%E5%85%B1%E9%80%9A%E3%81%AEThread%20IP%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%BB%E3%83%95%E3%82%A1%E3%83%96%E3%83%AA%E3%83%83%E3%82%AF%E4%B8%8A%E3%81%A7%E8%A4%87%E6%95%B0%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%20margin%3A%200.5ex%200px%3B%22%3E1%20i.MX6UL%20ARM%20Cortex-A7%20with%20Kinetis%20KW2xD%20Linux%20Border%20Router(%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E7%AE%A1%E7%90%86GUI%E3%81%A8%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AB%E4%BD%BF%E7%94%A8)%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%20margin%3A%200.5ex%200px%3B%22%3E%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E7%8A%B6%E6%85%8B%E3%82%92%E7%9B%A3%E8%A6%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E7%AE%A1%E7%90%86%E3%81%A8%E7%9B%B8%E4%BA%92%E9%81%8B%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E8%A8%BA%E6%96%AD%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%20margin%3A%200.5ex%200px%3B%22%3E%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AF%20OTA%20%E6%9B%B4%E6%96%B0%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%20medium%3B%20font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3E_____________________________________________________________________________________________%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%22%3E%E6%B3%A8%E7%9B%AE%E3%81%AE%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%22%3ENXP%E8%A3%BD%E5%93%81%3A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%2352cc8f%3B%22%3E%3CTH%20style%3D%22width%3A%2041.7459%25%3B%22%3E%E8%A3%BD%E5%93%81%3C%2FTH%3E%3CTH%20style%3D%22width%3A%2056.3526%25%3B%22%3E%E3%83%AA%E3%83%B3%E3%82%AF%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22width%3A%2041.7459%25%3B%22%3Ei.MX%206UltraLite%E8%A9%95%E4%BE%A1%E3%82%AD%E3%83%83%E3%83%88%3C%2FTD%3E%3CTD%20style%3D%22width%3A%2056.3526%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi.mx-evaluation-and-development-boards%2Fi.mx6ultralite-evaluation-kit%3AMCIMX6UL-EVK%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi.mx-evaluation-and-development-boards%2Fi.mx6ultralite-evaluation-kit%3AMCIMX6UL-EVK%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ei.MX6Ultra%20Light%20%E8%A9%95%E4%BE%A1%E3%82%AD%E3%83%83%E3%83%88%20%7CNXP%E3%81%AE%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22width%3A%2041.7459%25%3B%22%3EKinetis%C2%AE%20KW2x%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E5%90%91%E3%81%91Freedom%E9%96%8B%E7%99%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3C%2FTD%3E%3CTD%20style%3D%22width%3A%2056.3526%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Ffreedom-development-boards%2Fwireless-connectivy%2Ffreedom-development-platform-for-kinetis-kw2x-mcus%3AFRDM-KW24D512%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Ffreedom-development-boards%2Fwireless-connectivy%2Ffreedom-development-platform-for-kinetis-kw2x-mcus%3AFRDM-KW24D512%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFRDM-KW24D512%7CFreedom%E9%96%8B%E7%99%BA%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%7C%E3%82%AD%E3%83%8D%E3%83%86%E3%82%A3%E3%82%B9%20%7CNXP%E3%81%AE%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%20medium%3B%20font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3E_____________________________________________________________________________________________%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22149350_149350.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22149350_149350.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117127iBD2495A48728D78B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22149350_149350.jpg%22%20alt%3D%22149350_149350.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F87633i6D378CE8A948A487%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_16.jpg%22%20alt%3D%22pastedImage_16.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22149351_149351.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22149351_149351.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117128i3DFD8E6DEB81C473%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22149351_149351.jpg%22%20alt%3D%22149351_149351.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_17.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_17.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F86285iE83ECE09AEE4C996%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_17.jpg%22%20alt%3D%22pastedImage_17.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fword-edit.officeapps.live.com%252Fwe%252FResReader.ashx%253Fv%253D00000000-0000-0000-0000-000000000014%2526n%253DE2o1.img%2526rndm%253D1be9df2e-212b-4e23-8685-95dbbc07e6f9%2526WOPIsrc%253Dhttps%25253A%25252F%25252Fnxp1%25252Esharepoint%25252Ecom%25252Fteams%25252F108%25252Fcustomertraining%25252F2016nxpftf%25252Ftechlab%25252F%25255Fvti%25255Fbin%25252Fwopi%25252Eashx%25252Ffiles%25252F3ec502f0cc0f4c18b181e0ce2a70112c%2526access_token%253DeyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiIsIng1dCI6ImlZR1ZYcU1YbDZuSkI5MldBdW9jN1V3RHI0WSJ9%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%25252EZ6IgV7wX5fA0zw8YTC7EdFmp8DL%25252Dg2FPfDxGewtgAZgHuhQ%25252DpG62tZBv3XQH%25252DmLAiTeFvBiu2gOVPqqbp5Vw2EsqTFqHxjBYixE0T8RpBcMU%25255FiyPFuvNsM42aQsLvKRhbBLzihWydgGxSWoeyNsVUUUi21IOXXoL0Ia1o2ZlgzxYaA1LLk8eHRFAkVZUJguGzKZH8fuPqw%25252DKR%25252DHAmftkKc7rZ1PdPWM2JsyuDijwKoYWc4HE1QG6HE6fwxfODK9lBBRUoee0gu2Whm1tcgjPbWFu%25252Dq5zrfNFV%25255FrCrDCJyctjwkyFdNbXIjqI7FQ3ftTE67rve7%25255Frg%25255FzWMLjs7BnDVg%2526access_token_ttl%253D1463194412053%2526usid%253Db987814d-b1c0-4131-b0ff-fec6d0da9599%2526build%253D16.0.7011.2276%2526waccluster%253DUS1%22%20target%3D%22_blank%22%3E%3CIMG%20alt%3D%22%E7%94%BB%E5%83%8F%22%20class%3D%22WACImage%20SCX255823024%20jive-image%22%20src%3D%22https%3A%2F%2Fword-edit.officeapps.live.com%2Fwe%2FResReader.ashx%3Fv%3D00000000-0000-0000-0000-000000000014%26amp%3Bn%3DE2o1.img%26amp%3Brndm%3D1be9df2e-212b-4e23-8685-95dbbc07e6f9%26amp%3BWOPIsrc%3Dhttps%253A%252F%252Fnxp1%252Esharepoint%252Ecom%252Fteams%252F108%252Fcustomertraining%252F2016nxpftf%252Ftechlab%252F%255Fvti%255Fbin%252Fwopi%252Eashx%252Ffiles%252F3ec502f0cc0f4c18b181e0ce2a70112c%26amp%3Baccess_token%3DeyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiIsIng1dCI6ImlZR1ZYcU1YbDZuSkI5MldBdW9jN1V3RHI0WSJ9%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%252EZ6IgV7wX5fA0zw8YTC7EdFmp8DL%252Dg2FPfDxGewtgAZgHuhQ%252DpG62tZBv3XQH%252DmLAiTeFvBiu2gOVPqqbp5Vw2EsqTFqHxjBYixE0T8RpBcMU%255FiyPFuvNsM42aQsLvKRhbBLzihWydgGxSWoeyNsVUUUi21IOXXoL0Ia1o2ZlgzxYaA1LLk8eHRFAkVZUJguGzKZH8fuPqw%252DKR%252DHAmftkKc7rZ1PdPWM2JsyuDijwKoYWc4HE1QG6HE6fwxfODK9lBBRUoee0gu2Whm1tcgjPbWFu%252Dq5zrfNFV%255FrCrDCJyctjwkyFdNbXIjqI7FQ3ftTE67rve7%255Frg%255FzWMLjs7BnDVg%26amp%3Baccess_token_ttl%3D1463194412053%26amp%3Busid%3Db987814d-b1c0-4131-b0ff-fec6d0da9599%26amp%3Bbuild%3D16.0.7011.2276%26amp%3Bwaccluster%3DUS1%22%20style%3D%22margin%3A%201px%3B%20padding%3A%202px%3B%20border-style%3A%20none%3B%20color%3A%20%23000000%3B%20font-family%3A%20'Segoe%20UI'%2C%20Tahoma%2C%20Verdana%2C%20sans-serif%3B%20font-size%3A%208px%3B%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1106028%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E9%80%9A%E4%BF%A1%E3%82%A4%E3%83%B3%E3%83%95%E3%83%A9%E3%82%B9%E3%83%88%E3%83%A9%E3%82%AF%E3%83%81%E3%83%A3%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106043%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106043%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Edk%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%E3%80%81OpenWRT%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%A4%A7%E5%A4%89%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%9F%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Apiers.basto%40lightfox.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Epiers.basto%40lightfox.com%3C%2FA%3E%20%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E6%A1%9F%E6%A9%8B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106042%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Edk%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EOpenWRT%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%9F%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%20%3CA%20href%3D%22mailto%3Aarvin.amos%40gmail.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Earvin.amos%40gmail.com%3C%2FA%3E%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%82%A2%E3%83%AB%E3%83%B4%E3%82%A3%E3%83%B3%E3%83%BB%E3%83%AA%E3%83%A0%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EHello%20edk%2C%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3ELPWAN(Thread%2FSigFox%2FLoRa)%E3%81%A7IoT%E3%82%B2%E3%83%BC%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E4%BA%8B%E5%89%8D%E8%AA%8D%E5%AE%9A%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AB%E3%81%99%E3%81%A7%E3%81%AB%E3%82%B5%E3%82%A4%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%9F%E9%9B%BB%E5%AD%90%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%AF%20%3CA%20href%3D%22mailto%3Ak2s%40chience.co.kr%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ek2s%40chience.co.kr%3C%2FA%3E%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EOpenWRT%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%99%82%E9%96%93%E3%82%92%E7%84%A1%E9%A7%84%E3%81%AB%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E7%A7%81%E3%81%AF%E5%BD%BC%E3%82%89%E3%81%A8%E8%A9%B1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81NXP%E3%81%AF%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E6%95%B0%E5%8D%83%E3%83%89%E3%83%AB%E3%82%92%E6%94%AF%E6%89%95%E3%82%8F%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E4%BD%95%E3%82%82%E6%8F%90%E4%BE%9B%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%AF%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%BD%BC%E3%82%89%E3%81%AFOpenWRT%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E5%88%A9%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AB%E3%81%AF%E4%BD%95%E3%82%82%E8%BF%94%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20rgba(255%2C%20255%2C%20255%2C%200.8)%3B%20font-size%3A%2014px%3B%22%3EGPLv2%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%3C%2FSPAN%3E%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8FOpenWRT%E3%81%A7%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E3%81%A9%E3%81%86%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%8B%E7%A7%81%E3%81%AB%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23333333%3B%20background-color%3A%20rgba(255%2C%20255%2C%20255%2C%200.8)%3B%20font-size%3A%2014px%3B%22%3EOpenWRT%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%85%A5%E6%89%8B%E3%81%97%E3%81%9F%E6%96%B9%E3%81%8C%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E7%A7%81%E3%81%AE%E9%9B%BB%E5%AD%90%E3%83%A1%E3%83%BC%E3%83%AB%E3%81%AFmlopez(at)egiaudio.com%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106039%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Edk%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFzigbee%20%2F%20zigwave%E3%81%A7IOT%E3%82%B2%E3%83%BC%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81i.MX6UL%E4%B8%8A%E3%81%AEOpenWRT%E3%81%AB%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E4%BA%8B%E5%89%8D%E8%AA%8D%E5%AE%9A%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AB%E3%82%B5%E3%82%A4%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E7%99%BB%E9%8C%B2%E3%81%95%E3%82%8C%E3%81%9Fe-mal%E3%81%AF%20%3CA%20href%3D%22mailto%3Ajimmy.hsu%40zyxyel.com.tw%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ejimmy.hsu%40zyxyel.com.tw%3C%2FA%3E%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjim.lin%22%20target%3D%22_blank%22%3Ejim.lin%3C%2FA%3E%E2%80%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E5%BF%9C%E7%AD%94%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E4%BD%95%E3%81%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AB%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%8B%98%E6%9D%9F%E5%BD%A2%E6%85%8B%E7%B4%A0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Edk%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AFNXP%20i.MX%20FAE%20%2F%20CAS%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81i.MX6UL%E3%81%AEOpenWRT%E3%81%AB%E3%82%82%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AENXP%E5%86%85%E9%83%A8%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPS%3A%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AB%E5%82%99%E3%81%88%E3%81%A6%E3%80%81Thread%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B8%E3%83%A0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106036%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3EDhvanil%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014px%3B%22%3E%E4%BA%8B%E5%89%8D%E8%AA%8D%E5%AE%9A%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AB%E3%82%B5%E3%82%A4%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81OpenWrt%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014px%3B%22%3E%E7%A7%81%E3%81%AE%E7%99%BB%E9%8C%B2%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AFmlopez(at)%E3%81%A7%E3%81%99%20egiaudio.com%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014px%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20font-size%3A%2014px%3B%22%3E%E3%83%9F%E3%82%B2%E3%83%AB%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106035%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20edk%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%A7%81%E3%81%AE%E7%99%BB%E9%8C%B2%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9ID%3A%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Adhvanil.patel%40volansystech.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Edhvanil.patel%40volansystech.com%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-%3C%2FP%3E%3CP%3EDhvanil%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%80%E3%83%B4%E3%82%A1%E3%83%8B%E3%83%BB%E3%83%91%E3%83%86%E3%83%AB%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%A7%E3%81%AB%E3%82%B5%E3%82%A4%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E9%96%A2%E9%80%A3%E6%83%85%E5%A0%B1%E3%82%92%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%A1%E3%83%BC%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EEdk%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106033%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20edk%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E4%BA%8B%E5%89%8D%E8%AA%8D%E5%AE%9A%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AB%E3%82%B5%E3%82%A4%E3%83%B3%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81Openwrt%20%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%93%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%20Thread%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E5%86%85%E3%81%AB%E3%81%82%E3%82%8A%E3%80%81%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E4%BA%8B%E5%89%8D%E8%AA%8D%E5%AE%9A%20Thread%20%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fthread%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ewww.nxp.com%2Fthread%3C%2FA%3E%20%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E4%BA%8B%E5%89%8D%E8%AA%8D%E5%AE%9A%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fthread%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ewww.nxp.com%2Fthread%3C%2FA%3E%20%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106030%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106030%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOpenWRT%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AB%E3%81%A8%E3%81%A6%E3%82%82%E8%88%88%E5%91%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82i.MX6UL%E3%81%AEopenWRT%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%85%A5%E6%89%8B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F(%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%80%81DTS%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%91%E3%83%83%E3%83%81%E3%80%82%3C%2FP%3E%3CP%3Ei.mx6ul%E3%81%AE%E8%A9%95%E4%BE%A1%E3%82%AD%E3%83%83%E3%83%88%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%9F%E3%82%B2%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106029%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6UL%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FOpenWRT%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%83%9C%E3%83%BC%E3%83%80%E3%83%BC%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106029%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Cristian%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E9%96%8B%E7%99%BA%E8%80%85%E3%81%8C%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-%3C%2FP%3E%3CP%3EDhvanil%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎05-09-2016 03:03 PM
更新者:
