Demo
This demo showcases an OpenWRT based Thread Border router running on i.MX6UL and the various options to configure and use routing, firewall and out of band commissioning for Thread networks in combination with WiFi, Ethernet and NFC. OpenWRT is an open source Linux distribution for embedded devices specifically designed for residential gateways and routers. When enhanced with the Kinetis Thread protocol it offers the perfect solutions for creating a Linux based Thread Border Router
Large and dense mesh network consisting in 64+ Thread nodes
Each node is router capable, network decides dynamically which nodes become active routers
Multiple application functionality run in parallel:
Features:
_____________________________________________________________________________________________
Featured NXP Products:
| Product | Link |
| i.MX6UltraLite Evaluation Kit | i.MX6UltraLite Evaluation Kit | NXP |
| Freedom Development Platform for Kinetis® KW2x MCUs | FRDM-KW24D512|Freedom Development Platform|Kinetis | NXP |
Hi Cristian,
Is the source code and image available for developers ?
Dhvanil
I'm very interested in the OpenWRT image. Is it possible to get the source code of the openWRT tree for i.MX6UL? (thread is not necessary for us).
or at least, target directory, dts, drivers and patches.
I've already got the i.mx6ul evaluation kit.
thanks in advance
Miguel
Yes, but you will need to submit a request to access our Pre-Certified Thread Network Stack. Please go to the following link: www.nxp.com/thread for more information.
Yes, but the code is within the Thread package at this point and you will need to request access to our Pre-Certified Thread Network Stack to access it. Please go to the following link: www.nxp.com/thread for more information.
Hi edk,
I already sign up for the pre certified thread stack. but there isn't any source code available for Openwrt.
Hello Edk,
This is NXP i.MX FAE/CAS and I'm also interested in OpenWRT on i.MX6UL, is there any NXP internal repository to download it?
PS: I've just send the request for the access of the Thread stack, in case that's required.
Jim.
Hi Edk,
I'm develop IOT gateway with zigbee/zigwave and interested in OpenWRT on i.MX6UL.
I already sign up for the pre certified thread stack and my registered e-mal is jimmy.hsu@zyxyel.com.tw.
Could you help to provide OpenWRT thread source code ?
Don't waste your time. I talked to them and NXP is not willing to give anything unless you pay several thousand of dollars for support. This is interesting because they are taking advantage of open source software, like OpenWRT, not returning anything to the community. I don't know how this could be, with OpenWRT based on GPLv2 license.
If anyone gets a working source code of OpenWRT please let me know. My e-mail is mlopez (at) egiaudio.com.
Hello edk,
I'm develop IoT gateway with LPWAN(Thread/SigFox/LoRa).
I already sign up for the pre-certified thread stack and my registered e-mail is k2s@chience.co.kr.
Could you provide a OpenWRT source?
Hi Edk,
I would appreciate it very much if you can provide me the OpenWRT source. My registered e-mail is arvin.amos@gmail.com.
Thanks.
Arvin Lim
Hi Edk,
I would also appreciate it very much if you can provide me the OpenWRT source code. My registered e-mail is piers.basto@lightfox.com
Kind Regards,
Piers
