Nerf Gun Demo - Using FRDM K64F
Demo
11956_11956.jpgIMG_20140517_122609.jpg  11961_11961.jpgIMG_20140517_114232.jpg
This was a super fun project to work on and is popular around the office and on the road.  Now I have two of these for a truly amazing barrage of Nerf darts!  It's also always a lot of fun to tear things down and the Nerf gun had some cool plastic work and the shooting mechanism is more simple than what I originally guess.  But I digress, this post is about how you can build one of these yourself.  Please leave any questions or comments in the section below and I will try to answer and make refinements to this guide as we go.
The shopping list (aka Bill of Materials or BOM)
If you shop around you might be able to find better prices or substitute parts.
TypePartQtyPriceURL
UBECHKU51$             5.33http://www.hobbyking.com/hobbyking/store/__16663__HobbyKing_HKU5_5V_5A_UBEC.html
LiPoTURNIGY 2200mAh 3S 20C1$             7.89http://www.hobbyking.com/hobbyking/store/__8932__Turnigy_2200mAh_3S_20C_Lipo_Pack.html
ServoS5030DX1$           28.63http://www.hobbyking.com/hobbyking/store/__18862__Hobbyking_S5030DX_Digital_MG_Servo_X_Large_HV_164g...
ServoHK151381$             3.12http://www.hobbyking.com/hobbyking/store/__16269__HK15138_Standard_Analog_Servo_38g_4_3kg_0_17s.html
Relay PCBCOM-110411$             3.95https://www.sparkfun.com/products/11041
Relay ComponentsVarious1$             3.00https://www.sparkfun.com/wish_lists/36307
Nerf GunNerf Dart Tag Swarmfire Blaster1$           44.99http://www.toysrus.com/product/index.jsp?productId=11267568
ControllerFRDM-K64F1$           29.00FRDM-K64F | mbed
Servo ArmDouble Servo Arm X-Long1$             3.20http://www.hobbyking.com/hobbyking/store/__19468__CNC_Alloy_Double_Servo_Arm_X_Long_Futaba_.html
Servo ArmHeavy Duty Alloy Arm1$             5.63http://www.hobbyking.com/hobbyking/store/__18350__Heavy_Duty_Alloy_1in_Servo_Arm_Futaba_Red_.html
Servo LinkageAlloy Pushrod with Ball-Link 65mm1$             2.10http://www.hobbyking.com/hobbyking/store/__25834__Alloy_Pushrod_with_Ball_Link_65mm.html
Lazy SusanShepherd 6 in. Lazy-Susan Turntable1$             4.49http://www.homedepot.com/p/Shepherd-6-in-Lazy-Susan-Turntable-9548/100180572#.UYk5UqLql8E
Metal Rod3/8 in. x 36 in. Zinc Threaded Rod1$             2.87http://www.homedepot.com/p/3-8-in-x-36-in-Zinc-Threaded-Rod-17340/202183465#.UYk5pqLql8E
Frame1/2 MDF 2ftx4ft1$           10.45http://www.homedepot.com/p/1-2-in-x-2-ft-x-4-ft-Medium-Density-Fiberboard-Handy-Panel-1508108/202089...
The build
Two main pieces to construct in this phase.  The base turret and the actual hacking of the Nerf gun.
All your base..
The base of the turret is pretty rudimentary, lot's of room for improvement here.  I used 1/2 MDF and some carpentry skills.  Here is some instruction on how to build a MDF box.  Atop the box is a lazy Susan (ball bearing ring) so that the top-plate can rotate smoothly.  We considered leaving this element out, but worried that it would put to much strain on the servo.
On the subject of servos, a few tidbits of wisdom for you as you build this thing.  First, the left/right servo needs to be dead center of the lazy susan, if your off too much things will start to bind which is not good for your servo.  Second, I used large higher torque servos which cost a bit more, they might be overkill, but it certainly performs well.
I did a quick dimensionally accurate rendering of the design in Sketchup. Files are here.
Hacking the Nerf
Now for the fun stuff.
There is no shortage of screws with this Nerf Gun.  So get out your Phillips screwdriver and go to town.
There are two electrical systems in the Nerf that we are going to tap into.  One is the power switch and the other is the electrical trigger.
This is the electrical trigger.  The trigger goes to our relay, which is either on or off.  We did try at first to use a 7.2V R/C car battery, but the Nerf draws too much power and didn't fire.  Going up to a 11.1V LiPo fixed that right up.
This is the power switch.
In Nerfinator 1.0 everything was hardwired together, which prevented us from completely pulling the Nerf from the base and made repairs difficult to say the least.  Nerfinator 2.0 we put this handy connector which allowed us to completely and easily remove the Nerf from the base.  Shipping this thing around the country will take a toll on it!  On that subject, Nerf 1.0, stopped cycling to the next position for us at the Austin Mini Maker Faire.  After a through inspection of the operational mechanics inside the Nerf (really cool BTW) it was a little bitty spring that was causing the piston not to fully retract.  We replaced the spring with 1/2 a ballpoint pin spring and to our surprise it all worked again.
Electrical Connection Diagram
Added High-Level Block Diagram.  Need to add pinouts.  You'll have to read the code for now to figure it out.
Code
Mbed was the programming tool of choice for this build.
Receive Side (RX) - The receiver is the base side.  This one takes input from the remote and controls the servo movement.
NerfGun_nRF24L01P_RX - a mercurial repository | mbed
Transmit Side (TX) - The transmitter is the remote side.  This one senses the users movement (accelerometer) and sends that data to the base station.
NerfGun_nRF24L01P_TX - a mercurial repository | mbed
Finishing Touches
In the first passes of this build we just used a bare development board as the remote control.  We found that when given the remote they would not orientate it properly, so
3D Printed Controller STL files
Development Team
John McLellan - Amplification/Motivation
Clark Jarvis - Software/Hardware
Iain Galloway and Angus Galloway - Design and print of controller
添付
コメント
This is so cool.
I want one.
LOL  Reminds me of my project where I strapped a nerf dart gun on an autonomous penguin...
that's great!
%3CLINGO-SUB%20id%3D%22lingo-sub-1103727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%8A%E3%83%BC%E3%83%95%E3%82%AC%E3%83%B3%E3%83%87%E3%83%A2%20-%20FRDM%20K64F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20style%3D%22margin-right%3A%20100px%3B%20padding-left%3A%202px%3B%20font-style%3A%20inherit%3B%20font-size%3A%2026px%3B%20font-family%3A%20inherit%3B%22%20id%3D%22toc-hId-380581144%22%20id%3D%22toc-hId-1304186806%22%3EDemo%3C%2FH1%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211956_11956.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211956_11956.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117408iCD9A427373474D25%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2211956_11956.jpg%22%20alt%3D%2211956_11956.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E11956_11956.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20140517_122609.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20140517_122609.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84610i99006C50126B128E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG_20140517_122609.jpg%22%20alt%3D%22IMG_20140517_122609.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EIMG_20140517_122609.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%26nbsp%3B%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211961_11961.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211961_11961.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117409i9B88678A089DFB69%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2211961_11961.jpg%22%20alt%3D%2211961_11961.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E11961_11961.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20140517_114232.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20140517_114232.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F43922iD26713C62D6A5922%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG_20140517_114232.jpg%22%20alt%3D%22IMG_20140517_114232.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EIMG_20140517_114232.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%A8%E3%81%A6%E3%82%82%E6%A5%BD%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%80%81%E3%82%AA%E3%83%95%E3%82%A3%E3%82%B9%E3%82%84%E5%A4%96%E5%87%BA%E5%85%88%E3%81%A7%E3%82%82%E4%BA%BA%E6%B0%97%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BB%8A%E3%80%81%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%81%86%E3%81%A1%E3%81%AE2%E3%81%A4%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%A6%E3%80%81%E6%9C%AC%E5%BD%93%E3%81%AB%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84Nerf%E3%83%80%E3%83%BC%E3%83%84%E3%81%AE%E5%BC%BE%E5%B9%95%E3%81%A7%E3%81%99!%E3%81%BE%E3%81%9F%E3%80%81%E7%89%A9%E3%82%92%E5%A3%8A%E3%81%99%E3%81%AE%E3%81%AF%E3%81%84%E3%81%A4%E3%82%82%E3%81%A8%E3%81%A6%E3%82%82%E6%A5%BD%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%97%E3%80%81%E3%83%8A%E3%83%BC%E3%83%95%E9%8A%83%E3%81%AB%E3%81%AF%E3%82%AF%E3%83%BC%E3%83%AB%E3%81%AA%E3%83%97%E3%83%A9%E3%82%B9%E3%83%81%E3%83%83%E3%82%AF%E7%B4%B0%E5%B7%A5%E3%81%8C%E6%96%BD%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%A6%E3%80%81%E5%B0%84%E6%92%83%E3%81%AE%E4%BB%95%E7%B5%84%E3%81%BF%E3%81%AF%E7%A7%81%E3%81%8C%E6%9C%80%E5%88%9D%E3%81%AB%E6%83%B3%E5%83%8F%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%82%82%E3%81%AE%E3%82%88%E3%82%8A%E3%82%82%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%E9%96%91%E8%A9%B1%E4%BC%91%E9%A1%8C%E3%80%81%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE1%E3%81%A4%E3%82%92%E8%87%AA%E5%88%86%E3%81%A7%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%A7%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E8%B3%AA%E5%95%8F%E3%82%84%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E6%AE%8B%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E7%A7%81%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E9%80%B2%E3%82%80%E3%81%AB%E3%81%A4%E3%82%8C%E3%81%A6%E3%81%93%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E7%AD%94%E3%81%88%E3%81%A6%E6%94%B9%E8%89%AF%E3%82%92%E5%8A%A0%E3%81%88%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%20id%3D%22toc-hId-1071142618%22%20id%3D%22toc-hId-1994748280%22%3E%E3%82%B7%E3%83%A7%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%83%AA%E3%82%B9%E3%83%88%20(%E5%88%A5%E5%90%8D%E3%80%81%E9%83%A8%E5%93%81%E8%A1%A8%20(BOM))%3C%2FH2%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E5%91%A8%E3%82%8A%E3%81%AB%E8%B2%B7%E3%81%84%E7%89%A9%E3%82%92%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E3%82%88%E3%82%8A%E8%89%AF%E3%81%84%E4%BE%A1%E6%A0%BC%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E3%82%8A%E3%80%81%E9%83%A8%E5%93%81%E3%82%92%E4%BA%A4%E6%8F%9B%E3%81%97%E3%81%9F%E3%82%8A%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CDIV%20class%3D%22j-rte-table%22%3E%3CTABLE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTBODY%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20class%3D%22xl67%22%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%20width%3D%22151%22%3E%E7%A8%AE%E9%A1%9E%3C%2FTD%3E%3CTD%20class%3D%22xl67%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%20width%3D%22221%22%3E%E9%83%A8%E5%88%86%3C%2FTD%3E%3CTD%20class%3D%22xl67%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%20width%3D%2266%22%3E%E6%95%B0%E9%87%8F%3C%2FTD%3E%3CTD%20class%3D%22xl68%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%20width%3D%2287%22%3E%E4%BE%A1%E6%A0%BC%3C%2FTD%3E%3CTD%20class%3D%22xl69%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%20width%3D%22876%22%3EURL%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%83%A6%E3%83%BC%E3%83%99%E3%83%83%E3%82%AF%3C%2FTD%3E%3CTD%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EHKU5%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%205.33%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.hobbyking.com%2Fhobbyking%2Fstore%2F__16663__HobbyKing_HKU5_5V_5A_UBEC.html%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.hobbyking.com%2Fhobbyking%2Fstore%2F__16663__HobbyKing_HKU5_5V_5A_UBEC.html%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3ELiPo%3C%2FTD%3E%3CTD%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3ETURNIGY%202200mAh%203S%2020C%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%207.89%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.hobbyking.com%2Fhobbyking%2Fstore%2F__8932__Turnigy_2200mAh_3S_20C_Lipo_Pack.html%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.hobbyking.com%2Fhobbyking%2Fstore%2F__8932__Turnigy_2200mAh_3S_20C_Lipo_Pack.html%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EServo%3C%2FTD%3E%3CTD%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3ES5030DX%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2028.63%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.hobbyking.com%2Fhobbyking%2Fstore%2F__18862__Hobbyking_S5030DX_Digital_MG_Servo_X_Large_HV_164g_0_20s_30kg.html%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.hobbyking.com%2Fhobbyking%2Fstore%2F__18862__Hobbyking_S5030DX_Digital_MG_Servo_X_Large_HV_164g_0_20s_30kg.html%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EServo%3C%2FTD%3E%3CTD%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EHK15138%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203.12%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.hobbyking.com%2Fhobbyking%2Fstore%2F__16269__HK15138_Standard_Analog_Servo_38g_4_3kg_0_17s.html%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.hobbyking.com%2Fhobbyking%2Fstore%2F__16269__HK15138_Standard_Analog_Servo_38g_4_3kg_0_17s.html%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%83%AA%E3%83%AC%E3%83%BCPCB%3C%2FTD%3E%3CTD%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3ECOM-11041%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203.95%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fwww.sparkfun.com%2Fproducts%2F11041%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.sparkfun.com%2Fproducts%2F11041%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%83%AA%E3%83%AC%E3%83%BC%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%3C%2FTD%3E%3CTD%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E8%AB%B8%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203.00%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fwww.sparkfun.com%2Fwish_lists%2F36307%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.sparkfun.com%2Fwish_lists%2F36307%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3ENerf%20Gun%3C%2FTD%3E%3CTD%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%83%8A%E3%83%BC%E3%83%95%E3%83%80%E3%83%BC%E3%83%84%E3%82%BF%E3%82%B0%E3%82%B9%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%A4%E3%83%BC%E3%83%96%E3%83%A9%E3%82%B9%E3%82%BF%E3%83%BC%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2044.99%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.toysrus.com%2Fproduct%2Findex.jsp%3FproductId%3D11267568%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.toysrus.com%2Fproduct%2Findex.jsp%3FproductId%3D11267568%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FTD%3E%3CTD%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EFRDM-K64F%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2029.00%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20class%3D%22%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmbed.org%2Fplatforms%2FFRDM-K64F%22%20target%3D%22_blank%22%3EFRDM-K64F%E5%9E%8B%20%7CMBED%E3%81%AE%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EServo%20Arm%3C%2FTD%3E%3CTD%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%83%80%E3%83%96%E3%83%AB%E3%82%B5%E3%83%BC%E3%83%9C%E3%82%A2%E3%83%BC%E3%83%A0X-Long%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%203.20%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.hobbyking.com%2Fhobbyking%2Fstore%2F__19468__CNC_Alloy_Double_Servo_Arm_X_Long_Futaba_.html%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.hobbyking.com%2Fhobbyking%2Fstore%2F__19468__CNC_Alloy_Double_Servo_Arm_X_Long_Futaba_.html%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EServo%20Arm%3C%2FTD%3E%3CTD%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%83%98%E3%83%93%E3%83%BC%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%BC%E5%90%88%E9%87%91%E3%82%A2%E3%83%BC%E3%83%A0%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%205.63%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.hobbyking.com%2Fhobbyking%2Fstore%2F__18350__Heavy_Duty_Alloy_1in_Servo_Arm_Futaba_Red_.html%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.hobbyking.com%2Fhobbyking%2Fstore%2F__18350__Heavy_Duty_Alloy_1in_Servo_Arm_Futaba_Red_.html%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%82%B5%E3%83%BC%E3%83%9C%E3%83%AA%E3%83%B3%E3%82%B1%E3%83%BC%E3%82%B8%3C%2FTD%3E%3CTD%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%AB%E3%83%AA%E3%83%B3%E3%82%AF%E4%BB%98%E3%81%8D%E5%90%88%E9%87%91%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%83%E3%83%8965mm%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.10%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.hobbyking.com%2Fhobbyking%2Fstore%2F__25834__Alloy_Pushrod_with_Ball_Link_65mm.html%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.hobbyking.com%2Fhobbyking%2Fstore%2F__25834__Alloy_Pushrod_with_Ball_Link_65mm.html%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E6%80%A0%E6%83%B0%E3%81%AA%E3%82%B9%E3%83%BC%E3%82%B6%E3%83%B3%3C%2FTD%3E%3CTD%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%82%B7%E3%82%A7%E3%83%91%E3%83%BC%E3%83%896%E3%82%A4%E3%83%B3%E3%83%81%E3%83%AC%E3%82%A4%E3%82%B8%E3%83%BC%E3%83%BB%E3%82%B9%E3%83%BC%E3%82%B6%E3%83%B3%E3%83%BB%E3%82%BF%E3%83%BC%E3%83%B3%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%204.49%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.homedepot.com%2Fp%2FShepherd-6-in-Lazy-Susan-Turntable-9548%2F100180572%23.UYk5UqLql8E%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.homedepot.com%2Fp%2FShepherd-6-in-Lazy-Susan-Turntable-9548%2F100180572%23.UYk5UqLql8E%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EMetal%20Rod%3C%2FTD%3E%3CTD%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E3%2F8%E3%82%A4%E3%83%B3%E3%83%81x%2036%E3%82%A4%E3%83%B3%E3%83%81%E4%BA%9C%E9%89%9B%E3%81%AD%E3%81%98%E4%BB%98%E3%81%8D%E3%83%AD%E3%83%83%E3%83%89%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%202.87%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.homedepot.com%2Fp%2F3-8-in-x-36-in-Zinc-Threaded-Rod-17340%2F202183465%23.UYk5pqLql8E%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.homedepot.com%2Fp%2F3-8-in-x-36-in-Zinc-Threaded-Rod-17340%2F202183465%23.UYk5pqLql8E%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CTD%20height%3D%2219%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%3C%2FTD%3E%3CTD%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%2F2%20MDF%202%E3%83%95%E3%82%A3%E3%83%BC%E3%83%88x4%E3%83%95%E3%82%A3%E3%83%BC%E3%83%88%3C%2FTD%3E%3CTD%20class%3D%22xl66%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E1%3C%2FTD%3E%3CTD%20class%3D%22xl65%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%24%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2010.45%3C%2FTD%3E%3CTD%20class%3D%22xl64%22%20style%3D%22padding-right%3A%204px%3B%20padding-left%3A%204px%3B%20border%3A%200px%20solid%20black%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fwww.homedepot.com%2Fp%2F1-2-in-x-2-ft-x-4-ft-Medium-Density-Fiberboard-Handy-Panel-1508108%2F202089097%3FN%3Dbtn1%23.UYk6CqLql8E%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.homedepot.com%2Fp%2F1-2-in-x-2-ft-x-4-ft-Medium-Density-Fiberboard-Handy-Panel-1508108%2F202089097%3FN%3Dbtn1%23.UYk6CqLql8E%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%20id%3D%22toc-hId--736311845%22%20id%3D%22toc-hId-187293817%22%3E%E3%83%93%E3%83%AB%E3%83%89%3C%2FH2%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%81%93%E3%81%AE%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E3%81%A7%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B2%E3%81%A4%E3%81%AE%E4%B8%BB%E8%A6%81%E3%81%AA%E3%83%94%E3%83%BC%E3%82%B9%E3%80%82%E5%9F%BA%E6%9C%AC%E7%A0%B2%E5%A1%94%E3%81%A8%E3%83%8A%E3%83%BC%E3%83%95%E7%A0%B2%E3%81%AE%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%8F%E3%83%83%E3%82%AD%E3%83%B3%E3%82%B0%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH3%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%20id%3D%22toc-hId--45750371%22%20id%3D%22toc-hId-877855291%22%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9..%3C%2FH3%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E7%A0%B2%E5%A1%94%E3%81%AE%E5%9F%BA%E9%83%A8%E3%81%AF%E3%81%8B%E3%81%AA%E3%82%8A%E5%88%9D%E6%AD%A9%E7%9A%84%E3%81%A7%E3%80%81%E3%81%93%E3%81%93%E3%81%AB%E3%81%AF%E6%94%B9%E5%96%84%E3%81%AE%E4%BD%99%E5%9C%B0%E3%81%8C%E3%81%9F%E3%81%8F%E3%81%95%E3%82%93%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF1%2F2%20MDF%E3%81%A8%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%A4%A7%E5%B7%A5%E4%BB%95%E4%BA%8B%E3%81%AE%E3%82%B9%E3%82%AD%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81MDF%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AE%E4%BD%9C%E3%82%8A%E6%96%B9%E3%82%92%E3%81%94%E7%B4%B9%E4%BB%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%AE%B1%E3%81%AE%E4%B8%8A%E3%81%AB%E3%81%AF%E6%80%A0%E6%83%B0%E3%81%AA%E3%82%B9%E3%83%BC%E3%82%B6%E3%83%B3(%E3%83%9C%E3%83%BC%E3%83%AB%E3%83%99%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%AA%E3%83%B3%E3%82%B0)%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E5%A4%A9%E6%9D%BF%E3%81%8C%E3%82%B9%E3%83%A0%E3%83%BC%E3%82%BA%E3%81%AB%E5%9B%9E%E8%BB%A2%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E8%A6%81%E7%B4%A0%E3%82%92%E5%85%A5%E3%82%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%82%E8%80%83%E3%81%88%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%B5%E3%83%BC%E3%83%9C%E3%81%AB%E5%A4%A7%E3%81%8D%E3%81%AA%E8%B2%A0%E6%8B%85%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E5%BF%83%E9%85%8D%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%82%B5%E3%83%BC%E3%83%9C%E3%81%AE%E8%A9%B1%E9%A1%8C%E3%81%A7%E3%81%AF%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E3%81%93%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AE%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E7%9F%A5%E6%81%B5%E3%81%AE%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%B0%8F%E3%83%8D%E3%82%BF%E3%80%82%E3%81%BE%E3%81%9A%E3%80%81%E5%B7%A6%2F%E5%8F%B3%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%9C%E3%81%AF%E3%80%81%E6%80%A0%E6%83%B0%E3%81%AA%E3%82%B9%E3%83%BC%E3%82%B6%E3%83%B3%E3%81%AE%E6%AD%BB%E7%82%B9%E3%81%AB%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%AA%E3%83%95%E3%81%8C%E5%A4%9A%E3%81%99%E3%81%8E%E3%82%8B%E3%81%A8%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B5%E3%83%BC%E3%83%9C%E3%81%AB%E8%89%AF%E3%81%8F%E3%81%AA%E3%81%84%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AF%E5%B0%91%E3%81%97%E9%AB%98%E4%BE%A1%E3%81%A7%E3%81%82%E3%82%8B%E5%A4%A7%E5%9E%8B%E3%81%AE%E9%AB%98%E3%83%88%E3%83%AB%E3%82%AF%E3%82%B5%E3%83%BC%E3%83%9C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E5%BD%BC%E3%82%89%E3%81%AF%E3%82%84%E3%82%8A%E9%81%8E%E3%81%8E%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E7%A2%BA%E3%81%8B%E3%81%AB%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3ESketchup%E3%81%A7%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AE%E5%AF%B8%E6%B3%95%E7%9A%84%E3%81%AB%E6%AD%A3%E7%A2%BA%E3%81%AA%E3%83%AC%E3%83%B3%E3%83%80%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E3%81%99%E3%81%B0%E3%82%84%E3%81%8F%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CA%20_jive_internal%3D%22true%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F100845-22-275247%2FSketchup_Files.zip%22%20target%3D%22_blank%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%81%93%E3%81%A1%E3%82%89%E3%81%A7%E3%81%99%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH3%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%20id%3D%22toc-hId--1853204834%22%20id%3D%22toc-hId--929599172%22%3E%E3%83%8A%E3%83%BC%E3%83%95%E3%81%AE%E3%83%8F%E3%83%83%E3%82%AD%E3%83%B3%E3%82%B0%3C%2FH3%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%81%95%E3%81%A6%E3%80%81%E6%A5%BD%E3%81%97%E3%81%84%E3%82%82%E3%81%AE%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%81%93%E3%81%AE%E3%83%8A%E3%83%BC%E3%83%95%E3%82%AC%E3%83%B3%E3%81%A7%E3%81%AF%E3%83%8D%E3%82%B8%E3%81%AB%E4%BA%8B%E6%AC%A0%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E3%83%97%E3%83%A9%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%8F%96%E3%82%8A%E5%87%BA%E3%81%97%E3%81%A6%E8%A1%97%E3%81%AB%E5%87%BA%E3%81%8B%E3%81%91%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211947_11947.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211947_11947.jpg%22%20style%3D%22width%3A%20960px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117410iEEDEBDCCBAEDDBA0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2211947_11947.jpg%22%20alt%3D%2211947_11947.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E11947_11947.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Disassembly.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Disassembly.jpg%22%20style%3D%22width%3A%20960px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F6759i95A93B0951BBD5BE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Disassembly.jpg%22%20alt%3D%22Disassembly.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EDisassembly.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3ENerf%E3%81%AB%E3%81%AF2%E3%81%A4%E3%81%AE%E9%9B%BB%E6%B0%97%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E5%88%A9%E7%94%A8%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%821%E3%81%A4%E3%81%AF%E9%9B%BB%E6%BA%90%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%A7%E3%80%81%E3%82%82%E3%81%861%E3%81%A4%E3%81%AF%E9%9B%BB%E6%B0%97%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%81%93%E3%82%8C%E3%81%8C%E9%9B%BB%E6%B0%97%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%A7%E3%81%99%E3%80%82%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%AF%E3%80%81%E3%82%AA%E3%83%B3%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AA%E3%83%95%E3%81%AE%E3%83%AA%E3%83%AC%E3%83%BC%E3%81%AB%E9%80%81%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E6%9C%80%E5%88%9D%E3%81%AF7.2V%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E4%BD%BF%E3%81%8A%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%8A%E3%83%BC%E3%83%95%E3%81%AF%E9%9B%BB%E5%8A%9B%E3%82%92%E6%B6%88%E8%B2%BB%E3%81%97%E3%81%99%E3%81%8E%E3%81%A6%E7%82%B9%E7%81%AB%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%8211.1V%20LiPo%E3%81%AB%E4%B8%8A%E3%81%92%E3%82%8B%E3%81%A8%E3%80%81%E3%81%99%E3%81%90%E3%81%AB%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211949_11949.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211949_11949.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117411iE6B1E9199AD1CFC7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2211949_11949.jpg%22%20alt%3D%2211949_11949.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E11949_11949.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22trigger_hack.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22trigger_hack.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84611iD4BFAB6213945D03%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22trigger_hack.jpg%22%20alt%3D%22trigger_hack.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Etrigger_hack.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%81%93%E3%82%8C%E3%81%8C%E9%9B%BB%E6%BA%90%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211950_11950.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211950_11950.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117412i09A90F4AE08DA521%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2211950_11950.jpg%22%20alt%3D%2211950_11950.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E11950_11950.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22power_switch_hack.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22power_switch_hack.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84612i6946C6670EE6132F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22power_switch_hack.jpg%22%20alt%3D%22power_switch_hack.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Epower_switch_hack.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3ENerfinator%201.0%E3%81%A7%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E3%83%8F%E3%83%BC%E3%83%89%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81Nerf%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E5%AE%8C%E5%85%A8%E3%81%AB%E5%BC%95%E3%81%8D%E6%8A%9C%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E6%8E%A7%E3%81%88%E3%82%81%E3%81%AB%E8%A8%80%E3%81%A3%E3%81%A6%E3%82%82%E4%BF%AE%E7%90%86%E3%81%8C%E5%9B%B0%E9%9B%A3%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82Nerfinator%202.0%20%E3%81%93%E3%81%AE%E4%BE%BF%E5%88%A9%E3%81%AA%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92%E9%85%8D%E7%BD%AE%E3%81%97%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E3%83%99%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%20Nerf%20%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%8B%E3%81%A4%E7%B0%A1%E5%8D%98%E3%81%AB%E5%8F%96%E3%82%8A%E5%A4%96%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E5%85%A8%E5%9B%BD%E3%81%AB%E7%99%BA%E9%80%81%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%A4%A7%E3%81%8D%E3%81%AA%E8%B2%A0%E6%8B%85%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E7%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81Nerf%201.0%E3%81%AF%E3%80%81Austin%20Mini%20Maker%20Faire%E3%81%A7%E6%AC%A1%E3%81%AE%E3%83%9D%E3%82%B8%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%B8%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%8A%E3%83%BC%E3%83%95%E5%86%85%E9%83%A8%E3%81%AE%E5%8B%95%E4%BD%9C%E3%83%A1%E3%82%AB%E3%83%8B%E3%82%BA%E3%83%A0%E3%82%92%E5%BE%B9%E5%BA%95%E7%9A%84%E3%81%AB%E6%A4%9C%E6%9F%BB%E3%81%97%E3%81%9F%E5%BE%8C(%E6%9C%AC%E5%BD%93%E3%81%AB%E3%82%AF%E3%83%BC%E3%83%AB%E3%81%AA%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7)%E3%80%81%E3%83%94%E3%82%B9%E3%83%88%E3%83%B3%E3%81%8C%E5%AE%8C%E5%85%A8%E3%81%AB%E5%BC%95%E3%81%A3%E8%BE%BC%E3%82%81%E3%82%89%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%AF%E5%B0%91%E3%81%97%E5%B0%8F%E3%81%95%E3%81%AA%E3%82%B9%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%82%B9%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%921%2F2%E3%83%9C%E3%83%BC%E3%83%AB%E3%83%9A%E3%83%B3%E3%83%94%E3%83%B3%E3%82%B9%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AB%E4%BA%A4%E6%8F%9B%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E9%A9%9A%E3%81%84%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AB%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E5%86%8D%E3%81%B3%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CH3%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%20id%3D%22toc-hId-634307999%22%20id%3D%22toc-hId-1557913661%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211951_11951.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2211951_11951.jpg%22%20style%3D%22width%3A%20562px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117413iF6A3C060148755F3%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2211951_11951.jpg%22%20alt%3D%2211951_11951.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E11951_11951.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20140512_105908_384.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22IMG_20140512_105908_384.jpg%22%20style%3D%22width%3A%20562px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F84613iDDB40BCCA16FA1AC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22IMG_20140512_105908_384.jpg%22%20alt%3D%22IMG_20140512_105908_384.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EIMG_20140512_105908_384.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FH3%3E%3CH3%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%20id%3D%22toc-hId--1173146464%22%20id%3D%22toc-hId--249540802%22%3E%E9%9B%BB%E6%B0%97%E6%8E%A5%E7%B6%9A%E5%9B%B3%3C%2FH3%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E9%AB%98%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%20%3CA%20_jive_internal%3D%22true%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F100956-7-286919%2FSchematic.pdf%22%20target%3D%22_blank%22%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%9B%B3%3C%2FA%3E%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%94%E3%83%B3%E9%85%8D%E7%BD%AE%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E3%81%BF%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH2%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%20id%3D%22toc-hId--1183649568%22%20id%3D%22toc-hId--260043906%22%3E%E3%82%B3%E3%83%BC%E3%83%89%3C%2FH2%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EMbed%20%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E6%9C%80%E9%81%A9%E3%81%AA%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3E%E5%8F%97%E4%BF%A1%E5%81%B4(RX)%3C%2FSTRONG%3E%3C%2FSPAN%3E%20-%20%E5%8F%97%E4%BF%A1%E5%81%B4%E3%81%AF%E3%83%99%E3%83%BC%E3%82%B9%E5%81%B4%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%AA%E3%83%A2%E3%82%B3%E3%83%B3%E3%81%8B%E3%82%89%E5%85%A5%E5%8A%9B%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%80%81%E3%82%B5%E3%83%BC%E3%83%9C%E3%81%AE%E5%8B%95%E3%81%8D%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fmbed.org%2Fusers%2Fjohnmc%2Fcode%2FNerfGun_nRF24L01P_RX%2F%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ENerfGun_nRF24L01P_RX%20-%20%E6%B0%B4%E9%8A%80%E3%81%AE%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20%7CMBED%E3%81%AE%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3E%E9%80%81%E4%BF%A1%E5%81%B4(TX)%3C%2FSTRONG%3E%3C%2FSPAN%3E%20-%20%E9%80%81%E4%BF%A1%E6%A9%9F%E3%81%AF%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E5%81%B4%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AE%E5%8B%95%E3%81%8D(%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%A8%88)%E3%82%92%E6%84%9F%E7%9F%A5%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%9F%BA%E5%9C%B0%E5%B1%80%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22http%3A%2F%2Fmbed.org%2Fusers%2Fjohnmc%2Fcode%2FNerfGun_nRF24L01P_TX%2F%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ENerfGun_nRF24L01P_TX%20-%20Mercurial%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20%7CMBED%E3%81%AE%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH3%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%20id%3D%22toc-hId--493088094%22%20id%3D%22toc-hId-430517568%22%3E%E4%BB%95%E4%B8%8A%E3%81%92%3C%2FH3%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%E3%81%93%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%91%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E8%A3%B8%E3%81%AE%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%83%A2%E3%82%B3%E3%83%B3%E3%82%92%E6%B8%A1%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E9%81%A9%E5%88%87%E3%81%AB%E5%90%91%E3%81%8D%E3%82%92%E5%A4%89%E3%81%88%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F100845-22-275248%2FFRDM_case_sunday_PART_REV_001.STL.zip%22%20target%3D%22_blank%22%3E3D%E3%83%97%E3%83%AA%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BCSTL%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH3%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%20id%3D%22toc-hId-1994424739%22%20id%3D%22toc-hId--1376936895%22%3E%E9%96%8B%E7%99%BA%E3%83%81%E3%83%BC%E3%83%A0%3C%2FH3%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjohnmc%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20target%3D%22_blank%22%3E%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%9E%E3%82%AF%E3%83%AC%E3%83%A9%E3%83%B3%3C%2FA%3E%20-%20%E5%A2%97%E5%B9%85%2F%E3%83%A2%E3%83%81%E3%83%99%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FCJarvis%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20target%3D%22_blank%22%3EClark%20Jarvis%3C%2FA%3E%20-%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%2F%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FP%3E%3CP%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fiafg%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20target%3D%22_blank%22%3EIain%20Galloway%3C%2FA%3E%20and%20%3CA%20_jive_internal%3D%22true%22%20data-objecttype%3D%223%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fangusgalloway-b45797%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20target%3D%22_blank%22%3EAngus%20Galloway%3C%2FA%3E%20-%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AE%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%A8%E5%8D%B0%E5%88%B7%3C%2FP%3E%3CUL%3E%3CLI%3E%3CA%20_jive_internal%3D%22true%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F100845-22-275248%2FFRDM_case_sunday_PART_REV_001.STL.zip%22%20target%3D%22_blank%22%3EFRDM_case_sunday_PART_REV_001.STL.zip%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1103727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B9%E3%83%9E%E3%83%BC%E3%83%88%E3%83%9B%E3%83%BC%E3%83%A0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%8A%E3%83%BC%E3%83%95%E3%82%AC%E3%83%B3%E3%83%87%E3%83%A2%20-%20FRDM%20K64F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%8A%E3%83%BC%E3%83%95%E3%82%AC%E3%83%B3%E3%83%87%E3%83%A2%20-%20FRDM%20K64F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%AC%91%20%E8%87%AA%E5%BE%8B%E5%9E%8B%20%3CA%20href%3D%22http%3A%2F%2Farduino-pi.blogspot.ca%2F2014%2F04%2Fpenguinbot-self-defence-or-how-to-arm.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%83%9A%E3%83%B3%E3%82%AE%E3%83%B3%E3%81%AB%E3%83%8A%E3%83%BC%E3%83%95%E3%83%80%E3%83%BC%E3%83%84%E3%82%AC%E3%83%B3%E3%82%92%E8%A3%85%E7%9D%80%3C%2FA%3E%E3%81%97%E3%81%9F%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E6%80%9D%E3%81%84%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99...%20%3C%2FP%3E%3CP%3E%3CIMG%20alt%3D%22IMG_20140427_090932.jpg%22%20class%3D%22jive-image%22%20height%3D%22441%22%20src%3D%22http%3A%2F%2F2.bp.blogspot.com%2F--AzWE1yDVoU%2FU11DlpSDHCI%2FAAAAAAAAAZk%2Fu5dwphQHqL0%2Fs1600%2FIMG_20140427_090932.jpg%22%20style%3D%22width%3A%20302.027px%3B%20height%3A%20441px%3B%20float%3A%20left%3B%22%20width%3D%22302%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%8A%E3%83%BC%E3%83%95%E3%82%AC%E3%83%B3%E3%83%87%E3%83%A2%20-%20FRDM%20K64F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103729%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E4%BA%BA%E3%80%85%E3%82%92%E8%BF%BD%E8%B7%A1%E3%81%99%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%99!!%3CA%20href%3D%22http%3A%2F%2Fmakezine.com%2F2015%2F02%2F16%2Ffoamland-security-sibling-proof-your-stuff-with-a-nerf-sentry-gun%2F%22%20title%3D%22http%3A%2F%2Fmakezine.com%2F2015%2F02%2F16%2Ffoamland-security-sibling-proof-your-stuff-with-a-nerf-sentry-gun%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fmakezine.com%2F2015%2F02%2F16%2Ffoamland-security-sibling-proof-your-stuff-with-a-nerf-sentry-gun%2F%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%83%8A%E3%83%BC%E3%83%95%E3%82%AC%E3%83%B3%E3%83%87%E3%83%A2%20-%20FRDM%20K64F%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103728%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%A8%E3%81%A6%E3%82%82%E3%82%AF%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%B2%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎05-21-2014 01:34 PM
更新者:
