Demo
Wheel rotation is controlled by the SB0400 DC motor pre-driver. When the wheel is stopped manually, the Wheel Speed Sensor -KMI23- detects it & sends a signal to the SB0400 motor pre-driver & S32K MCU to activate the electromagnet
Products
Links
Now there is a " Motorcycle ABS" project, in demo found the solution "Motorcycle ABS (S32K + SB0400) ".
Could you please show me where can I get the refence design ?
Kiger
